Question about Kenwood KDC-MP435U CD Player
I get a message Protect. All other controls are
I Have a Kenwood KDC MP 443U CD-Receiver. 2 days back on attaching the front piece I get a flashing message 'Protect'. All other controls are disabled.
What is the problem and what is the solution.
  • Kenwood Master
  • 17,130 Answers
Usually the protect is a safe mode to indicate that your set is unsafe. Starrt by checking the speakers, speaker wires for shorting. detach the speaker lines and power on the set for confrimation. check in power/auxially circuits in the set. it is possible that your mechanism drive / audio output drive Ic's could have shorted. Most of these cirrcuits have an error detection of higher current to cut off power and issue a protect warning. so discoonect the IC power to confirm. Hope this helps. Good day
Posted on Jul 13, 2010
Testimonial: "The problem was with speaker wiring.Thanks"
  • frankenb Nov 18, 2010
    Use the reset button to clear the condition. There may be no electrical issues.. My kids friend plugged her iPhone into the USB jack incorrectly at first.. there was probably a brief short or over current condition which latched the Protect circuity.. The Reset button cleared that and monitoring the stereo showed no signs of damage or shorts...... The reset button for your unit should be documented in your Users Guide... If reset doesnt clear the condition then refer to the message above from caroldong who is the GURU !!!
  • udaisaklani Nov 29, 2010
    Thanks the speakers had indeed shorted. There is also a reset button which can be used if the problem was temporary.
My Kenwood KDC-U453 cd receiver displays "PROTECT" on connection and nothing works - any solutions appreciated!!!!
Pull the radio out, tape off all wires but yellow, red and black. Twist red/ yellow together and attach to positive 12 volt, attach black wire to negative 12 volts. Turn on radio and see if it comes out of protect mode. If it does, you will have to troubleshoot all of the speaker wires to find a short.
Apr 11, 2013 | Kenwood Kdc-u453 Car Audio Radio Iphone...
I have a kenwood it says,kdc-mp142 and all of a sudden it just says protect. it wont do anything
The Kenwood radio will generally give a "PROTECT" error if the amp or receiver is being overloaded. This may mean that some of your wiring may have gotten frayed, one of your speakers isn't putting out the right voltage, or the receiver has decided to go bad. Make sure all of your connections in the back of the radio are solid and not frayed. If that's not the problem, try running each of the speakers one at a time. If one causes the radio to go into protect mode, that's your culprit.
If neither of these are the issue and the radio decides to stay in "protect" mode, your receiver may have seen better days and may need a replacement.
Feb 28, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
I am installing kenwood kdc-mp443u. it is flashing protect and i can't remove it. can you help please?
A speaker wire has a short-circuit, crossed, or touches the chassis of the vehicle it activates the protection mode function.
? Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center.
I have attached a link for you which is for a free Kenwood KDC-MP443U instruction manual download. Nice receiver by the way!
Kenwood KDC MP443U Instruction Manual
Dec 18, 2010 | Kenwood KDC-135 CD Player
Protect code
make sure you have no bare or shorted speaker wires and check your speakers to make sure they are all good. if that all checks out, you probably have a bad output ic.
May 25, 2010 | Kenwood KDC-W3037A CD-receiver,...
Kenwood KDC - MP 235
I would also check the speaker outputs from the deck. If any of the speaker outputs are touching any metal on the vehicle, it could give that message.
Dec 08, 2008 | iLO XM-MP3-CD Car Stereo
GET IPOD TO WORK ON KENWOOD KDC-W3037 CAR CD PLAYER
you have to activ ate the aux port form the menu, on standby hold the menu button and then use the control knob on the right to change the aux to on1
Sep 18, 2008 | Kenwood KDC-W3037A CD-receiver,...
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Kenwood cd receiver KDC-MP436U
Protect:- The speaker wire has a short circuit, or touches the chassis of the vehicle, then the Protect function is activated. Wire or insulate the cable properly and then press the reset button. If the "Protect" code does not disappear, consult your nearest service centre.
Mar 20, 2008 | Kenwood KDC-MP235 CD Player
Security
"Protect" isn't for security on a Kenwood; it's caused by a problem with the speaker output. There may be a defect in the CD player, or you may have a blown speaker or a shorted speaker wire in the vehicle. Try disconnecting all the speakers and see if the unit still shows "protect" when you turn it on. If it still shows the "protect" message with no speakers connected, the unit needs to be serviced; if not, re-connect the speakers one at a time until you find out which one is causing the problem.
Aug 10, 2007 | Kenwood KDC-MP232 CD Player
Kenwood KDC-MP435U CD Player Logo
544 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
