Question about Sony Playstation 3 (PS3) Console
Ps3 80g light turns green flashes yellow, then
Ps3 80g light turns green, flashes yellow, then blinks red, with three beep. no pict on screen
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 122 Answers
Unfortunatly your ps3 is dead, I am sorry for your loss.
Posted on Jul 13, 2010
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
When I turn on my ps3 model cechg01, it blinks the green light a couple times then shuts itself off. No other color lights just the green one, then beeps three times and shuts off.. Can anybody help narrow...
When you plug in your system with the power cable and turn the toggle switch (in the back) do you see the red stand by light?
The red and yellow light comes from 1 bulb and the green and blu light comes from another..
If you have the YLOD and your yellow/red light is out, you will only see the green light.
I am really interested in your problem.
Do this to check your status: If you can do this function below but not any other, chances are, you do have the YLOD. It can be fixed.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and should eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: Whe i touch the red startup button it beeps and tu...
you got a YLOD yellow light of death when you get a yellow light briefly and then the red lights start blinking, you need to reflux the solder on the processors and apply heat to them, here is a link on how to do the repair, if you are not good at doing these kind of work, I would suggest taking it to a pro.
http://www.youtube.com/watch?v=XIm0Qk0CVTE&feature=related
May 17, 2010 | Sony Playstation 3 (PS3) Console
When you turn the unit on it goes to a green light then beeps twice and goes to a flashing red light?
This is an overheating problem.
Let it sit for about a day and then try it out.
Make sure it has ATLEAST 4 inches of open space all around it and is not near any heat-making devices, it makes enough heat on its own.
Also make sure it's not on carpet.
If it ever starts to immediately shut-off, blink green yellow and then repeating red with 3 beeps, you have the Yellow Light of Death.
This is a console killer.
Repost as a different question if it turns into the YLOD.
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
Mar 31, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
Red flashing light and PS3 won't work
I have had this same probelm unfortnaully .. It sux , and after trying alot of different things and reading , and talking to sony themselfs seems only fix is $150 repair or a new playstation :( . . Have you noticed your fan is just loud and has like 3 stages of loudness? Thats what mine did , and i got the red flashing lights if not loud then anthor device in your playstation has stopped working sorry to say
Feb 02, 2009 | Sony Playstation 3 (PS3) Console
Flashing red ring on x box 360 console
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Jul 18, 2008 | Video Game Consoles & Games
Beep 3 times turns green yellow then blinks red then turns to a solid red wont turn on wont give me game
3 Solid Red lights usually means that a cable is unplugged. Check all cables (unplug and plug back in)...you may need to replace power cable if issue is still ocurring. If it is 3 Flashing red lights, this is known as the Red Rings of Death, i.e. your XBOX is dead and needs to be completely replaced.
http://www.xbox360forum.com/forum/xbox-360-console/64180-what-do-three-solid-red-lights-mean.html
Jun 16, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
191 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
