Question about HP Computers & Internet
Winzrv32.rom Every time I start the computer my PC tells me that RunDLL couldn't start the file winzrv32.rom, that it couldn't find the module. So I wonder, is this file important? If I don't have will it cause system errors? Could this have happened duo to a virus? I haven't seen any problems yet but I'm afraid that I will in the future if don't take care of the problem now.
  • 487 Answers
Hi, try this link to understand and fix this problem : http://www.delete-computer-history.com/rundll-error.html
Hope this helps
Posted on Jul 12, 2010
Hw to remove run DLL error in microsoft window 8.1
run.dll is a DATA LINK LIBRARY FILE if it is sikped in installing windows {or} other any software ,malware,adware virus problem you can fix it by using DLL suite { the dll suite download and install it will have a lot of serials keys in serial.ws.com } you will enjoy the features of windows
Apr 06, 2015 | Microsoft Computers & Internet
When I start up my laptop this message box comes up RUNDLL Error loading dll32 the specified module could not be found I can close the box & the laptop seems to work fine but what does it mean?
File dll32.exe is NOT a Windows core file--It is a leftover piece of code from malware.
File dll32.exe is usually located in the folder C:\Windows\System32--delete it
Jan 13, 2011 | Toshiba Satellite 2410-S203 Notebook
After starting the laptop it showing amessage like this ''RUNLL There was a problem starting winpxs32.rom The specified module could not be found...
just found this on the internet not sure if it will work for you but have a read up about it.
Rundll problem issues are caused by misconfigured system files. Rundll problem usually happen when the computer's registry system overloads with to much data, or when certain system files become missing or broken.
The Rundll problem issues are easy to repair. By downloading and running the registry repair tool System Optimizer, you can quickly and effectively fix this problem and prevent others from occuring. Simply click the links below for your download.
Download & Install System Optimizer.
Note:If the download link doesn't work you may need to Download it from a mirror
  • Step 2:
    Click the "Quick Scan" button.
  • Step 3:
    Click the 'Repair All' Button to Repair Your PC.
  • or try this link first..
  • RUNDLL There was problem starting winpxs32 rom The specified module could...
    Oct 28, 2017 | Acer 4220-2346 Notebook
    Everytime I start up Windows I an error message.
    Well, the reason causing Rundll Error is probably that when you are surfing on line, some Trojan and malware attack your PC and modify the registry for malicious purpose. Though the anti-virus and anti-spyware can remove those Trojans and malware, they cann't repair the destroyed registry. So, Rundll Error happens! Of course, Rundll Error is not only caused by Trojans and malware. According to our research, mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause Rundll Error.
    Thru serious test of our expert team, Perfect Optimizer can fix Rundll Error 100%, much higher than other registry products.Because Perfect Optimizer uses a high-performance detection algorithm that will quickly identify missing and invalid references in your Windows registry. With a few easy steps Perfect Optimizer will entirely scan your Windows registry for any invalid or obsolete entries and provide a list of the registry errors found. After that you can choose to clean list items with selection or automatically repair them all.
    So when your PC got Rundll Error, it's highly recommended that you download Perfect Optimizer and repair Rundll Error. Anyone can do it like a computer guru within 5 minutes!
    Jul 14, 2010 | Toshiba Satellite P105-S6227 Notebook
    How do i remove run.dll2 from my computer?
    Rundll.exe files are programs that are directly tied to the registry on Windows computers. Dynamic Link Library (DLL) files contain libraries of information used by other programs running on your computer. They were originally created in order to help computer programs run faster on the Windows operating system. When a DLL file is corrupt or missing, a Rundll error will be generated. Normally when a rundll error is generated it is related to malware.
    1. Note the process that is generating the Rundll error by examining the last file name in the error that ends in ".dll."
    2. Open the service configuration program on your computer by selecting the "Start" menu and typing "command" in the search text field. At the DOS prompt type "services:msc" and click "Enter."
    3. Select the DLL service from Step 1. Right click the service name followed by the "Stop" menu button. Exit the service configuration program.
    4. Open your computer's registry editor by typing "regedit" at the DOS prompt and navigate to the Rundll registry key by typing "Microsoft\Windows\CurrentVersion\Run" in the Search field.
    5. Select the registry key returned and in the value associated with the registry key, confirm it ends in the same DLL file name found in Step 1. If it does, single left click the value and Press the "Delete" key. Exit the registry editor.
    6. Restart your computer and the Rundll error will be corrected.
    Save a tree.
    Apr 28, 2010 | HP W19b LCD Monitor
    Starting computer
    try to re-install the windows by booting first priority with the cd rom using the windows xp cd installer.
    Jan 31, 2010 | Microsoft Windows XP Professional With...
    When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
    Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
    Now, if you able to access the XP in safe mode, You could go to :-
    Start > Programs > Accessories > System Tools > Restore.
    Select a restore point and it's all done.
    Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
    Let me know, if needed assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Nov 08, 2009 | Microsoft Windows XP Home Edition
    Error message RUNDLL
    this file is not a recognized windows file it looks like a trojan or virus that is afecting how your computer boots up. You may be better off backing up all the files and documents you don't want to lose then re-format your drive and do a windows fresh install.
    Jun 03, 2009 | Dell Dimension 1100 PC Desktop
    RUNDLL
    It appears that a program has been removed (not uninstalled) from the computer and XP can no longer locate the removed files while references to the files still exist. So, we need to find what is referring to this file. The easiest way would be to download, install and run a registry cleaner such as CCleaner (from www.download.com), but this can also cause more problems than it solves. The other way is to use the msconfig utility to disable all of the extras that are loading and then enable them one by one and rebooting each time until the problem appears again. Then just disable the last one enabled (that caused the problem to reappear), and continue on until all other programs and processes have been reenabled.
    Apr 07, 2009 | Microsoft Windows XP Professional With...
    RUNDLL Error loading c:/PROGR-1/MYWEB-1/bar/2.bin/M3PLUGIN.DLL The specified module could not be found Can you please help me how to get rid of this at the start up please. Thax Tracie
    This is a virus download " Malwarebytes " and install and run it will delete all virus files
    Usually picked up downloading cracks
    Get a decent antivirus suite to protect your computer
    A lot of them have a free 15 to 30 day period
    Aug 20, 2008 | Intel Motherboard
    Computers & Internet Logo
    283 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
