Question about EnGenius EOC-3220 (EOC3220)
Am using a engenius 3610 ext. but i forgot about my password and i want to reset to default using the serial cable through the hyper terminal connection.but when i used the upper case like the M ,L ,W ITS GIVES ME FUNNY CHARACTERS
  • 481 Answers
Check your hyperterminal settings and make sure the communications settings are correct: baud rate 57600, 8 bits, no parity, 1 stop bit, no flow control. telnet terminal ID ANSIW. The full directions are here:
http://www.engeniustech.com/datacom/support/general-details.aspx?id=109
If this doesn't work, and it doesn't work from a different computer either, then I would suspect your USB/Serial cable or your radio unit itself.
Posted on Jul 13, 2010
Forget Password and admin, when I login on website
If you reset your router normally by holding in the reset button for 10sec , it will go back to the default password and admin . Sometimes the default password and admin is stored at the bottom of the router. the username and password for this model is admin
i have supplied you the manual for this model below:
http://www.engeniustech.com/resources/ESR-1221_EXT_User_Manual.pdf
May 09, 2011 | EnGenius ESR-1221 EXT Router
ACER default password for Bios
By default Acer wont enter any BIOS password however, if you have forgot BIOS password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battrey, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
Thanks and regards,
Jitha
Nov 24, 2010 | Acer Aspire 5920-6423 Notebook
How can i communicate from my pc to the ups on the 9 pin serial connection
Taken from the MGE UPS SYSTEMS, Network Management Card Installation manual (34003641EN/AD)
Run Hyper Terminal on a PC running Windows (9x, Me, NT4.0, 2000 or
higher).
Connect the card to the PC using the cable supplied.
Set up the terminal with the following communication parameters:
9600 bauds. 8 data bits.
1 stop bit. no parity.
no flow control.
ASCII: "echo typed characters locally" option disabled.
Press the Carriage return key. The configuration menu is displayed.
Enter the password (MGEUPS by default).
The main menu is displayed.
Select one of the items in the configuration menu.
Via the serial link or Telnet
Select the "Agent configuration" command by entering 1.
Select the item numbers and modify all the IP parameters (address, mask, gateway).
Once all the modifications have been made, exit following the instructions on the screen.
Restarting the card Via the serial link or Telnet
Select the "Restart agent" command by entering 6.
Then follow the instructions on the screen.
Restoring the default parameters Via Telnet or Hyper Terminal
Select the "Reset configuration to default" command by entering 5.
Nov 05, 2010 | MGE UPS Galaxy 3000 UPS System
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
How do I get into my engenuis eco-3220? Someone messed with the ip address and I cant figure it out at all...or it will let me ping then not let me ping...going crazy
There is no reset button on this model. To forcibly regain control of the configuration, you need a USB to serial cable, possibly a null modem adapter (depending on the serial cable), and a serial communication program like HyperTerminal or ZTerm for the Mac.
The manufacturer has incomprehensibly removed the detailed reset instructions from their website, but they can be found here:
http://www.keenansystems.com/engenius__senao_wifi_faq.htm
Look for the section titled "How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? "
Aug 30, 2010 | EnGenius EOC-3220 (EOC3220)
My Engenius access point is having problem wth the resettings. when i reset it, it fail to recongnise the default user name and password, but it recognises the default IP address
Assuming you are using the proper serial channel reset procedure, this should not be occurring. If it is occurring, your unit is probably malfunctioning and cannot be corrected.
Aug 05, 2010 | EnGenius EOC-3220 (EOC3220)
I forgot ip address of my EOC 8610. how do i
Try address 192.168.1.1 in most cases this is default IP for the routers.
Sep 23, 2009 | EnGenius / EOC-8610 EXT / 54Mbps /...
Restoring engenius EOC 8610 to factory default
Resetting the older beige Engenius radios requires a screwdriver and a USB-to-serial cable. You must unscrew the small plate at the bottom, which covers a serial connector. Plug the serial cable into it and then into your computer. Follow these instructions to perform the reset:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
Mar 31, 2009 | EnGenius / EOC-8610 EXT / 54Mbps /...
Resetting EnGenius EOC 3610
Dear Venmattey,
please follow these steps, it works:
1. Connect the EOC-3610 to your computer with a null modem serial cable.
2.Start a HyperTerminal session: Click Start and then select Programs-> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3610.
b. Select correct COM port. Ex:COM1.
c.Set baud rate as "38400", data bits "8", parity "none", stop bits "1",and flow control as "None". Then press “OK” to bring up theHyperTerminal window.
d. Unplug the power on the POE injector and wait 5 seconds then plug the power back in.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
NEW: Keenan Systems has written a software that will soft reset the 3610 series back to factory reset. Thisfree software is provided "AS IS" by Keenan Systems and is notsupported or guaranteed by EnGenius Technologies. Use at your own risk.
Be Happy Always
Regards
Dec 03, 2008 | EnGenius Computers & Internet
192.168.1.1 unreachable
you can use the "ifconfig -a" to see the ip addresses of all network adapters. but i'm wondering what happened to the user interface that showed a list of options to choose from.
Mar 15, 2008 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-3220 (EOC3220) Logo
573 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
jgbyers1
Level 1 Expert
Tech support
Tech support
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
