Question about Dryers
I have cleaned out the vents to my dryer. And it still will not dry in one cycle. It takes 3 to 4 cycles before it will dry. It tumbles the air is strong and hot in the back
  • Dryers Master
  • 3,740 Answers
Hi and Welcome to FixYa. I am Kelly.
The vent can be clean but the internal ducting of the dryer can still be clogged. I note you stated the air is strong in the back. It should be strong enough to push a relaxed wrist away from the vent hole.
This may sound odd but try one cycle with the vent disconnected and see if the drying time is 40 mins or less. If it is more than 40 mins then there is still a problem inside of the dryer.
You did not post a make or model number so it is impossible at this time to say exactly what part is causing your symptoms.
Some general things that can cause this:
1. If you use dryer sheets the lint filter itself can appear clean but severly restrict airflow. Wash the lint filter with vinegar and water then soap and water. Rinse well.
2. Check the area around the lint filter and the ducting that you can see for lint build up. If you note anything clean it well with a vacuum crevice tool. Use a folded in half metal coat hanger if you have to for losening the lint. NOTHING SHARP.
3. You did not mention if this was a gas or electric dryer. Gas and dryers can get hot then cycle off either by the cycle thermostat or the high temp thermostat. If there is a problem with either of the thermostats it can cause long drying times. Additionally a gas dryer that has a faulty flame sensor will light the burner.. for about 30 - 45 seconds then cycle the burner off.
4. Another possible cause is that the blower wheel hub has broken and the blower fan in not running at full speed.
There are some other possibilities but without a Make and Model number 1 - 4 above are a good start.
Thanks for using FixYa.
Kelly
Posted on Jul 12, 2010
  • Dryers Master
  • 19,396 Answers
Hi.
Check if there is heath. If air is completely cold, check the heating element (in case of electric dryer). Heating element is tested removing it from appliance and reading Ohms with a multimeter to ensure it has continuity.
If there is heat, or if air is cold and element is good, test and replace the thermostats, there should be two or three of them placed in heating group and air ducts.
First ensure you have checked filter, vents and duct and removed lint.
If you want to contact an authorized technician call the number listed on the owners manual or on manufacturer website.
Dryer takes 3 cycles to dry clothes
Air flow blockage will shut the thermostat down early. You may need to clean out the lint filter holder with a vacuum cleaner or a bent coat hanger. Look inside the dryer vent hose. It probably has a load of lint dust in it. A thorough cleaning is in order.
Oct 01, 2014 | Estate Dryers
Maytag Centennial Dryer (MEDC400VW) not drying properly
First of all, please make sure the vent is clear all the way through. Next the vent must be straight as possible. Next it can not be to long. People think that because they feel the air outside the vent is clear, not always true. The vent can be partially clogged. So make sure. Next, if the vent hose has sags or bows and even tight turns. It can accumulate the moisture in it from the drying proceed. If water has collected in the vent hose the clothes will not dry properly. If the vent is to long it can not dry properly either, the blower on the dryer can only move air so far. So the shorter the better. If all of these requirements are meet. Then, I would have to start checking the thermostats. I hope I have helped you. Please respond if you need further assistance.
Jan 29, 2014 | Maytag Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
My Kenmore dryer has heat, tumbles fine but I have to run 2 cycles to dry clothes and 3 - 4 cycles for towels. The vent line is new and I can feel damp warm air where it exits the vent line. It worked fine...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 15, 2011 | Kenmore 400 6943 Dryer
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
Whirlpool model # lgr7646ez3
Here are a list of causes that may contribute to this lack of sufficient drying.
CAUSE
• Lint screen is clogged with lint.
• Restricted air movement.
Exhaust vent or outside
exhaust hood is clogged with
lint.
• Exhaust vent is crushed or
kinked.
• One fuse is blown or circuit
breaker is tripped. The dryer
will appear to operate, but you
will not get any heat.
• Cycle Control knob or temperature
selector is set on air dry.
• Load not contacting the sensor
strips and automatic cycle
ending early.
• Fabric softener sheets blocking
exhaust grill.
• Dryer located in room with
temperature below 45ºF (7ºC).
• Large amount of moisture in
the load.
• Cold rinse water used.
• Load too large and bulky to
dry quickly.
Here are the solutions to combat the issues.
SOLUTION
• Clean lint screen.
• Run dryer for 5-10 minutes. Hold hand under
outside exhaust hood to check air movement. If you
do not feel air moving, clean exhaust system of lint
or replace exhaust vent with heavy metal or flexible
metal vent.
• Replace with heavy metal or flexible metal vent
• Replace fuse or reset breaker.
• Select the right cycle and temperature for the types
of garments being dried.
• Level dryer.
• Use only one softener sheet per load and only use
it once.
• Move dryer to a location with temperatures above
45ºF (7ºC).
• Expect longer dry times with items that hold more
moisture (cottons).
• Expect longer dry times.
• Separate load to tumble freely.
This will help you fix this problem. i suspect an exhaust obstruction.
Mar 11, 2009 | Whirlpool LGR7646E Dryer
Dryer wont dry but heats and tumbles. takes 3 cycles to dry
Have you checked the entire duct run. When dryer vents should feel like a hair dryer on high blowing outside
Feb 16, 2009 | Roper RES7646KQ Electric Dryer
Dryer won't tumble
Check thermal fuse located behind rear panel mounted on dryer (depending on model of the dryer) duct. Fuse is the component with 2 blue wires and is white in color. Try jumping 2 wires together or OHM out fuse. Fuse being bad is a sign that either
a) Dryer vent is clogged ..... If dryer takes any longer than 1 60 min cycle to dry loads than the vent IS CLOGGED!!
b) Dryer thermostat (next to fuse with 4 wires 2lg red and 2sm)
is not cycling proper
c) some other electrical short causing element not to cycle proper
Check Temp of discharge air with thermometer
on High should cycle on somewhere around 120
and back off at no higher than 170 no less than 155
Jan 18, 2008 | Dryers
Dryers Logo
106 people viewed this question
Top Dryers Experts
