Question about Refrigerators
The Freezer keeps freezing up right around the blower so no cold air can get down to the refrigerator. The freezer works but not able to use refrigerator.
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
There is a very remote possibility that nothing has gone bad.. Sometimes the freezer drain gets clogged and the unit just continues to build ice. However.. most of the time there is an automatic defrost circuit problem that because it does not defrost automatically the ice builds up.
The problem can be caused by several components:
1. The defrost control
2. 60 deg bi-metal thermostat is open
3. Defrost heater has burned out.
4. Broke or heated / burned wire / terminal
5. Evaporator fan is not running full speed.
If you pass your make and model number, I can help you isolate the problem if your able to use a meter and do some basic mechanical work.
What you can for the moment is do a manual defrost... This makes a mess so be ready with the mop and rags. Here goes:
Manual defrosting the easy way.
UNPLUG THE UNIT
1. Remove the contents of the freezer compartment.
2. Block open the door.
3. Place a ;fan blowing into the freezer compartment for a little over 2 hours... (Messy part)
4. After the 2 hours and mess tending your manual defrosting is complete.
5. Reload the freezer and plug the unit back in.
6. Check temps in 4 - 6 hours.
You will need to go through this routine every 2 to 3 days... if you want your unit to keep the correct temps until the automatic defrosting problem is corrected.
Thanks for using FixYa.
Kelly
Posted on Jul 12, 2010
Why is the refrigerator side is freezing food
First some fridge 101, the refrigerator/freezer models cool by directly refrigerating the freezer section and the refrigerator section is cooled when "some" of the cold air from the freezer is directed over to the refrigerator side (typically by a fan) to keep food fresh and not frozen a temperature controlling damper opens and closes to regulate the temperature of the fridge by introducing more or below freezing air into the cabinet. In older models where the freezer was on top the air simply "gravity" drained into the refrigerator cabinet, if the food was too cold you turned the fridge knob up and less air sank from the freezer to the fridge, simple but effective.
When you adjust the temperature level it controls the freezer temperature and this turns the compressor on and off to keep the food frozen. There is typically a knob or lever and some even have electric dampers that open and close to direct more or less air from the freezer and direct it to the refrigerator cabinet based on your temperature requirements.
Now that you know how it works there are a couple things to check. If the condenser coil is plugged with dust the internal system pressure will rise and in some cases make the fridge an over achiever and can chill too much so check/clean the condenser coil. Check the freezer temperature control and turn in up, also make sure the fridge temperature control setting is not set too cold.
Finally as the temperature changes around the refrigerator it will have an effect on the inside of the fridge too so expect to turn it up and down as the environment changes, down in the summer and up in the winter.
Hope the novel helps to resolve your issues.
Nov 01, 2017 | Refrigerators
The botton drawers are freezing the friut.
Is it a freezer on bottom unit? If so, it's because the fridge part of a refrigerator, doesnt actually cool anything, it uses the cold air from the freezer. I'm assuming the vent from the freezer is right behind the fruit drawer? Try turning the fridge temp. down a little, or unfortunately don't keep anything in that drawer?
Mar 14, 2012 | GE Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
My KitchenAid Subra fridge. it seems like the freezer is always producing cold air. It keeps the freezer so cold that it freezes the drain plug were the condensation is suppose to drain out of the freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 23, 2011 | KitchenAid Refrigerators
Reefer is working o.k. Freezer is not working. Blower in freezer is working
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
I hope the above helps.
Take care.
Mar 22, 2011 | Refrigerators
Coil is freezing up
two options...one drain hole blocked in freezer,clean with copper wire/bleach to clear gunge.
two outside temp too cold i.e. unit in garage/outhouse( too cold for compressor )
also check seal to doors.air leaks...
Feb 06, 2010 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Freezer not blowing air - bad smell in fridge
Your automatic defroster coil is open and needs to be replaced along with the fan in the freezer that blows the cold air around and also blows air into refrigerator.
Bad smell down below is food rotting in that section because it is not cold enough.
Mar 22, 2017 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
