Question about Car Audio & Video
Hi, My 2 yr old turned the lights on when I let him sit in the driver seat (he loves cars!) and I ended up with a flat battery - I thought I knew the code but it doesn't work so can anyone help? MOD-RENRDW100-10 TO1751 RNRD0130008874 PROD No FD0003030008874 BAR CODE No 8200247962TI751 Thanks in advance I hope!
  • Car Audio & ... Master
  • 4,915 Answers
Remove the radio from the dashboard
Then post the radio make+model plus all the letters+numbers on any labels, barcodes or stamped in the metal casing
Posted on Jul 12, 2010
2006 FLHX starts but will not keep running once I sit on the seat.
sounds like a wire has rubbed bare and any weight is grounding it, maybe around suspension parts or just under seat. Possible broke wire but not all way and insulation still intact.
Aug 27, 2014 | 2006 Harley Davidson FLHX Street Glide
Ok so I have a 4 1/2 yr. old male pit. He's
Since when has a pitbull been a car or a truck?
Apr 10, 2013 | Cars & Trucks
Wont turn on
At the risk of making you angry, did you verify that 1) it's actually plugged in, and 2) is it plugged into a wall socket operated by a light switch that isn't turned on? (I've actually done the later...Thought I was going to be bald! It was driving me nuts! I KNEW I had done EVERYTHING right, but it wouldn't turn on...Then I realized that I had plugged it into a socket that was also operated by a light switch...yup...turned on the switch...everything after that was LOVELY! Except me...where I kept kicking myself for not catching that sooner!
That's probably not your problem, but I thought I'd mention it...
Feb 12, 2013 | Apex Digital Televison & Video
Wont start on the first try? When we turn the key the vehicle will not start up. usually takes a few turns to get it to start. All the lights come on and it makes a tick sound. I thought maybe the...
When you turn the key and it makes the tick, does it ever turn over at all? If not and it only ticks then it is most likely your starter. You can also test your battery at a local autozone, oreilley, napa, etc. and they can tell you if the battery is the problem. Also if you remove the starter they can typically test them also if you desire.
Jul 13, 2011 | 1997 Honda Odyssey
My 2 yr old Powershot A560 is not accepting new batteries. The lense telescopes and the lcd briefly lights up with the red battery symbol flashing. I can preview photos taken, but I cannot take any new...
The battery you found (CR1220) is for the camera memory.IE time and date.Chances are the batteries that were installed are dead.Also check the contacts on either end of the batteries and clean if needed.
Dec 31, 2009 | Canon PowerShot A560 Digital Camera
My 2 yr old Ixus 70 keps turning itself off.
How old is your battery? Keep in mind rechargeable Li-Ion batteries aren't meant to last more than a couple years, regardless of whether they've been used or not. If yours is as old as your camera, I think you know the answer. The good news is there are many inexpensive generic alternatives available these days. Some are very good, and vice versa. Research the buyer reviews before considering purchasing.
Nov 10, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Install back seat
Someone else had this problem and posted the solution online. I found it while planning to reupholster the drivers seat on my Olds Alero. Hope this helps, i've cut and pasted from wikianswers.... I had the same problem, hence my stumbling across this question this afternoon. i just spent a very frustrating hour working it out! first, to get an idea of how the black clips sit, place them in the rectangular gaps on either side at the front of the seat. the plastic clips sit in the rectangular hole, with the pointy ends facing up. the short one at the front. the short pointy end clips around the front edge of the rectangular hole. the longer pointy end that is now towards the rear of the car is meant to clip onto the wire that sticks out at the front of the seat. there is one on either side of the seat so it is easy to see them line up roughly. the pointy end doesnt clip around the u shaped bit that sticks out, but the striaght bit just behind that. now, if you can understand what i meant. it is time to install. take the plastic clip out of the rectangular hole. clip the long pointy end around the wire on the seat. lower it carefully into place. this is what i found the tricky bit. you can't see, so i lined it up by feel, and lowered it very carefully. then....... after trying many times to put in in place, a finally forced it in with brute stregnth and determination. you have to force it down towards the back of the car to make the clip latch into the rectangular hole. it took me ages to work out the frist one, then the second side only took a minute as i knew what to do. hope this was understandable and will help.
Mar 07, 2009 | 1999 Oldsmobile Alero
Battery location?
It's under the back seat on passenger side. Give the end of the seat a good upward yank and it will pop up
Jan 28, 2009 | 1992 BMW 5 Series
JVC i art 32" flat screen
your tv is under shutdown state, there is a protecting circuit that prevent the tv from turning on when there is a short
Sep 10, 2008 | Televison & Video
Help-Love my 40307
I hate to tell you but if parts are not available is not a good sign,consider buying a new TV and get it over with.
Sep 12, 2006 | Mitsubishi CS-40307 40" TV
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
