Question about Electrolux Ovens
Eog 6330 oven door does not fully close ie small gap at top unless you hold door closed are hinges damaged or bent?
I have a problem with my Electrolux EOG 6330 Oven door not closing fully so letting valuable heat loss to occur. I notice on here it seems like a common problem. How do I get it to close shut properly?
Posted on Feb 20, 2011
  • farhat_nadim
    farhat_nadim Sep 13, 2012
    I have a problem with my Electrolux EOG 6330 Oven door not closing fully same as chrissy, I checked the hinges they seems fine and strong could it be something else. thank you
  • Brad
    Brad Dec 13, 2013
    I bought a new inner door with hinges factory fitted already and the door is still the same, wont close properly??
    President:
  • 1,891 Answers
You will have to replace both left & right hinges / this should correct problem .. mm
Posted on Jul 16, 2010
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
Door will not close completely leaving 1cm gap at top.
If the door closes fine till that 1cm gap hinges more than likely wont solve it you need to replace the supports that the hinges slot into
Dec 13, 2013 | Electrolux EOG6330 Gas Single Oven
Hygena Select 620 Diplomat oven
The last person who used the oven door as a shelf to rest a heavy roast has bent the bracket the hinges go in to.
A piece of dowel (broomstick) cut to the width of the oven and placed as a fulcrum in the hinges, gentle pressure when almost closed can bend it back into position, but that wont last.
>> Replace front frame or retention brackets
Oct 16, 2013 | Ovens
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Oven door won't close fully.
The only satisfactory solution, is to replace both the oven door hinges,\ which is a fairly straightforward job to do.
Please rate my solution.
Thanks
Nov 09, 2009 | Bosch Ovens
Door will not close fully gap at sides and top akp 511
If it is a drop down door with rear hinges, then you need to replace both hinges.
Thanks.
Oct 28, 2009 | Whirlpool RBS275PD Electric Single Oven
Doors don't shut all the way and light stays on
It sounds like your door hinges are worn, usually on older ovens due to weight of door. Most oven doors can be removed by simply raising the tabs/ fitting small screwdriver on both hinges(refer to user manual) etc. Once door is removed you can place a medium size screwdriver or similar in the hinge slot, pushing the hinge plate on the bottom in an outward direction, thereby bending this plate(very slightly) forward. This will make the door close fully, activating the door switch, and turning off the oven light. This is only a short term solution, as this hot air escaping can lead to further problems. Hinge pair will need replacing. Door hinges are spring loaded ALWAYS KEEP FINGERS AND HANDS CLEAR OF LOADED HINGES.
Sep 18, 2009 | Jenn-Air JJW8230D Electric Double Oven
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Oct 20, 2008 | Neff U1661 Double circotherm super...
My oven doors wont close all the way
When the door came open you may have bent the hinges. Open the door fully and it should stop at 90 degrees. If lower than that, then the hinges are bent and will need replaced. Also you may look at the install directions and see if your model shows removing the door. If it is removable for install, you can try removing and reinstalling the door. It is possible with removable doors for them to slide up during install and then they are out of alignment for closing. Hope this helps.
Jan 04, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
1,230 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
