My paper won't feed correctly. It continually jams and there does not appear to be any paper caught in machine.
    Scholar:
  • 103 Answers
Its hardware failure go for a new unit
Posted on Jul 12, 2010
Can't print pictures from my laptop. The printer always says paper jam but there isn't one
"Paper Jam" issues are common with printers. They most often occur right after there has been a paper jam. Most people (not necessarily YOU), don't take the time to read how to properly clear a paper jam in their printers and often yank the jammed sheets backward thru the paper tray. Most times you should remove the cover in the back and pull the jam FORWARD out the rear, or if the jam made it close to the output tray, then FORWARD thru to the output tray. Pull sheets backward can cause two issues. It makes tearing the paper easier. This can result in tiny pieces being caught in places where the printer detect them as a jam. The other issue is that pulling backward can damage the feed rollers that pull the paper into the machine, as well as the mechanical sensors that detect paper jams. If you cannot find ANY shards of paper in the machine, you may have printer damage that results in the jam indication.
Oct 10, 2015 | HP Computers & Internet
My printer keeps showing the message, " paper jam
Hello Tessty,
The Paper Jam message may appear on the display if the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=ca&lang=en&prod=mfc240c_all&Cat=113
Jun 20, 2011 | Brother Multi-Function Center MFC-240C...
The printer keeps saying that there is a paper jam when there is not.. Also some times when it trys to print it will jam and the page will be torn down the middle.
Check the machine carefully, sometins a small sliver of paper is caught in a critical place in the printer and will give the paper jam message. If you paper is being torn it is most likely due to an uneven feed caused by feed wheels that are slipping on one side while the other side still feeds normally. Clean all the feed wheels in the paper path with a Q tip soaked in Isopropil Alcohol. Also make sure that your paper guides are set to the correct widths.
Jan 21, 2011 | Lexmark Office Equipment & Supplies
The paper does not feed into the printer
Sounds like you have a jam!
The jam always hides good!
Look carefully and get back with me!
Jul 16, 2009 | Samsung ML-2510 Laser Printer
CONTINUING PAPER JAM. I OPEN DOOR, CLEAR THE JAM, AND PAPER STARTS TO FEED, THEN AGAIN ANOTHER PAPER JAM, AM I USING WRONG PAPER?
I know the problem, Its the Exit paper sensor! if u make a short circuit on the pin 2 and 3 of the CN2 when the paper reaches the sensor it wont jam. Chainging the sensor resolves the continous paper jam or try to clean it!
Apr 08, 2009 | Samsung CLP 315 Laser Printer
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
Paper jam error, but no jam present
mabey its the wrong paper youre putting in it:O?
Jan 03, 2009 | Office Equipment & Supplies
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Printerjam
A paper jam error message will appear if the printhead is not correctly installed. Try removing and reinstalling the printhead again, but make sure it snaps into place. Try loading a sheet of plain paper and press at the same time copy+cancel; hold them down until the printer feeds the paper. The paper will go through the rollers and come out blank.
Apr 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paper won't feed
Dell.com will chat with you on-line to help you toubleshoot that printer.
Mar 31, 2008 | Dell 924 All-in-One InkJet Printer
12 people viewed this question
k24674
jasbo
jasbo
