Question about Ryobi Three Trimmer Combo
Pcb 3046ye machine starts idles too fast touch throttle then cuts
Pcb 3046ye
  • 1,498 Answers
Hi Ronald,
Not a lot to go on here.
If you are serious about getting an answer, include Make and Model. Describe your problem clearly, concisely and with as much detail as possible.
Often, a problem can be the result of a seemingly unrelated event. It is always a good idea to include a recent history.
Additional information such as what steps have already been taken, has the product ever worked, is it new, etc. can have a bearing on providing the best solution for your particular circumstances.
Remember, you are a key participant in this process. I am not there, you are. I depend on you to be my eyes and ears. I can only respond to what you provide me.
What you get out of the experience depends on what you put in to it.
So help me help you.
Best regards
Mike
Posted on Jul 12, 2010
Have 2000 malibu that idles to fast
Fast idle is often caused by a faulty TPS. Throttle Position Sensor. The computer is not able to determine exactly where the throttle is so it compensates by applying too much throttle automatically to avoid stalling the engine. Just went through this with a delivery truck at work that would run at 40 without touching the gas. Scary ride in a 2 ton truck.
Jul 02, 2014 | 2008 Chevrolet Malibu
How to adj the crab on a poulan chainsaw
if the engine is in good shape..screw in both carb jets adjusting screws till they seat lightly, then back them out 1 1/2 turns, srew in the throttle adj screw a turn and start the motor,,warning if the chain is on make sure the blade isnt likely to touch anything when the engine starts as you will have to have the brake off to get started and adjusted. With the engine running, adjust the throttle srew until it is idling just above shutting off speed, then adjust the "L" low speed jet to get the best idling speed without srewing it in much, reset the throttle srew, then , while trying to accelerate suddenly each time, open the Low jet a little at a time until the machine accelerates smoothly without hesitation. Reset the throttle srew to a position that the chain stops running at idle and check again that the acceleration is without hesitation ( usually with "L" jet about 1/4 turn out more than best idling). The high "H" jet can now be set to give the best power while cutting a block of wood.
Jun 29, 2014 | Poulan Garden
Ryobi C4620 chainsaw idles too fast
I had this same thing . Its in the throttle cable tube. take the cable away from the carb. cut about 1/4 in of the tube around the cable off reattach to carb it works for me!
Apr 23, 2014 | Ryobi DOUBLE D - CARB ADJUSTING TOOL...
My husqvarna 254 run great but she idle too fast ,ill set the low needle and when i set the idle one nothing chang
Machines that idle too fast and eill not alter with the idle screw either has the throttle butterfly on the throttle spindle loose and sticking, or the machine is drawing in air through a crank seal or gasket.
Jan 18, 2013 | Garden
Husqvarna starts but cuts out if not on full throttle
There is a screw that allows you to set the Idling. Take the top off so you can see the carb. Without starting it play with the throttle trigger you will see a shaft move in the carb, the shaft will probably have some small attachments on it. Identify the screw that acts as an "end stop" when the throttle trigger is released. Once you have found the idle screw you can start the machine and turn the screw in slightly. Set it so that the machine idles but not too fast or the cutting chain will start running.
LPG
Sep 10, 2012 | Husqvarna Garden
Hit the throttle it quits running . it starts right up fast idle ok cuts good .wide open throttle runs fine. let it idle and hit the throttle it dies, starts right back up. has new carb kit, fuel, spark...
Conected to the rubber induction boot is the impulse hose, it is a short curled pipe, make sure this has not split and is conected to the two nipples on the carb flange.
Aug 21, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
BRAND NEW ECHO CS-600P HARD STARTING, HAVE TO PULL THE RECOIL LIKE 20 TIME BEFORE IT WILL START.
Are you pumping the primer bulb until fuel flows into the bulb, setting the choke, and the fast idle is being set? Set the choke at half position after the first 'pop' and don't touch the throttle until it starts running. If you are doing these things per the instructions, take the machine back for warranty adjustment. Hope this helps!
Nov 03, 2010 | Echo CS600P Gas Chainsaw 20 Inch
Ryobi PBC 3046YE strimmer starts but cuts out when speed control
A lack of acceleration in these units is most likely a fuel delivery related issue. It may possibly be time for a diaghram kit or carb rebuild kit to be installed in your carburetor. Ethanol in the gas deteriorates the parts that accomplish the acceleration procedure and may need to be replaced as they don't function anymore.
Many other things can affect these little machines as well such as clogged air filters, clogged crank case vent, clogged mufflers/exhaust ports./ spark arrestor screens...but more often than not, your problem is a carburetor issue.
Please look at the troubleshooting section on this Zama site PDF file
http://zamacarb.com/pdfs/TechGuide_2007.pdf
Jul 09, 2010 | Ryobi Garden
My ryobi pbc-3046YE brushcutter wont run. When I start with choke it races for a few seconds then cuts out, if I get it started without choke it idles briefly then cuts out, if I try to accelerate it cuts...
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 09, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Idol runs fast after starting vehiicle
the idle air control valve is stuck,or there is a vacuum leak.check the vacuum lines,the throttle cable is not sticking and the idle control valve which is on the side of the throttle body and the throttle position sensor.check all the plugs on these for a good connection.
Jul 13, 2009 | 2003 Chevrolet Venture Passanger
Ryobi Three Trimmer Combo  Logo
147 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
