Question about Hifonics Brutus BXi 1206D Car Audio Amplifier
High Pitch Whine from Amp (not speaker)
I have a newly installed Brutus BXi 1206D and I'm hearing a really high pitched whine coming out of the amp. It is not from the speakers, as I've disconnected the sub to check this. The noise is coming from the amp itself. Any ideas?
  • Mossman44 Apr 21, 2008
    I can totally remove the RCA's and the amp still makes the noise. I removed the speaker leads and RCA's, and the internal ringing starts once the amp sees the remote turn on signal.
  • 52 Answers
Make sure your rca andpower/remote wires are ran on seperate side of your maybe recieving some kind of interference from the alternator. try buying higher shielded wiring too
Posted on Apr 20, 2008
  • john wasson
    john wasson Apr 29, 2008
    hm it sounds like there is a current problem within the amp. i would possibly take it back and get another one or just get another one. or try on of your friends to see if the problem continues
Need help finding & solving high pitch whine at mid to high speeds
It sounds like a Bearing is worn in one of the wheels or in the Drive-shaft. Get a mechanic to check it out
Jan 15, 2014 | 1994 Ford Crown Victoria
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
I have a brutus bxi 1206d 1200 watts, and the amp is coming on fine not protected. But there is no sound output. u can hear a small feedback rumble when connecting the input rca's. But thats it. My...
i would check the speaker cables to see if something came disconnected first maybe wire i touching other terminal shorted out the channels output .
run a new set of rca cable to see if one use are bad . check to see if rca cables pluged into right output of radio . check to see if your remote wire is powering up the amp to turn on the amp ..
will still light up with battery power but will never put output to the speakers with out the remote turn from the radio ... how to check this is to disconnect the cable at the amp and take a short 18 gauge wire and strip both ends and touch the battery terminal at the amp terminal one end the other end where the remote wire is mounted on the amp if do this for a few seconds to see what happens or better yet buy a digital volt meter and check for 12volt a the remote wire when you turn on your radio
Dec 23, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Hi, I'm driving a 04 honda accord euro, and I've replaced the old standard speakers with a new one, sorry that I forgot the brand of the it. Recently I heard some high-pitch noise coming out of the...
sounds like alternator whine, can be a hard thing to fix or something really simply. here are some things to try: check your ground at the battery first, make sure it's a good connection on the battery and the bolt it's grounded to on the car, make sure the battery connections are clean, positive and negative. make sure you have a "good" ground on your amp/amps and radio. you can also try grounding the radio and amp at the same location to avoid "ground loops" don't run a long ground from amp, but run a wire from the radio to the amp ground. hope it helps. dave
Oct 05, 2010 | Car Audio & Video
Protect Light Coming On - BXi 1206D
If you actuate the subwoofer by hand, do you hear any scraping sounds?
It's possible the voice-coil is rubbing and tripping the amplifiers protection.
Try the amp on a different sub.
Jun 23, 2009 | Hifonics Brutus BXi 1206D Car Audio...
High piched whine on left front! 2001 dx
hat u need to do is drive vehicle until you hear this pitch once you hear it turn steering to the right to see if whine disappears if it does you are looking at replacing wheel bearing.
Feb 26, 2009 | 2001 Mazda MPV
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection basicaly a large coil of copper can take silcon and put on the effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
RCA Whine, Newly Installed Amp
The shield ground is probably open in the head unit. You can check the shield ground by measuring the resistance from the shield of the RCA connector to the chassis of the head unit. It should be near 0 ohms. Disconnect all RCA cables from the head unit before testing.
If you find that the shield ground is indeed open, the following link has more information for a temporary fix.
Temporary Shield Ground Repair
Nov 18, 2007 | Car Audio & Video
Hifonics Brutus BXi 1206D Car Audio Amplifier Logo
815 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
