Question about EDGE Tech Corp Edge 540T 40cc~50cc GAS ENGINE POWER AEROBATIC AIRCRAFT
LookING for a manual for A DUCAR 50C ENGINE - EDGE Tech Corp Edge 540T 40cc~50cc GAS ENGINE POWER AEROBATIC AIRCRAFT
  • 31 Answers
Tell where u go it from
Posted on Jul 14, 2010
How to set throttle speed ducar genset
move screw of speed regulator on the top of the carburator clockwise
May 01, 2014 | Electrical Supplies
Hi everyone I have a 125 4 stroke ducar engine it won't start I don't know why can anybody help me the petrol goes thru and it had a spark I have no clue why it won't start
there are three things that engine needs to start fuel,spark and compression you stated that fuel and spark but what about compression if no compression could rings or valves!
Jun 02, 2012 | 2003 ATK 125 4-stroke
I got a 90 cc ducar dirtbike and it wont idle right keeps on bogging out ,,what 's wrong with it
Try draining the carburetor. Water may have built up in the float bowl. Install a new spark plug.If draining and a new plug dobn't help, remove the carb then remove the float bowl and clean the carb with spray carb cleaner.
Jun 06, 2011 | Suzuki Tempter GR 650 Motorcycles
Which bolts are to be removed on ducar 125 to remove head
Take out the gas-tank, exhaust manifold, carb, the head-cover. Then take ouf the head. It would be better getting the shop manual, because the head bolts must be removed and tightened in proper sequence.
Oct 25, 2009 | 2003 ATK 125 4-stroke
Printer says to see manual for 50C. What's the problem?
well there is a couple things going one, first 50C means it is a cartirage problem, if you recently refill your ink cartilages, and waited for the cartilages to be super low, there is a fuse inside the electronic board that blows and it not fixable, dell is not right, there printer cartilages are made so you cant refill them, if you wanna bypass paying a fortune for replacements ones thru dell, go buy the lexmark brand ones that are the same looking as the dell ones, cut off the top part of you dell ones, and put those on your new ones, also you can only fill the dell ones 3 maybe 4 times before the electronic reader goes bad. Hope this helps
Sep 24, 2009 | Dell A960 All-In-One InkJet Printer
My A940 All-in-One shows a Cartridge error 50C and also shows that the colour cartridge is missing when it is not can you please help tried looking through manual but cannot find what a 50C error is please...
Hi there Error 50c
All the best of luck
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jun 17, 2009 | Dell A940 All-In-One InkJet Printer
Lexmark 5150
I went to the Lexmark site and downloaded the manual. Looked for my problem 'Cartridge Error 50c' and found that my color ink was empty. It took some playing around, but that was it.
Aug 11, 2008 | Lexmark X5150 All-In-One InkJet Printer
Hotpoint aquarius FDW60 FAULT
dishwasher runs for 1 min then stops and 40c indicator and 50c indicator flash on and off together it pumps water out then stops
Jan 03, 2008 | Dishwashers
EDGE Tech Corp Edge 540T 40cc~50cc GAS ENGINE POWER AEROBATIC AIRCRAFT Logo
204 people viewed this question
Top EDGE Tech Corp Toys Experts
ray gallant
Are you an EDGE Tech Corp Toy Expert? Answer questions, earn points and help others
