Question about NEC MultiSync LCD2010 20.1" LCD Monitor
No display unknown message
No display only displaying unknow signa for vertical and horizental signals, it gets on but does not display computer application only show H: unknown, V: unknown in small window displays on LCD, please send me the circuit diagram of NEC LA 2032 JMW and tell what is wrong with my LCD,
jackboy
  • 2985 Answers
SOURCE: NEC LCD1980SX - displaying colored blocks not synchro
Have tried NEC technical Support? This looks like a circuit boatd problem
Posted on May 31, 2007
CompuGuy44
  • 432 Answers
SOURCE: Display Image Pinched Vertically
I think this is a non-ddc monitor. But I think you right, the monitor is damaged and won't read it's own driver. http://support.microsoft.com/kb/162737/en-us
Posted on Jul 12, 2007
SOURCE: NEC MobilePro 900 lines in display
It is probably due to loose ribbon connector that connects screen(top) to the motherboard(bottom). Try tapping the right hinge first.
Else (make sure to backup the computer before) examining this exposed ribbon connector under the right hinge, and depending upon how far one's knowledge and skill allows to go, by unseating and reseating this ribbon should take care of this situation. Very careful. Getting here could be fatal if not done right.
Posted on Jan 01, 2008
SOURCE: DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Posted on Dec 03, 2008
  • 13 Answers
SOURCE: NEC Dterm 80 LCD display is defective.
The common thing on this style of phone is the silver ribbon cable that connects the display to the main circuit board comes loose after being dropped or knocked around and needs to be reinserted. You will need to open up the phone to do this. If this is not the solution then you will either need to purchase a used phone, send it in for repair or use another phone to take parts from.
Posted on Dec 08, 2008
Aoc led monitor has a vertical jitter seen on letter and picture
Unplug the monitor from the back of the computer and wait a few seconds until it displays a message "No signal." If the no signal message also has vertical lines, you know the problem is in the monitor and not in your computer. Press the "Menu" button on the screen and then use the other buttons to browse for a "Factory Settings" mode. Select this mode to reset the monitor to its original settings. If the lines persist, the monitor may have been dropped or exposed to a magnet -- which can't be fixed.
Aug 18, 2017 | AOC Computers & Internet
Dell xp620 is not working
No Signa where? No Wireless Signal? Or is the monitor saying No Signal?
If you are saying the Monitor says No Signal, then more than likely the Video Card in the computer is bad. Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor does the same and displays No Signal, then your video card is bad. If the Borrowed monitor displays and works ok, then your original monitor is bad.
May 23, 2012 | Computers & Internet
No signal. Power is on, cable functions well (tested on other computer). nevertheless, the screen does not work (any more) and shows signa " no signal" . What can have gone wrong with my screen...
The fact that you see the "No Signal" message indicates that the display is functioning properly. The problem is with the input section. Verify that you have the correct input selected. Other than that, the input board is the likely defective section. This is not uncommon and will require service. This is not likely to be a DIY repair if the input board is defective.
Dan
May 29, 2011 | iiyama Prolite E430 17" LCD Monitor
FS 3900 "Unknow toner istall" shows in display?
The message is indicating that you do not havea real Kyocera toner installed in the machine.
Apr 04, 2011 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
My 19" flatscreen monitor flashes on a blank screen and the power button light flashes on and off blue, no picture.
Problem in Your monitor VGA cable no horizental or Vertical signal.So it is not active standby mode.Check signal or VGA cable on not adjust properly CPU.or any other device.May be VGA cable was broken.Replace it.If you are not replace the part so you can get help any service technician.
Dec 27, 2009 | Soyo 19" LCD Flat Panel Monitor
Need help! there is a black line on my computer monitor I mean horizental
need help.the display is seperated in the middle and the both sides of the monitor,seperated by the vertical line are with diferent brightness and/or resolution
Dec 27, 2009 | Sony SDM-HS73P 17" LCD Monitor
Message unknow disc
hello,
you can try this
This hack enables VCD playback
Power on the player with no disk in the drive
Press "PAUSE" on the remote
Enter "1472" on the remote
Press the UP arrow three times
Press "PROGRAM", "5", "PROGRAM", "5" (the characters 04 EE should now be displayed)
Press "ENTER" (the display should flash briefly)
Press "RETURN"
Power the player off and then back on
Thank you
Dec 05, 2009 | Zenith XBR716
Hello sir, only horizental single line show in my display, what is this problem?
That is caused by absence of the vertical signal, more likely to be a problem with a semiconductor (specially a transistor) broken inside the display. Also, it may be caused by a "cold joint" or a problem with the solder. Heat caused by the "excessive" use of this monitor causes the joint to fail.
May 13, 2009 | Samsung SyncMaster 550S Monitor
Princeton Digital VL1716 Monitor "No Signal Message"
Roxio Changed Your display settings on the dual display.
Right Click on desktop>goto Prefences>
You should see both monitors indentfy the one and change it to a lower resolution.
Apr 28, 2009 | Princeton Digital VL1716 17" LCD Monitor
NEC MultiSync LCD2010 20.1" LCD Monitor Logo
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
