Question about Sony CDX-F5500 CD Player
Connect my ipod to sony CDXF5510X
I tried to connect the ipod toy stereo using the connecting lead both tocthe aux port(situated at its back) and to the audio in ports(white and red in colour) but i could not find aux option in my source menu, it just changes from cd to fm or vice-versa...... Pls help me out.....
5 Suggested Answers
  • 87 Answers
SOURCE: Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Posted on Jun 03, 2009
  • 6 Answers
SOURCE: sony cdx gt200
I HAVE A SIMILAR MODEL AND I HAVE TO HIT THE SOURCE BUTTON TILL AUX APPEARS MAY BE A RADIO MALFUNCTIO
Posted on Nov 13, 2008
  • 6 Answers
SOURCE: Car audio aux lead
there should be a 'source' or 'mode' button that should switch between CD and AM/FM modes. This button should also swith over to the AUX input.
Posted on Feb 04, 2009
  • 40 Answers
SOURCE: had a new battery put in my car and now when I
push the volume knob button in and hold it down until the psm menu pops up. your display should read "DIMMER" press the track forward button repeatedly until you get to "EXT IN" and then use the volume knob to select it. then hold down that volume knob button again for 4 to 5 seconds and your done
Posted on Mar 17, 2010
My kenwood nv701 does not have bluetooth but has a headphone port at the front. What connection will i need to hook my ipod to my stereo through the headphone port. It also has alota ports at the back of...
You have could use a cable with 2 tulip plugs on one side and a 3,5 mm headphone plug on the other side. Plug the tulip plugs on the back of your Kenwood in AUX, tuner or Tape in, and choose thethat input on the Kenwood and plug the 3,5 mm plug in the headphone port of the MP3 player (iPod)
That is all.
Jan 31, 2015 | Kenwood Car Audio & Video
Tip
How do i connect my iPod to a Pioneer Car Stereo
<p>It is advisable to listen to your iPod through headphones while driving in the car. Not only is it dangerous to completely cancel the sounds of the road as it is often illegal in many cities across the country. There is an alternative, however. In just a few steps you can use your iPod to your car stereo speakers and use the car to listen to your music, podcasts and audiobooks. No brand car stereo makes it easier to connect these beautiful than Pioneer. <br /> <p><br /> <p>1. Connect one end of the mini-jack on your iPod headphone jack. Once done, set your iPod or on your dashboard or your car seat so that it will not tip over while driving. <br /> <p><br /> <p>2. Find your sound system's auxiliary input Pioneer. It is often located in front of the front panel stereo, but can also open the front or back of the unit completely. If the extra connector on the back of the stereo itself, then you remove the panel. When it comes to this, see the instructions that came with your sound system is provided for further guidance. <br /> <p><br /> <p>3. Connect the other end of the cable mini-jack for stereo aux port. This will allow your iPod to the audio signal through the cable to the stereo and the stereo signal will pass to the car speakers. Most often, when something is plugged into the stereo aux jack will work in stereo. In some models a setting to select the additional connection. Whatever the case, now you can sit and enjoy your iPod for that long car ride. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
I just want to fix my ipod on it
I'm glad to provide the instructions to connect an iPod to the Sony Receiver. Depends upon the model, it is possible that the iPod can be connected to a Sony Receiver using a Digital Media Port Adapter. Purchase the Digital Media Port separately, connect the iPod to the Digital Media Port Adapter and then connect it to the Receiver. However, some Receivers are not compatible for connecting Digital Media Port Adapter. In that case, you can connect the Headphone output of the iPod to the Aux/Line input on the Receiver.
Please provide the model # of the Receiver that you're using so that I can provide more information about the specific connections. Thanks for understanding.
Jun 17, 2011 | Sony Audio Players & Recorders
Hey yeah ummm when my like stereo is off I can connect a cord with my ipod and play it... But since the stereo is technically "off" I can not control the volume on it unless it's the volume control on my...
SEEMS LIKE YOU ARE TRYING TO PLUG INTO THE HEADPHONES JACK AT THE FRONT ! NO GOOD . YOU NEED TO HAVE STEREO ON. AND USE AUX. TO DO THIS pLUG IN YOUR MP3 PLAYER WITH 3.5 STEREO JACK OTHER END BACK OF STEREO INTO AUX. RED AND WHITE RCA PLUGS.
THIS LEAD COSTS LESS THAN $7.00 AND THE SOUND IS VERY LOUD THEN. !
I DID IT MYSELF AND AM HAPPY WITH IT .
May 19, 2010 | Panasonic SC-AK320 Shelf System
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
How do you hook up your ipod through the rca cable hookups in the back without the radio still playing?
This is different on every stereo, but generally the RCA ports in the back of the stereo are labeled "Aux" or something to that extent.
First, you must purchase a headphone jack to RCA cable which can connect to both your stereo and your ipod.
Connect the cable, turn your ipod on and start playing a song. Turn the volume on the stereo to a moderate volume so you can hear when the song is being played through your stereo. Then, using the selector switch, turn the stereo from "Radio" to "Aux" or whatever it says next to the the RCA plug ins on the back.
Aug 14, 2009 | Pioneer DEH-2000 CD Changer
No idea how to connect an iPod!
You need to buy an extra cable that connects to the back of the radio, it is ipod ready but you need buy the cable. The front USB port is just for mp3 or mp4 players that you can connect via a USB port.
Jun 11, 2009 | iLO XM-MP3-CD Car Stereo
I have a CDE-9872 and it wont pick up my ipod touch
Add Alpine's optional "Full Speed" connection cable and you'll be able to use the CDE-9872 to control your iPod. -Crutchfields website
This is compatible with first and second generation iPods touch.
fyi- if you have a mini-stereo aux in jack on the deck you can connect a ipod touch compatible mini stereo cable to the earphone jack of your ipod.
Dec 28, 2008 | Alpine CDE-9872 Car CD/ MP3 Player
Connecting an iPod to a HT-Q100 Home Cinema System
If you connect an iPod via USB, the system will treat it as a hard drive and will use its (very basic) on-screen system to display your tracks.
I found the best way to get a result is to use a 3.5 (stereo) jack to RCA phono stereo input into the auxillary input on the back (side). To hear your iPod, select AUX on your Samsung and then select and play on your iPod. Bobs your uncle!!
Sep 18, 2007 | Samsung HT-Q100 System
Sony CDX-F5500 CD Player Logo
208 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
