Question about HP LaserJet 3050 All-In-One Printer
Using XP printing command very slow reponsed - HP LaserJet 3050 All-In-One Printer
  • 223 Answers
It could be an effect of the network spooler, if you are connected through usb make sure the printer is connected through a usb2 port. If networked try printing directly to the printer. Go to your printers folder and right click on the icon, select properties, go to the advanced tab and select print directly to the printer, also under printing preferences, under the advanced tabs, under printer features change raster compression : MAX COMPRESSION
and print data optimization : OPTIMIZE FOR TEXT AND VECTOR.
Al
Eliteprintersolutions@gmail.com
Posted on Jul 14, 2010
Canon mx922 not printing word document from PC. Puts it into queue
How To Fix It - The fix is simple. You need to clear the print queue manually so that all the print jobs currently in the queue are deleted properly - once the queue is empty you should then be able to print new documents without problems. We will show you how below, depending on whether you use XP or Vista/7:
1. XP - click 'Start' then click 'Run' and in the Run window type CMD then press 'OK' - this opens a Command Prompt window. Now skip to Step 3.
2. Vista/7 - click 'Start' and type Command in the search box. Right click on the 'Command Prompt' result in the search results above it and select 'Run As Administrator' - this opens a Command Prompt window.
3. All version of Windows - in the Command Prompt window (these commands are also shown in the picture below):
4. Type net stop spooler then press the Enter key.
5. Type del %windir%\system32\spool\printers\*.* /q then press the Enter key (Note: the only spaces in this command are a single space between del and %, and a single space between * and /q)
6. Type net start spooler then press the Enter key.
7. Type exit then press the Enter key to exit the Command Prompt window.
Fixing the print queue
This should have cleared the print queue (i.e. all print jobs have been deleted) and you can now submit new jobs for printing
What Do These Commands Do?
The Command Prompt is a throwback to the pre-Windows days of Microsoft DOS but is still a useful way to type and enter system commands. The print Spooler is basically the print 'queue' - we need to Stop it running before we can Delete documents stuck in it.
The Del command deletes everything currently held in the print queue, including the 'stuck' document(s). We then have to Start the Spooler (print queue) up again so that it can accept new print job requests in future.
What If It Keeps Happening?
If the problem only occurs occasionally it is likely just due to an incompatibility with the actual data being printed ( a webpage that has unusual fonts or some other format that the printer is unable to convert into printed output - run the above fix to resolve it.)
However, if you find that almost all documents keep getting stuck in the print queue then Microsoft's answer is that it is an issue with your printer drivers (software) - one solution may be to download and update new printer drivers from the manufacturer. You could also try the Microsoft automatic Fix It for printers . This will repeat our fix above but may also flag up/fix any different Windows errors that stop printing.
Other causes may include a misconfigured printer e.g. network printing to an IP address that doesn't exist uninstalling and reinstalling the printer software from scratch should fix this.
Aug 19, 2017 | Canon Office Equipment & Supplies
Printing is very slow
try to align the cartridges and try to print
Dec 07, 2013 | HP DeskJet 5550 InkJet Printer
I have sumsang SCX3200 & I want to print my some Document & figer frm dos mod. Windows Xp is runing on my desktop pc
DOS applications cannot print on USB ports, but there's a workaround by using a share and the NET USE command, first create a share of that printer check this site: http://compnetworking.about.com/od/windowsnetworking/ht/printer-sharing.htm, (take note of the name you gave the shared printer) than you use NET USE command to connect the shared printer to a virtual port (LPT2) first click on START, than RUN, than type CMD than hit enter, type the following command " net use lpt2: \\127.0.0.1\(shared printer name) /yes " than hit enter, if you have a " command completed successfully " than you have your shared printer connected to a virtual port (LPT2) now it is just a matter of setting your DOS software to print to LPT2... and VOILA! it prints...
Jun 25, 2011 | Office Equipment & Supplies
BONSOIR J AI UNE ONE FOR ALL URC - 7530 ET JE VOUDRAIS LE CODE A IMPUTER POUR COMMANDER UNE TV THOMSON MERCI BEAUCOUP
Essayez les codes prochaines pour votre machine:
10625
10560
10343
10287
10109
10335
10037
10556
10349
10216
Bonne chance.
Si cette reponse est bonne, SVP click sur l'image des 4 Pouces Vers Le Haut qui signifi que cette reponse vous a aider.
Merci beaucoup.
Joe.
Mar 09, 2011 | Televison & Video
Canon f80 multipass New five years ago never
Are you using Windows Vista or Windows 7? If so, the driver download page at Canon does not provide drivers beyond XP. Otherwise, go back to the XP (or earlier versions) driver downlaod site and download the MultiPASS F80 Software User's Guide. That may provide the answer to your problem. Also, if you are using unpopular, proprietary software programs the driver may not recognize the commands. Good Luck!
Apr 26, 2010 | Canon MultiPASS F80 All-In-One InkJet...
The printer is taking to long to print....
1) may be your print spooler is full
to set it right kindly do this:
click start and then go to run type cmd.in vist asearch for command prompt.
Opens a Command Prompt window is open.
key the command
sc config spooler depend= RPCSS
note :THIS COMAND IS CASE SENSITIVE so type it exactly as shown and there is a space between rpcss and the = and there is no space between depend and =
restart your computer
open a Command Prompt window again.key the commands
net start spooler
note this command is also case sensitive.
__________________
thsi should resolve ur issue
if this does not kindly upgrade the ram of your computer.
that means u ned to buy more memory for ur computer.
it was supporting printer earlier but after printer has started working its getting more load thts why prnter now isslow.
its like a small kid inicilly may like the school but after few days kid gets burdon n gets slow n less excited.
if u have HP printer
u can also visit
http://welcome.hp.com/country/us/en/support.html
although i hav worked as tech support fr 2 years for DELL and 1 year for HP all in one printers. i am sure my steps will help u
rate me 100% when u issue gets fixed ;)
May 17, 2009 | HP DeskJet F380 All-In-One Printer
Windows XP Locks Up
Your power supply might be almost dying.
May 05, 2009 | Dell Dimension 8400 PC Desktop
Printing initiation is very slow.
what drivers are you using on each partition - what version of xp is on each partition and if you restart the print spooler on both of them does that help ?
Also why have you got 2 installations of xp on one computer using 2 filing systems ?
Apr 14, 2009 | Computers & Internet
DP-303
Perhaps the XP firewall software is preventing PS Admin from connecting to the print server?
Jan 16, 2008 | D-Link DP 303 (DP-303) Print Server
Deskjet 940C slow to respond to print commands
first if you are using the printer conector istead of USB cable that is one reason the second one is the setings for your printer you can go to the printer properties click on advance check to start printing imediatelly and thats it
Nov 07, 2007 | HP DeskJet 940c InkJet Printer
HP LaserJet 3050 All-In-One Printer Logo
146 people viewed this question
Seeker5211
Seeker5211
