Question about Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop
My computer has started to make a ticking noise if 3 second intervals for about a minute, then it can go for long periods without noise. i tried dell diagnostics - nothing
  • 1 more comment
  • joecoolvette
    joecoolvette Jul 12, 2010
    Is the computer dirty inside? Have you checked to see whether the Processor fan power cable from the motherboard, is occasionally being drawn into the fan? Making the occasional ticking sound?
  • john35655 Jul 12, 2010
    it is not that when it is ticking it stops the other programmes woking
  • joecoolvette
    Is this in direct reference to a Dell Inspiron 531 desktop computer? If so, does it have the optional Floppy Disk drive, and if this holds true, is there a Floppy Disk in said drive? Again if there is a Floppy Disk drive, and no disk present in the drive, remove the power cable to the drive. See if the ticking persists. If there is no Floppy Disk drive, AND if the unplugging of the power cable to it does no good, then the problem is the harddrive. Your harddrive is starting to fail. Suggest you copy all personal information off of the harddrive to disks, or thumbdrives 'Toot Suite'! Your harddrive is starting the 'Click of Death'.http://www.youtube.com/watch?v=vbq8vfs1w...
  • 487 Answers
Hi, sounds like your hard drive working, do a scan for any bugs. Hope this helps
Posted on Jul 12, 2010
How do i fix my 2001 740i bmw it makes a ticking sound win idleing
could possibly be a lifter tapping (Ticking) ,depending on how many miles the vehicle has on it might be time for lifters to be adjusted,most foreign overhead cam engines must have lifters adjuster periodically ,if you turn on the air its puts more of a load on the engine causing a louder sound (also check oil level an engine low on oil will start to tick too.. the more wear the engine gets the looser the lifters can get over time ,look in your service manual if you have one and see what the intervals are on lifter adjustment this can give you an idea.
possible only if
the ticking sound is coming from the top of the engine usually comes from under the vavle covers where the lifters are located,
Aug 19, 2015 | BMW Cars & Trucks
A ticking sound on a 06 ford f150 super crew 5.4L
Ticking sound could be coming from a Coil-on-Plug, or a pcv valve, or (hope it's not) a valve lifter which could be sticking. Sticking lifter noise often disappears when rpm's change, or the noise comes & goes. try changing the motor oil & filter right after adding an Engine-Flush Treatment to the motor oil, running the engine for 10 minutes at idle with treatment added to the oil, then draining the oil & changing filter while oil is still very hot. That last part is very important, so be careful not to burn your hands - be careful. -- The sticking lifter is a likely cause if motor oil has not been changed at frequent intervals in the past (every 3-4K miles) -- dirty oil causes sticking lifters.
Aug 10, 2012 | Ford Cars & Trucks
My Maxtor external hdd switches on, tries to start (spins etc) then switches off within a few seconds
Does the noise sound like a clicking noise at regular intervals?
If so, I'm afraid it sounds like the hard drive is dead and needs to be replaced.
May 20, 2012 | Maxtor Computers & Internet
2006 mazda 6 2.3 65,000 miles. It started making a very, very loud ticking / knocking noise at all times following the rpms. The valve clearences are within spec, but that's all i've checked. ...
Mobil oil won`t cause this problem however if the mechanical parts have just succumbed to metal fatigue or defect.the noise could be rocker arms,connecting rod noise or a failed piston.its hard to say without hearing the noise as it is to try and describe the noise.
Jul 06, 2011 | Mazda MAZDA6 Cars & Trucks
Ticking noise
Maybe a dry u-joint, or one on it's way out.
Apr 24, 2009 | 2005 Chevrolet Silverado
Dell Dimension 8400 won't boot, cpu fan running like a jet engine
don't worry pal just follow the steps (according to my expeience)
1) turn your computer on.
2) when it is being started keep pressing both DELETE keys (one of Num keys and other one.) without any interval.
3)there will be a set up menu
4)find the boot option and enable it (all option)
i do it on my PC like this only
Jan 12, 2009 | Dell DimensionTM 8400 PC Desktop
Danby Air Conditioner
I have the same problem with my Danby AC unit...every 5-20 seconds it makes a god awful clicking noise...Make me wanna cry
Jul 09, 2008 | Danby DPAC8020 Air Conditioner
Ticking noise
It is part of the waste gate just above the gas tank. It periodically checks for leaks and pressurizes and releases. Gives a ticking noise when it does this. Not a problem and GM is aware of this and said its normal on our cars.
Jun 02, 2008 | 2007 Chevrolet Cobalt Coupe
Ticking/chirping sound during slow spin
it will more than likely be a bra wire stuck between inner and outer drum it will only sound when clothing is in it due to the weight of clothing and water so it wont be heard with just water init or by pushing it around by hand only thing u can really do is eiether strip it yourself or by getting an engineer in but what i would do is leave it after a while it will dislodge itself and go into the pipe underneath the washer in the pipe that is in the middle of the drum check this when the sound stops love
Aug 22, 2007 | Bosch WFMC 3200 Front Load Washer
Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop Logo
138 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
