Question about Karcher K2.26 Electric Power Washer
Pulsing when idle and when operating - Karcher K2.26 Electric Power Washer
    Problem Solver:
  • 15 Answers
I have the same Problem, there is a leak at a seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement K2.26* Part # 97501760 is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and if you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
Posted on Jul 13, 2010
93 isuzu pickup pulsing idle.
if u undo 2 bolts that hold ur distributor on alittle then ur can turn dizzy clock wise or anti clock wise to get it ideling higher or lower
May 18, 2013 | Cars & Trucks
jis common for the computer not to jive with new motor--may have to reprogram it--running a data stream with factory gear can confirm--or send issue to magicmechanic online
Idle air notfunctioning Rough idle in mornings idles up then down pulsing idle 2003 Jeep laredo .
check for vacuum leaks and make sure throtlebody plate is clean, use throtlebody cleaner and an old tooth brush to clean, if problem is still there then replace the valve (idle air control valve ).
Jan 10, 2010 | 2003 Jeep Grand Cherokee
Temp guage inside truck pulses..and outside temp is going crazy...truck is idleing up and down at idle
For the pulsing temp gauge: Check Coolant Temperature Sensor located near the Thermostat.
After this is change - recheck idle.
If still rough on idle, check the Idle Sensor.
Jan 08, 2010 | 2000 Dodge Ram 3500
HONDA CIVIC 1996 PULSING IDLE
It might be bad gas or a plugged filter or it might be a bad mass airflow sensor.
May 03, 2009 | 1996 Honda Civic
Pulsing in idle while in park only
No its not ur pcv or ur vacuum.
There is a little sensor on the bottom of your throttlebody called ISC
They almost always go bad in these cars.
You can find ones that are good used at mitsubishigraveyard.com
they also can explain to you how to test the ISC.
Apr 22, 2009 | 1991 Eagle Talon
Karcher K2.26 Electric Power Washer Logo
487 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
