Question about Tricity Bendix AW850W Front Load Washer
Washing machine door will not open
We have a Bendix Autowasher 800 washing machine. Usually at the end of the cycle the door will be able to be opened. The door is remaining closed and there appears to be no spring or give in the handle. Can you help? I cannot find a manual
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
  • 213 Answers
SOURCE: Bendix washer-dryer door won't open
if you remove the panel in the front lower right hand coner of the washer you should be able to feel around in there for a plastic cord. pull the cord to manually unlock the door
Posted on Nov 25, 2007
  • 54 Answers
SOURCE: Bendix 800 autowasher
put it on its back on yhe top side of the motor you will see the brushes two screws hold each one on.
Posted on Feb 12, 2008
SOURCE: Bendix Washer/Dryer WDB 1074T
Well well well - Welcome to the Bendix Club!
Here is the secret!
Push all 4 buttons in!
Turn on the Cold water only!
Set the first dial on 3 dots before the GREEN #12
Set the second dial to snow or cold
Set the third dial to one dot after the green 7....
If this doesnt work...the something is wrong with the machine!
Or email me.
Posted on May 19, 2008
ginko
  • 19396 Answers
SOURCE: TRICITY BENDIX AUTOWASHER 800 WASHING
Hi.
Problem is likely the thermostat. Before replacing internal thermostat check the following:
Tricity Bendix Autowasher models are usually not self heating and dual inlet (hot and cold). If the machine is not self heating, ensure that the inlets are not inverted. Ensure that both inlets have enough pressure.
In case the machine is self heating, check also that the washer is not heating in cold cycle, otherwise you will need to check wiring to heating element.
To get parts contact Tricity Bendix at the number listed in the owners manual, or give us the full model number, as written on service tag.
Regards.
Ginko.
Posted on Feb 10, 2011
Door wont open on washing machine zwf16581w at the end of the cycle
The door is designed to stay shut at the end of a cycle usually for about 4 minutes, even if you switch the machine off at the mains. Other than that you probably need a repair.
Dec 17, 2011 | Zanussi Washing Machines
My bendix washing machine door does not open after wash cycle ha finished
  1. Is there still water in the machine when the wash cycle has finished? If so, the door doesn't open because there is still water in the machine. Try clearing the filter at the bottom of the machine, in the front. If this doesn't work, check that the drain hoses are cleared. If it still doesn't work, try replacing the drain pump.
  2. Is the "door" light still on? You may have a faulty door lock assembly, or your control board may be faulty.
Feb 27, 2011 | Tricity Bendix AW1400W Front Load Washer
Is there an emergency door release on my bendix washing machine?If so where is it?
No there isn't. The door will now open until until the wash cycle is finished
Jan 14, 2011 | Tricity Bendix AW1000W Front Load Washer
Bendix 800 autowasher de luxe, drum spin snagged then cleared.
should b nothing off this description on ure machine unless the pump coil has over heated iff so just replace coil and check for blockages
Jul 13, 2009 | Tricity Bendix AW1000W Front Load Washer
Is my bendixx 1000 autowasher hot or cold fill
Look at the top left rear of the cabinet, there you will see the connections for the inlet valve(s), if there is only 1 then it is a cold fill only, if there are 2 connections , then it is hot and cold fill.
They are normally marked H and C.
Plz leave feedback for this solution.
thanks.
Dec 17, 2008 | Tricity Bendix WDR1040W Front Load Washer...
I have a Bendix Autowasher 800 washig machine. The door lock seems to have broken, with a load inside the machine, and I can't open it to get the load out. The cycle has finished. I think I broke it by...
Have the same problem myself.
Remove top panel from washing machine by undoing two fixing screws to rear and sliding panel forward to front of machine.
Door lock is located internally on right hand side, its difficult to reach and I had to loosen the control dial and switches to gain access.
However it may be possible to release the mechanism by touch.
At the back of the lock mechanism the latch protrudes by approx 3 mm if you can see it or feel it you only have to apply some pressure to the projecting end to release the latch.
The broken release lever can then be removed from the door and replaced by a new part which cost about €6.
Jun 29, 2008 | Washing Machines
Jan 03, 2008 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW850W Front Load Washer Logo
135 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
