Question about Hotpoint Washing Machines
Says F5 on display, wont empty. - Hotpoint Washing Machines
Just had F5 blockage warning on hotpoint aqualtis. Removed front panel on the bottom and unscrewed filter, cleaned and replaced. checked all outlet pipe was clear. Laid washing machine on to its back and removed black pipe from pump and checked and finally removed the other end of the pipe that joins to the drum. large ball acts a valve and a missing sock was found in the drum end! replaced all parts and washing machine works a treat! before the f5 warning the machine leaked from the door on a couple of occasions, no problem since and may have been a build up of water finding its only way out.
Posted on Aug 23, 2010
Thanks to the first solution stopped panic after seeing F5 fault, opened the filter and found a part of the shirt collar plastic film blocking the pump.
Posted on Nov 02, 2012
Also if your machine is newly fitted and the waste pipe on your walll is not high enough it will cause the same probleb as the pump will fail to form a syphon. Probably worh checking. Minimum height is usually mentioned in theinstruction manual.
Posted on Jun 09, 2012
How do i fix a split screen of my Toshiba c600d-t36b laptop
The quickest way to change the display output settings is to use the
display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order
(the last two options are available if an external monitor is
connected):
? Built-in display only
? Built-in display and external monitor (simultaneously)
? External monitor only
? Built-in display and TV (or other external video device)
? TV (or other external video device)
? External monitor and TV
? Built-in display and external monitor (extended mode)
? Built-in display and TV (extended mode)
? External monitor and TV (extended mode)
? Swap-Switch primary display between internal display
and external monitor when using extended desktop
Feb 12, 2015 | Toshiba Computers & Internet
Why vga fails to display when you connect t acomputer?
Display is working on internal monitor of laptop?
Then the problem is;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the SAME time tap once on the Display Toggle-Over key.
Which key is that? Dunno.
Laptop manufacturer name, and model number was not stated.
Model number is on the Bottom of the laptop.
It will be one of the F keys at the Top.
F1 through F12
GENERALLY it's;
F4 for HP or Compaq
F5 for Acer
F5 for Toshiba
F8 for Lenovo/IBM
Usually has a monitor icon on the F key, (Looks like an empty rectangle, with rounded corners); and an arrow off to one side.
Still no?
Hold the Fn key down again, and tap once more on the Display Toggle-Over key.
Post back in a Comment
Regards,
joecoolvette
May 02, 2013 | Computers & Internet
F5 fault code
    • F05 - Pressure switch jammed on full
Nov 27, 2011 | Hotpoint Washing Machines
Machine goes through the wash cycle then stops before it rinses and spins . Machine displays F1 OR F5 which indicates an error has occured , have to empty manually but cant get it to spin at all .....
Hello
F1 is usually a low water code.Check your hoses and water supply inlet screen for any bulid up of dirt or sediment.
Also the water inlet valve may need to be replaced.
F5 is a water temp fault.Possible bad heating element or thermostat.
The F1 code could be causing the F5.
Due to low water.
May 04, 2011 | Indesit Washing Machines
I have a hotpoint aquarius wmf740 that is showing a fault f--5 and wont empty out the water
Something wrong the pump would prevent the machine draining and generate an F5 code.
http://appliancejunk.com/ge/washer/31-9103.pdf
Service manual above.
Jun 25, 2010 | Washing Machines
Oven wont come on -I get E1 F5 on display.
Self clean latch will not lock
If door not latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Jul 04, 2009 | Whirlpool Ovens
I have pressed Fn and F5 on my easynote laptop now the LCD screen has gone wierd. How do I reverse this?
fn + F5 changes output mode
its 3 way toggle switch
1. laptop screen only
2. secondary display unit only\
3. mirror on both display units
press Fn+f5 keys again to revert to normal mode
Apr 04, 2009 | Computers & Internet
Computer turns on w power but monitor wont turn on
Try circling through displays Use FN + F5 as per user MANUAL INSTRUCTION ON PAGE 5-4
"Pressing FN + F5 changes the active display"
Jan 24, 2009 | Toshiba Satellite A305-S6853 Notebook
Fn F5 key in my Travelmate2310 stopped working
Was Fn+F5 working before? Why do you 'have to use with external display", because LCD no display any more or...?
If non above, you better check from BIOS and chang display to Both LCD and VGA.
If Fn+F5 was working before but not now, could be something else wrong... I need know more details....
Nov 12, 2008 | Acer TravelMate 2300 Notebook
Washing Machines Logo
3,211 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
