Ive crackling noises coming from my Oki Microline 395 Printer. What can this be?
    Scholar:
  • 103 Answers
Hardware failure
Posted on Jul 12, 2010
Hit select button to print one line alarm light comes on
what is the light show..........is it for ink or triangle light for warning
Dec 09, 2009 | OKI MICROLINE ML-395 Matrix Printer
Oki Microline 395 install problem
This printer will print with the Windows Generic/Text driver. It can also be set to print with IBM or Epson FX drivers. Follow these steps:
1. Press on the "SHIFT" Button, while holding it down press the SEL Button. The "SEL" Indicator will light up.
2. On the controll pannel, press the "PARK"
Button. The Printer will print a Setup Page.
The last line that is printed will be what it is
set to - ML or IBM or FX.
3. With the "TEAR" button you can set it to
the driver you want.
4. To save the config you selected, Hold the "SHIFT" Button and press the "SEL" button.
The "SEL" indicator will turn off and save the configuration.
Aug 03, 2009 | Office Equipment & Supplies
Oki ML395 printer, paper continues to feed
your paper feed sensor maybe stuck or a piece of paper could be stuck in the sensor.Hope this helps ?
Dezzi
Nov 19, 2008 | OKI MICROLINE 395 Matrix Printer
I have a OKI Microline 320 printer.
Your printer has a damaged mainboard. Very sorry, for yours is a very good unit. the replacement model is the Oki ML-420, which comes with a 3-year warranty.
Be blessed.
Oct 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Microline 395 all lights blinking
You may have a blown logic board.
Hope this helps.
Dezzi
Mar 03, 2008 | OKI MICROLINE 395 Matrix Printer
Problem with oki microline 395
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer4.gif.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print4.gif.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints4.gif, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Feb 15, 2008 | OKI MICROLINE ML-395 Matrix Printer
Printer not printing the top of the characters
Yes quite possible pin broke on head, check ribbon is fitted correctly and has plastic sheild on front of it intact
Jan 18, 2008 | OKI MICROLINE ML-395 Matrix Printer
Problem with OKI ML 395
the lid has 2 small points the holds down 2 censors that indicate when it is off, make sure that there are not broken and that the censors are being engaged.
Oct 31, 2007 | OKI MICROLINE ML-395 Matrix Printer
Printing problems
Someone else may have an exact diagnosis on this, but here is one possibility: The printhead home sensor may be defective. This sensor, either an optical device or mechanical switch senses when the head is in the home or leftmost position. This information is used to determine start point of print. A mechanical switch will be more prone to problems, but often fixed by cleaning it. Again, someone else may have actually seen and diagnosed this problem, and could give the definitive answer.
May 09, 2007 | OKI MICROLINE 395 Matrix Printer
jasbo
jasbo
