Question about Lexmark X2500 All-In-One Printer
Printer when trying to scan I get a message saying my display setting is to low it should be 800x600 and the color should be 256. How do I change this ?
  • 487 Answers
If you are using windows XP
follow following instructions.
start
control panel
(make sure you are not on classic view)
appearance and themes
screen resolutions
left on botom put screen resolution on 800X600 or highre if your computer can handle it and color to highest
This should fix the problem.
Please rate this if this corrects your problem. Otherwis come back to me
Posted on Apr 20, 2008
Mf toolbox requires at least 800x600 256 color display?
If you're using Surface Pro 3 that switches between landscape or portrait modes, ensure your display setting is in landscape mode in order for mf toolbox to run.
Feb 07, 2014 | Canon ImageCLASS MF4350d Laser All-in-One ...
I cannot install adobe pagemaker 7.0
Did you see the system requirements? Here's it - try to see if its fit to your system For
Windows
  • Intel® Pentium® processor
  • Microsoft® Windows NT® 4.0 with Service Pack 6, Windows® 2000 Professional with Service Pack 2, Windows XP Professional or Home Edition
  • 32MB of available RAM (48MB or more recommended)
  • 175MB of available hard-disk space for installation (200MB or more recommended)
  • Video card with 800x600 resolution and 8-bit/256 colors (24-bit, high-resolution display recommended)
  • CD-ROM drive
  • For Adobe® PostScript® printers: Adobe PostScript Level 2 or later
for Macintosh
  • PowerPC® processor
  • Mac OS 9.1 or Mac OS X (Classic mode only)
  • 30MB of available RAM (45MB recommended)
  • 150MB of available hard-disk space for installation (200MB recommended)
  • 800x600 monitor resolution with 8-bit/256 colors (24-bit, high-resolution screen display recommended)
  • CD-ROM drive
  • For Adobe PostScript printers: Adobe PostScript Level 2 or later
If you think your computer system got all of the above requirements, Perhaps there's a problem of your computer Operating System. Try reformatting it.
May 18, 2011 | Adobe PageMaker 7.0 for PC
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
Printer was installed but does not operate..gives a message that the program cannot run with your current display settings at least 800x600 at least 256 colors. I have tried to adjust the display...
Try going to manufactures website and updating your drivers. Look for newest driver and also check if it's compatible with Windows 7. This should help you with an issue. Good Luck
Apr 28, 2010 | Lexmark X4875 InkJet Printer
Wont let me connect it says display setting to 16-bit,800x600 resolution or higher
That refers to the PC's display settings. Use the Control Panel to set the display settings as suggested; 800x600 pixils, with 16 bits of color or higher.
Jan 25, 2010 | ION Audio VCR 2 PC USB VHS Video to...
Screeen Resolution too low
600x800 for printer.
go to control panel display properties settings tab
click on advanced. click on monitor tab and uncheck hide monitors
uncheck hide modes
click ok. change resolution to 800x600.
Nov 25, 2009 | HP Mini 1000 Netbook
Scannig
that's on your display settings for your monitor..assuming you are on xp, go to start, settings/control panel/display settings/settings, and make adjustments there..
Apr 19, 2008 | Lexmark X2500 All-In-One Printer
Trying to scan and I get message saying to change display setting to 800x600. How do I do this?
Right click on your desktop, go to properties. On display property click on settings then change the screen resolution to 800x600. hope that help get back to me if that error persist.
Apr 19, 2008 | Office Equipment & Supplies
I need technical support
You need to try what it says try lowering the or color depth try 1024 X768 256 colors if that doesn't work try 800 X 640 256 colors Right Mouse click on the desktop where a Icon isn't go down to properties regular click go to settings change the screen resolution and color depth and color quality to above suggestions apply changes try your movie
Johnlgrn
Dec 27, 2007 | Computers & Internet
Lexmark X2500 All-In-One Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
