Question about HP Photosmart Premium C309A All-In-One Printer
Attemts to print e-tax summary the printer is defaulting to cd
I am trying to print an etax summary and despite settings for A4 paper the printer is defaulting to cd and telling me to put cd in place.
    Scholar:
  • 103 Answers
Click on startà control panelàprinter and faxes.
Click on top left Add a printer option. This launches the Add Printer Wizard. Click next.
Select Local printer attached to this computer and uncheck automatic detect and install my plug an play printer option then click Next.
Now, Use the drop down arrow to select USB001 then click next.
Select the Manufacturer as HP from drop down list and select DeskJet 990c from printer drop down list. Click Next.
Verify the printer name and set the printer as default then click next.
Do not select print a test page option.
Click on Finish
Click on start then run type notepad.
Write any stuff and then try to print.
ADD A PRINTER IN VISTA
Click Start and click Control Panel.
Click Hardware and Sound then Printers.
Click Add a printer. This launches the Add Printer Wizard.
Click Add a local printer.
Now, Use the drop down arrow to select USB port 001 then click on Next.
Select replace current drivers
Click on Finish.
Click on start then search type notepad.
Posted on Jul 12, 2010
Xerox 7760 Wrong paper size error when trying to print to A4
First your computer selects the printer to output to, so make sure your default printer is selected.
Next, within your printer you may have selected a different page size for output as a default.
The printer it self should allow you to load and auto detect paper size. If this feature is not enabled see if it is a choice.
Also whatever you are trying to print check page setup in the program you are using make sure to ensure they match.
Sep 16, 2016 | Xerox Phaser 7760DN Laser Printer
Load A4 paper in the multi-purpose tray again,and then press [paper] to print. error shown in LBP2900B
If you normally print on letter sized paper, then some program you are using is trying to print on A4 paper (PDF files often the culprit) and the default on most printers is that if they do not have the paper loaded it will ask for it from the MP tray. You can check your printer settings as you may be able to tell the printer to automatically sub letter paper when A4 is requested.
Sep 20, 2015 | Canon LBP2900
How do I reset my SX215 to factory settings
When you are in the application that you are going to print from. Go to the menu bar, click on File - Page Setup. Here you should be able to change the paper size you wish to print out in. If you want to set the paper size by default to A4, then you will need to (Windows7) click on the Start button - Devices and Printers, select the printer that you want to change the paper size, right click on the printer - Printer Preferences, a dialog box appears, select the paper size you want in the paper size drop down list, click - Apply - OK. This should then have set the paper size to A4 by default.
Feb 26, 2015 | Office Equipment & Supplies
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
The irc3080 ask for a A3 paper but in my configuration i put A4 for printing.
ensure that your printer settings are set for A4 paper. not just in the software you are printing from.
if you set A4 in your word processor programme it does not mean that is what will be used by your printer. go to your printer icon and click properties and ensure that the printer has A4 as default paper.
I hope this was useful.
Aug 23, 2011 | Computers & Internet
Always showing the manual feed option when we printing. We would like to set it as automatic printing. How can we do that in default. Please help. We checked all the menus. example: in system set up paper...
If you are in Canada or US then you need to set the default paper size to Letter not A4. Most if not all software you use likely sends the print job in letter format. Because the printer is set in A4 it stops and waits for that size.
Mar 11, 2011 | HP LaserJet 3050 All-In-One Printer
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    Whenever i change paper size from A4 to letter,
    Don't set by using the "Print" option.
    Go to [Start]
    [Printers and Faxes]
    right-click on the HP printer entry
    ! Don't select "Printing Preferences"! from there
    Select [properties]
    Select [Advanced] tab
    Select [Printing Defaults]
    [Advanced}
    (I know, the screen looks the same, but it functions differently this way)
    Change paper size to "Letter"
    [OK, OK, OK]
    *done*
    Sep 25, 2009 | HP LaserJet 4350 Printer
    Hp laserjet p3005dn tray1 manual feed problem
    you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
    Jul 25, 2009 | HP LaserJet P3005n Printer
    Konica Minolta 2490MF - Paper size error
    Need to set A4 size default on the printer driver itself.
    Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
    Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
    Click apply.
    should be o.k.
    Jan 13, 2009 | Konica Minolta magicolor 2490MF Laser...
    HP Photosmart Premium C309A  All-In-One Printer Logo
    456 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
