Question about Ace Hardware Air Tools & Compressors
Keypad not working - Ace Hardware Air Tools & Compressors
  • 384 Answers
Dear sir
if your air compressor,s key pad is not working then open that key pad box(microcontroller box) and check connecting cable and find any visable fault may be that cable have looseness if it,s loose then make it reconnect and check its if not then try to check its electronics components .and contect to your service provider. hope the question,s answer
thank you
Posted on Jul 12, 2010
Micromax M2 keypad not working
Your Phone Keypad Ic Deafult So Please Change keypad Ic
and keypad Problem Will Solved
Jul 24, 2012 | Cell Phones
My craftman 139.52606 opener does not have a learn button to set pin on keypad. I had keypad working at one time but since I changed the battery I can't rember how to reset the keypad.I also changed...
If the keypad is hardwired, do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
Needed and put in a new 9V battery in my keypad. The keypad now does not work. Do not see keypad light up when pressed, ???
Sounds like you may have a bad battery if the keypad was working before you replaced it. If the keypad did not work I would suspect it has failed.
Dec 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
Maxx 463 keypad not working
maxx 463 keypad not working plz help me.
Sep 04, 2010 | Health & Beauty
Micromax q3's keypad is not working
Aug 01, 2010 | Cell Phones
Can only program one remote or keypad. which ever
You are going to have to do a process of elimination. I think you have either a bad remote or a bad keypad. Try programming a remote and then the keypad. If only one works then go with the other remote and the keypad. If only one works then program the two remotes. If the two remotes work then the keypad is bad or if you can program one remote and the keypad then the other remote is bad. Get rid of the bad one.
Oct 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Nokia 5200 (Number keypads) will Not Working
u need to change the key pad until then it wont work.
two keypad IC's under the keypad and next to the keypad connector unfortunately all the keypad points are linked to the IC's and so even if one key doesn't work it is related to these IC"s in question UNLESS the keypad connector is dirty or sticky please do service your phone or take it to a reliable technician
Jul 01, 2009 | Nokia 5200 Cellular Phone
Keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Keypad doesn't work
good morning ! the problem of your 6233 nokia is keypad main brain or keypad crystal ic ,,,,try to clean the keypad mainbrain or replace the keypad ic ! thanks ! good luck ! ......
Sep 07, 2008 | Nokia 6233 Cellular Phone
Air Tools & Compressors Logo
35 people viewed this question
Top Ace Hardware Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Ace Hardware Air Tool and Compressor Expert? Answer questions, earn points and help others
