Question about Zanussi WJS1397W Front Load Washer / Dryer
The drum is not moving
    Genius:
  • Zanussi Master
  • 1,474 Answers
Could be motor brushes worn check belt on okay first
Posted on Jul 12, 2010
CAN'T GET THE SILVER PLATE IN SIDE THE DRUM IN CORRECTLY. THE DRUM NOW MOVES UP AND DOWN
Take off the outer covers all round the appliance and look at the back of where the screws you put in went, did they go into the correct places firmly?
Dec 15, 2013 | General Electric Profile DPSR610EGWT 7.0...
I have got whirlpool condenser dryer model AWZ541/3 but the drum does not seem to move does the drum spose to move or not
yes the drum should move sounds like the belt has snapped or the start capacitor for the motor is faulty
Regards
Ian
Apr 17, 2011 | Dryers
Np 6412 copy dirty lines length of paper
Sounds as if the drum needs to replaced. How long has it been in the copier? They are supposed to be good for 30,000 copies or one year. It could also be dirty optics ( mirrors and glass ). Drum is easily installed by the customer. Just practice with the old drum - removing and re-installing before using the new drum. Too expensive to damage when installing. **** open the copier, Look under the control panel and you should see two levers. Move the right one to the right - this moves the developer away from the drum. Then move the left one down and this releases the drum for removal. Reverse procedure and power up the copier. It will automatically run and set the new drum settings into the copier.
Dec 08, 2010 | Canon NP 6551 Black and White Copier
Frigidare ftw 647ghso thumping sound in one spot when i manually rotate drum sounds like its rubbing on something
Suspect a bad drum bearing or bent drum bearing shaft. When you rotate the drum, look for movement of the drum up or down while turning. If the drum moves suddenly, suspect the drum bearing. If it slowly moves up or down during turning, suspect a bent shaft on the drum. In either case, it is a major teardown to remove the drum from the outer drum case. If still under warranty, take advantage! Hope this helps!
Mar 05, 2010 | Frigidaire ATF6000ES Front Load Washer
Plastic things inside the drum have all come off,
If they have come off, it is because they are worn or broken.You need to fit 3 new ones
They are referred to as drum or clothes lifters, thier purpose being to move the clothes around.
Do not use the washer until you have got them fitted.
They usually slide and click into the slots in the drum.
Mar 01, 2010 | Indesit Washing Machines
When turned on, the drum makes a grinding noise as
The main bearing may be worn out at the back of the drum allowing the drum to wobble.Reach inside the drum and lift upward. If you can move it up and down this is probably the problem.
Nov 05, 2009 | Whirlpool LER4634J Electric Dryer
Maytag washer spin trouble drums moves from side to side
under the drum is a plastic support that can wear out. it must be replaced. if you do it yourself not too expensive
Apr 20, 2009 | Maytag Washing Machines
Thumping sound
Most likely the rear drum support has worn and dropped down.
Remove the drum and replace the rear ball and cup drum support.
Mar 20, 2009 | Frigidaire FEQ1442ES Electric Dryer
Drum wont move
you should take off the bottom panel on the front of the dryer. there is usually 2 screws on the bottom. from there, you will be able to see if the belt is on and if you move the drum with your hand as you look inside, you will see if the belt is moving like it should
Oct 27, 2008 | Hotpoint Dryers
Zanussi WJS1397W Front Load Washer / Dryer Logo
65 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
