Question about Navman F20 GPS Receiver
Navman F20 I have not used my gps system for a number of months.Now, when I turn it on it shows the battery, the charger shows a green light. The battery disappears off the screen and then nothing ???
  • lilsarndra Apr 20, 2008
    The picture of a battery disappears off the screen after approx.1 minute and then the screen remains blank. Very very faint I have seen the screen that shows charging but I'm not sure.
  • 3,037 Answers
If it won't charge there is probably a break in the cable - If you able to, try to locate the break and repair. you'll probably find it's at the usb plug end. Maybe easier just to replace it.
If this isn't it, then can you explain the "nothing" a little more, does the screen turn off or just freeze up or what?
Please let me know about this.
Thank you for using Fixya and have a Great Day!
Posted on Apr 20, 2008
  • Benjamin Patri
    Benjamin Patri Apr 20, 2008
    Try testing the brightness of the screen first and if it is able to go through from lightest to darkest ok, then most likely the battery has just gone bad. When the battery is displayed on the screen, what charge is it showing (full or half, etc.)
    Here are directions for testing the brightness and whether the screen is the problem
    To get to the test menus First
    Hold down Menu + Power Buttons for 10 seconds
    This will bring you to the -= Maintenance Menu =-
    From here you can use the + & - Sound Keys to move up and down the
    menus and the “Menu Key” to go forward and the ^ key to go back.
    Run a
    Self Test on the device and it should check if the screen is operating correctly.
    Please let me know how this goes and we can go from there.
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
  • 19,396 Answers
The battery drained off completely for a while probably it is damaged, you need a new battery
  • Ginko
    Ginko Apr 20, 2008
    Bring it back to the shop and buy a new battery, before buying the battery have it tested with a different charger, just in case.
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
Hi I have a navman f20 which shows a batterey with a x on the display then turns off I have allowed the unit to discharge fully when on recharge it shows the same display
The battery is defective or your charger is not working. Most likely it is the battery but the charger is a possible until checked. You may want to find a gps shop and find out if they can get a battery.You can also contact Navman and talk to support about sending it in to them for repair. The battery should be about $20 plus labour to install.
http://www.navman.com/
Sep 06, 2011 | Navman F20 GPS Receiver
My navman won't charge or turn on, any ideas?
screen shows computer to navman all the time
Jul 25, 2010 | Navman F20 GPS Receiver
Navman f20 will charge fron usb port on computer but not with in car charger
If it's not the original Navman usb loader then there's a easy solution to this : With a sharp knife carefully open the usb cable : you'll see four tiny cable's with different colours . You;ll have to cut two of those four cables ; Leave the black and red cable intact.
Use some tape to fix the cut in the usb cable. Now you can use your car charger and your navman won't go into usb mode.
Dec 08, 2009 | Navman F20 GPS Receiver
Will not charge, or turn on
Probably the plug on the navman has suffered what we call dry solder joints from inserting and pulling out the charger you need a tech to fix it. soldering is nesessary shouldnt be too expensive I fixed mine its about half an hours work if not too damaged inside
Feb 15, 2009 | Navman F20 GPS Receiver
Navman won!t charge from in car charger or mains adapter but will charge from garmin in car charger
Your Navman will not run in car unless the output on the charger is 1000ma or 1a. you need to buy a genuine charger, motorola phone chargers do not have the output to run the unit
Jul 22, 2008 | Navman F20 GPS Receiver
Navman f20
my navman f20 has lost its sound
Mar 09, 2008 | Navman F20 GPS Receiver
Battery Charging Navman S90i
The problem is that most of the chargers have the output of 5V/0.5A. The charger for NAVMAN (C30 in my case) has 5V/1A. And that is causing the trouble. The GPS is undercharged and is switching off itself. Buy one which specify the output power: 5V/1A. Hope I solved your problem
Feb 04, 2008 | Navman F20 GPS Receiver
Navman f20
this is because of high voltage in input AC power so u have to replace it
Nov 06, 2007 | Navman F20 GPS Receiver
Navman F20 GPS Receiver Logo
136 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
