Question about Panasonic KX-T7735 Corded Phone
I can't access my co1 outside line on the KT-x7735
I can't access my co1 outside line on the panasonic kxt773. Everything is plugged in correctly and my line 2 (co2) works!
  • desvignes Jul 12, 2010
    Hi Cnavarro, it does say CO-1! But no dial tone available. Called up Tel Co and they said it was an issue their end. Thanks for your help. Hopefully they can rectify it.
  • Panasonic Master
  • 2,460 Answers
It could be a couple of things. First, press PROGRAM and the CO1 button. If it does not say CO-1, then dial 0 1 STORE and it will.
If it does, you probably altered system programming and that line is now restricted from the phone. That requires Installer system access to the programming from the phone connected to the first jack in the cabinet.
Carl
Posted on Jul 12, 2010
How can I get set the outside line back on Line one and get the dial tone back?
try entering a 9 then the number you want .if that does not work try every number alone till you hear a dial tone
Jan 27, 2015 | Panasonic Lands Phones
My phone is panasonic kx-t7730 white advanced system HYBRID SYSTEM it does not ring in the day time mode
it may be the battery for its memory be dead...if this is true the phone installer can straighten it out for you
Jan 18, 2014 | Panasonic Advanced Hybrid Kx-t7730 White...
KX-T7431 try to dial out and dispaly says CO Not assigned, I cannot answer calls either!!!! Hellllppppp
What has happened is that the CO1 CO2 etc buttons have not been programmed to dial the access code for an outside line. You can do this manually by dialling 9 then the number you wish to call. You need to enter the programing mode from the default extension usually EXTN 20 or 21. You need to go into the options and assign the digit 9 and a pause (P). The system will allow you to set different options such as if someone is on CO1 and another user dials 9 from another extension, the system will then assign the next free exchange line, again this must be programmed via the default extension. Let me know if you need further help.
Sep 04, 2013 | Panasonic KX-T7730 Corded Phone
Determining which CO you get when pressing 9
Set outgoing line preference.
Or simply swap the CO1 and CO2 line plugs.
The plug from your service provider that enters in CO1 put it in CO2 port and vice versa.You may need alittle config as well.
Oct 26, 2012 | Panasonic KX-T7730 Corded Phone
I had a KX-T7730, i have 2 line and use to be store as CO1 & CO2.. then other time when i try to store a speed dial.. everything got mix up.. now when i colleague hold a call, i can't pick up the call...
From the idle phone, press PROGRAM the button where line 1 used to be and dial 0 1 STORE do the same for line 2 if you unprogrammed that, using 2. Press PROGRAM or pick up the handset and drop it back down to end programming
Carl
Apr 18, 2011 | Panasonic KX-T7730 Corded Phone
Dial tone on speaker-phone but no dial tone on line 1
Either button mapping or no dial tone at the system cabinet. If your desplay sas CO1 and you have no dial tone, go to the sytsem cabinet ans swap the modular plugs for CO1 and CO2. If the No Dial Tone moves, "mus be sumpin wrong wit yo lines".
Carl
Aug 13, 2010 | Panasonic KX-T7730 Corded Phone
Two phonelines no longer accessible. Using Panasonic KX-T7730 with a Panasonic KX-TES824 system. Lines were working fine and have now disappeared. They don't ring in and I can't ring out on them. ...
This is most likely a service provider issue. If these are analog lines, take a regular phone, not a Panasonic system phone, and plug it into wherever the CO1 CO2 CO3 lines go into the cabinet. If they work there, you have a system fault (not likely). If they don't you have a line problem.
Make sure that you plug the phone into the lines coming in, not into the cabinet :-)
Carl
Oct 09, 2009 | Panasonic KX-T7730 Corded Phone
I HAVE STILL GOT ALL THE SPEED DIAL NUMBERS IN MY TELEPHONE BUT SEEM TO HAVE LOST THE OUTSIDE LINE TO CALL ANYBODY, ALL I GET IS co NOT ASSIGNED, CAN ANYBODY HELP ME THROUGH IT?
If your 773x phone is connected to most Panasonic systems, you can press PROGRAM and the place where lines are supposed to be assigned and it will tell you what's under the button with names like CO1, CO2, CO3 etc.
If it says something else, you can make it become outside line access buttons by the command 0+a number 1,2,3 and STORE.
You can do all 3 buttons at once, just keep pressing them and dialing the sequence with a STORE. After you've finished, just pick up the handset and drop it back down to end programming.
Carl
Apr 22, 2009 | Panasonic KX-T7730 Corded Phone
I have a panasonic kx-ta624.I have a anolog line coming into port CO1 and feeds all the jacks my problem is i can make calls but cant recive them. I am not using panasonic phones but was told the system...
You have to have ONE 7x3x phone plugged into Jack 01 in the system or you don't stand much of a chance to make this work.
There is no USB interface to program a 624 and the ringing is controlled by programming. By default, turning off the system will tie CO1 to Jack 01 in power fail transfer. If you believe the line is functioning, then plug it into CO1, a phone into Jack 01 and call your number. If it rings, then you have connectivity, now puwer up the system and do the same thing. If it doesn't work, then you need to program the box.
Carl
Sep 08, 2008 | Panasonic Lands Phones
Panasonic KX-T7735 Corded Phone Logo
283 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
