Question about Fuji FinePix S304 Digital Camera
I have a Fuji Finepix S5600 and shortly I got the same problem: zoom error. First I tried the telephone trick but it didn't work. Then I tried solution #10 by LizK76, but how can I separate the back of the camera from the rest. I have to loosen some sort of mini flatcable connectors (of the LCD monitor) but I don't know how to do that.
  • th_hageman Jul 18, 2010
    Thank you very much for your advice. It was very helpful. Now I was able to disassemble the camera. I hope it will work again when I have reassembled it again.
    President:
  • 1,197 Answers
The zoom and focus operate on screw thread drives. 1 of these has detatched resulting in "ZOOM ERROR" and locked the camera up. Dis-assemble lens and re-attach drive.
Start by removing all the securing screws for the casing. There should be 2 on each side and 3 underneath. 2 of the one's underneath will be tri-wing screws (security screws) so you will need to purchase a screwdriver for this ( I paid £1 for mine on ebay). Make sure there are no screws located under the rubber cover for the usb and av sockets ( Im working from memory here)
Best to have a box with compartments in to put screws etc in as you dis-assemble to aid re-assembly. Open battery compartment ( this helps lock the case together) and gentley open the case. It will have plastic clips holding it together also so be carefull of these. The lcd is screwed to the back case too and conected to the pcb as is the key pad so don't lift the back away instantly incase the ribbons tear. Once you have the back removed its just a case of unscrewing the pcb and unplugging the different cables. I think the power board is under the main pcb so will have to remove this to get at the lens unit( Beware of electric shock. It does hurt!) Remove the fixing screws for the lens unit and remove it from the case. The zoom is on a long screw thread which runs from a small motor and gear drive. There should be a little plastic or metal attachment that runs up and down the thread which should be located on the sliding lens which is the zoom. If I remember the motor assembly needs to be removed to re-attach the zoom assembly to the drive thread. Then re-assemble.
courtesy: daveward
Posted on Jul 12, 2010
I dropped my Fuji S5200 now it reads zoom error?
lens will not function normally,due to the mechnism fault,get it repaired by a camera tec.
Mar 09, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
What is Old Telephone Repair" trick
i need to know to!!!!!!!!! everyone is talking about how it fixed their camera, but i dont know what it is or how to use it! so the answer would be helpful, thanks!
Oct 05, 2009 | Fuji FinePix S304 Digital Camera
S 5600 finepix fuji camera - card error
Test the card in another device(computer)to see if it works.If so the card capacity may be too large for the camera.
Sep 22, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Zoom Error Problem
No, your lens has several very small motors, dust sand or water gets in can cause problems. Fuji has a huge problem with these cameras and bad lens. You will always have this problem and there is no easy fix.
Jul 01, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
User manual for finepix s 5600 digital camera
Go to: http://fuji.fi/documents/12/S5600.pdf ... and you can download the manual for free in about 30 minutes! Brenda
Mar 10, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Focus error
Check out this link: www.digitalcamera-hq.com/digital-cameras/fuji-finepix-z1_question.html?qid=4289
After the basics, try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji A500 and 90% of the responders on the link. Everything on the web said it would cost ~$100 to fix. I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
The error may be caused by debris in the zoom mechanism preventing it from working. Dropping the camera loosens the debris and voila!
May 13, 2008 | Fuji FinePix A500 Digital Camera
Fuji fine pix z1 error
I had the same problem and finally had the time to look at it. I was reading some other posts, when I read try the telephone trick. Leave the camera closed and kinda slam it on a hard surface. I slid the shutter open and focused and it took a pic with no problem!!!
Mar 21, 2008 | Fuji FinePix Z1 Digital Camera
S56oo fuju finepix camera focus error
Hit the lens (smack it on you're leg); that seems to be the solution..........
But try cleaning the lens and the AF assistent first!!
Jan 23, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Fuji FinePix S304 Digital Camera Logo
73 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
