Question about Philips Magnavox Learning Universal Remote
Magnavox TV all in one remote code
Remote codes for TV needed
I have held down the code search button and the TV button and then entered my TV code conitinually and this doesn't work. Tried new batteries. That didn't work either.
  • 5 more comments
  • Martin Earl Apr 20, 2008
    It's an older remote mabye early 2000-ish
  • char6443 Apr 29, 2008
    this is the third remote I tried. none of the codes work for magnavox tv. maybe the tv wont accept the signal?
  • Anonymous May 15, 2008
    I too can't get my Philips Universal remote to change channels up or down on my Philips/Magnavox, but it will turn on & off. I have the written instructions for my Philips Universal, but none of the codes seem to work.
  • darkdestroye Aug 07, 2008
    i have a magnavox remote without the instructions, how do you programme the reomte?
  • Anonymous Oct 13, 2008
    It just won't work for the Magnavox TV. It was working, but now I can't reprogram it. It is so frustratin!!!!
  • Anonymous Mar 18, 2014
    trying to program remote to magnavox tv
  • Anonymous Mar 24, 2014
    Remote worked fine until I replaced with new batteries. The lights on both the remote and the converter box light up when trying to perform a function but does nothing. The remote will power on the converter box but nothing else.
    Champion:
  • 207 Answers
I have the same problem. I called Philips and they told me that if it doesn't work I need to return my remote because it is not compatible with my TV.
It's surprising though becuase I have a magnavox remote (made by philips) and it wont work with a Magnavox TV!!!
Posted on Oct 10, 2008
I have a philips SRU3003WM universal remote im trying tn program to work on a magnavox tv model TR2510 C101 but cant find the codes to do so
The codes for Magnavox are 0807, 0002, 0502, 0919, 1914, 0224, 0430, 0247, 0402, 0408, 0109, 0715. Enter the code in the Setup and then check if the remote does any feature other than on/off.
You can search through all the codes as well. Turn on the TV. Press and hold the Setup button until the light remains lit. Press the TV button. Press Channel Up repeatedly (up to 300 times) until the channel changes on the TV. (If you miss this, press Channel Down to backtrack). Press the Mute button to set the code. Check if the TV responds to other functions of the remote. Continue the search as above if it doesn't work for all desired functions.
However if your TV was released less than 6 months before the remote was programmed or is newer than the remote, the code you need may not be in the programming.
I hope this helps.
Oct 03, 2010 | Philips Magnavox 27MS343S 27" TV
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
SDTV REMOTE CODES FOR MAGNAVOX
Hi
On the URC 4330 model the Magnavox brand is not listed in the code index.
Therefore, you should be aware that this remote may not have code stored in its pre-programmed library to allow it to operate Magnavox.
There is a code search function with this remote and this is your only other option in a situation such as this.
TO SEARCH FOR YOUR CODE FOR YOUR TV
1. On the remote control, press TV once.
2. Press and hold SET until the LED blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first so this may take some time to complete.
5.Once you find the point at which the remote operates the TV press and hold SET until the LED blinks twice, then release SET. This locks in the code.
As I say - the remote may or may not compatible with Magnavox. However this search function is there to use in situations such as this.
Hope this helps. Thanks for using FixYa.
Jan 09, 2010 | One For All URC-4330 Remote Control
Remote codes for sentry rmc10 really big universal remote
i need the codes for the Sentry Big universal remote for a philips magnavox or for someone to tell me how to do the code search
Jan 28, 2009 | Samsung DLP HL-P5663W 56" TV
Magnavox codes
Try holding down the the code search button until the LED lights.. Then push the TV button.. with the tv on Start pushing the power button at one second intervals until the tv turns off.. Then push the enter button. that should find the correct code.
Jul 18, 2008 | Philips Magnavox 27MS343S 27" TV
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
I need to program my remote to my tv
hit the stop button after it has found the code..
May 10, 2008 | RCA Universal Remote Control
Big button remote rcr 4258
does not have all the codes for every product,
Please give me the model # for the cable box -scientific Atlanta and the model # for Magnavox T.V.
also goto www.replacementremotes.com (336)969-1842
They will find you REPLACEMENT remote control CODES, not remote control
Apr 12, 2008 | RCA Universal Remote Control
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
Philips Magnavox Learning Universal Remote Logo
1,474 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
