Question about Gaggia Paros Espresso Machine
Hello, i have a gaggia paros coffee machine and no water is coming through the brew head instead it is going back into the resevoir. Thanks.
    Problem Solver:
  • 5 Answers
This happened to mine. I think that it gets blocked with limescale. I solved this by running a solution of citric acid through the system (available in the baking aisle of the supermarket). To start with nothing came through, but I left it on and tried running water every 10 minutes and eventually it started to run again. NB it takes a long time to flush out all the citric acid, my first few coffees have a lemon flavour!
Posted on Sep 11, 2010
I need an instruction manual for a Gaggia Paros coffee machine
there is a parts diagram here... http://www.partsguru.com/user/Paros%20parts%20diagramER0043_01%20Rev01.pdf
May 20, 2010 | Gaggia Paros Espresso Machine
Have a Gaggia Cyncrony Compact Coffe Machine that doesn't brew!
Has the machine been de-scaled recently? I would run a descaling solution through the machine first to eliminate that.
Jan 15, 2010 | Gaggia Syncrony Compact Coffee...
The water coming out of the steam nozzle is clear but fromthe brew head it is milky looking. I have descaled
That's ok .
The water from the steam nozzle is straight from a boiler.
Where as the brew head is fed from another boiler via the brew unit,so you will still have some coffee in the system.
If you wanted to you can rinse the brew head by making preground coffee without coffee this will flush it clean.
Nov 28, 2009 | Gaggia Titanium Espresso Machine
Brand new Gaggia classic, no water coming through the brew head
take out screen and screen holder,and unscrew piece in head,clean with wire and try,i think its your head plugged out.
Aug 22, 2009 | Gaggia Classic Espresso Machine
Gaggia baby 18 momths old water coming through steam bit but no water coming through coffe bit any suggestions libby
HI
If you have a pre-grind button on your machine, push it but don't put any coffee in the brew unit. Push any of the coffee buttons, and see if water will come out then. If it does not, then you have a plugged brew unit and the brew head needs cleaning. I have directions for cleaning.
Jul 13, 2009 | Gaggia Syncrony Compact Coffee...
Water coming out of steam nozzle not coffee output when making coffee
Sounds to me there might be a blockage on the brew unit, and since the pressure is so high it is going through the bypass. Clean the screen and tubes on the brew unit.
May 12, 2009 | Gaggia Syncrony Compact Coffee...
Machine will not brew coffee instead hot water comes out of the steam nozzel
check brewunit is clean and clear of any blockages,if this does not help your outlet valve cursor may have melted,this is a common problem if are making mainly cappuchinos
Jan 03, 2007 | Gaggia Titanium Espresso Machine
Gaggia Paros Espresso Machine Logo
273 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
