Question about TallyGenicom 6312 Matrix Printer
The print job for the TallyGenicom 6312 is a coupon and has a barcode in it, and the barcode is not readable by the barcode reader. The printed barcode looks perfect. And, the barcode reader has no problem, and reads printouts form other 6312 printers. What can be the reason. Please help
  • Anonymous Mar 16, 2014
    canon ip 2707 not printing coupon barcode
Tallygenicom 6312 not print nither from LB1 nor from serial
please help me
Posted on Sep 15, 2013
  • 21 Answers
Try to adjust the "Bar" setting in the Graphics menu. Here you can specify the density of the barcode. I have seen the best results using the Medium setting.
Posted on Dec 04, 2010
NEED WIN7 DRIVERS & FIRMWARE FOR T6045
Best option is to add printer in Win 7 using Generic manufacture and generic/text only for printer. Obviously you select LPT, serial or your external printserver IP address.
Should be able to print anything you want.
Except barcode...
If you have problems printing a simple windows test page, let me know, we can figure out the problem.
Thank you,
Toby
As you know those printers are very old, so to get you out of the dinosaur days and into the 80's. You might look at TallyGenicom 6312. It can do everything the T6045 plus multiple times more. We have parts still available for T6045, but if the main logic board goes bad... recycle time
Aug 09, 2016 | Tally Line Matrix T6045 Printer
Not print in windows xp from lpt1
There are two likely issues. First, install the appropriate drivers for the printer from here... http://www.tallygenicom.com/products/productdrivers.aspx?id=5976. If that doesn't solve the issue, the LPT port may be disabled in the bios of the computer. To solve it, enter the bios and enable the LPT port. (Normally under "Integrated Peripherals"
Oct 29, 2013 | TallyGenicom 6312 Matrix Printer
I want pdf menual 6312 line printer
can send email to attach pdf for tallygenicom 6312
Oct 26, 2012 | TallyGenicom 6312 Matrix Printer
Sir, We have a Genicom 6312 L Line Printer. This printer is attached with UNIX (5.9) system. It was working fine till few days back. Recently we changed the Logic Card. After this the printer is not...
If the printer does not print from Unix via parallel interface, it may be nessesaey to set the BI-DIRECTIONAL setting within the Parallel interface settings to OFF.
Sep 21, 2011 | TallyGenicom 6312 Matrix Printer
I've TallyGenicom 6312 It was printing and suddenly stopped and display the following error: Fault: Coil 26 and doesn't print anymore. Please help!
This error is is indicating the printer detects a problem with one of the coils which make up the hammer bank.
You can try checking for any obstructions in the printer, in particular check the ribbon shield is no bent or out of place and may short out any coils.
Further then this to identify the problem may involve disassembling the printer. Ensure the hammer bank alignment is not messed up or you will need to replace this!
Check the cables from the hammer bank to the logic board for any damage, check the cable makes good contact.
Further than this you may be able to test each of the coils with a multi meter to see if there is a fault with a coil, if there is it is likely the hammer bank will need to be replaced as it is not passable to service this in the field.
Mar 26, 2011 | TallyGenicom 6312 Matrix Printer
Printer TallyGenicom T6312 printing blank pages
This is most likely caused by a problem with the print gap mechanism. It seems the print gap sensor was not able to adjust the gap correctly for your paper. The first I would try is to update to the current firmware version (4.0A) which is in many times solving the problem. If not you would need to replace the print gap sensor.
Sep 27, 2010 | TallyGenicom 6312 Matrix Printer
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Our Genicom Tally printer fails to keep settings. The model type is 6312. What could be the problem?
There may be a number of reasons for the 6312 failing to keep your settings, the first thing to identify would be that you have changed the settings on the printer and then saved these settings. If you do not save the settings to a menu / configuration they will be lost if the printer is powered off or receives a reset command.
Once you have made your settings changes, the settings can be saved in the following way;
Ensure the pritner is OFFLINE
Press Menu
Press Up Arrow until display shows Config Menu
Press Enter
Press Up Arrow until display shows Configurations
Press Enter
Press Up Arrow until display shows Save
Press Enter
Press Up Arrow until the Config Number Or Name appears that you want to save the settings to (Default is Confg 1)
Press Enter
Press Clear, to return to Offline mode.
If you save your settings you can then print a configuration report to see the values that have been saved, this can be done in the following way;
With the printer OFFLINE
Press the Menu key
Press any Arrow key until display shows Config Menu.
Press the Enter key.
Press any Arrow key until display shows Printer.
Press any Arrow key until display shows Report.
Press any Arrow key until display shows All Configs.
Press the Enter key and the configurations will be printed.
This should show your saved settings, try powerign th epritner off and back on again and again print the Congfig report to check the settings are retained.
If you find the settings appear to change when you print to the printer this will be caused by your print job, escape commands in the print job will take presidence over the printer menu settings.
You would need to check the host computer system to see what might be causing the problem; chack page size, fonts, ensure the correct printer driver is used etc on the system.
Jan 26, 2010 | TallyGenicom 6312 Matrix Printer
Hammer voltage 2
A high resistance coil fault has likely occurred in one or more of the hammer coils. Note: this fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Check the hammer bank for defective coils.
Replace the
Controller Board
Jan 08, 2009 | TallyGenicom 6312 Matrix Printer
TallyGenicom 6312 Matrix Printer Logo
168 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
