Question about Fisher and Paykel Washing Machines
No power lights
No power light on a fisher and paykel 608 washer. Stopped during water filling. Wall switch OK. No lights at all on the washer
  • Fisher and P... Master
  • 713 Answers
Hi Rob just found your posting.Do you still require help?Now the main reason your machine will not light up is your motor controller is faulty.Please reply if you still need help and I will help you rectify this problem.
Posted on Jul 15, 2010
  • rob_wheeler Jul 18, 2010
    i had to purchase a new machine but would be keen to get faulty machine working if possible. I have an electrical circuit tester if you can advise on what to test
Fisher paykel gwl15 squeal while filling
1. Does the squeal go away if you choose a different temperature, eg, a hot wash?
2. Check the strainers/filters where the inlet hoses screw onto the washer:
- turn off water at the wall.
- start a warm wash to release pressure from hoses, then switch off machine.
- remove inlet hoses and inspect for blockage/debris. Then, place hoses directly into where the clothes go then carefully turn the water back on at the wall to check flow.
- Also check strainers/filters at other ends of hoses.
3. If all seems OK, new water valve(s) may be required. The rubber in the water valves can harden over time.
Aug 09, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel smart drive 608 6.5 kgs has running well for ages but recently while finishing water filling it makes a warning beep sound and start leaking from the bottom,anyone there to help me pls
Hi just read your post.Now when the machine beeps a series of lights will light up on the wash progress lights. The spin light is number 8 and the other end of the lights is number 1 which is long wash, i think. Starting from the long wash light which is number 1, which lights are on when the machine is beeping, is it 1,4 and 7 or 3, 7 and 8 etc? Please reply with the answer to this question and i am sure i can help you. Regards Lu
Jan 25, 2014 | Fisher and Paykel Fisher & Paykel Washer
Gw612 error code lights
the motor controller needs replacing. this fault is not servicable at home.
Sep 07, 2013 | Fisher and Paykel Fisher & Paykel Washer
My fisher and paykel gw708u is intermitantly filling then goes into alarm and stops
Your rotor position sensor could be faulty,
your error code should be on the wash cycle progress lights.
Nov 18, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel washer GW703 only letting water in spurts. takes forever to fill.
Hi just read your posting. Sounds like you have an out of balance switch problem.This is the most likely cause on the information you have posted. 80% of the time it is the switch and about 20% of the time it is the rotor sensor which is attached to the motor.Just a question or two. Does your machine stop during filling and light up a series of lights and it starts to beep.If it does ,from left to right is it the 3rd and 6th or 1st and 7th etc please reply and I can guide you throe what action needs to be taken.
Jun 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
POWER UNIT IS NOT WORKING
sounds like the motor controller is faulty.if u have power to unit and the lights aren't on then it is either faulty controller, or faulty pump or best case broken power wire.please turn power off b4 u work on it. dont want any accidents. please reply 4 more help.
Apr 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
HI. I have an old F&P Smartdrive 085 and I am looking for the reset button on it. It was not completing the cycle and wouldn't turn off so I turned it off at the wall, waited for a while and turned it...
sounds like your motor controller is faulty.the sharp click u heard was the fuse on electronic board popping. unfortunetly there is no reset button. u might need a new controller.if u r not comfortable working with electronics it would b best to ring a repairer in your area. please reply 4 more help
Mar 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
The machine does not work
Ok this fault is telling me you have a faulty RPS(Rotor Positioning Sensor) in this machine. The RPS sensor is located in the motor Stator. To replace you need to remove the motor rotor then the motor Stator. you want to be careful with this part when fitting it as they can break.
Please rate my advice.
Cheers
Steve
Mar 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
144 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
