Question about Asrock K7S41GX Motherboard
Don't boot up and when it does after a couple of minutes it boots again by itself and keeps doing that constantly.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 32 Answers
It sounds like you have a problem with your RAM. Remove the modules and insert them, testing one at a time. Before inserting them back into the motherboard, you can try cleaning the contacts with an eraser that erases ink from paper.
Also, you can try re-seating the cards connected to your motherboard, cleaning them first as indicated above.
Posted on Jul 12, 2010
Digistream box stuck on boot
Power it off, leave for a couple of minutes and power on again. If still no boot, hdd error if recordable or power supply issue.
Jun 17, 2015 | Computers & Internet
D780 not booting
Remove battery for a couple of minutes and try again
Dec 13, 2013 | Samsung D780 Cellular Phone
I keep getting booted out of castleville and have to refresh every minute or two, How do I fix this?
Well it must have a lot of problems because it does that when I'm on chefville and Hidden Choricles also!. Constantly!!!
Oct 15, 2012 | zynga.com
Hi, I have a laptop Compaq A945 US with Windows 7 installed in it. I am facing a serious problem these days as my laptop shut down automatically while doing my work. It happens after 10-15 min on first...
dear..
i think you should re-install your laptop, maybe the system has an error because some files are missing, it can be happens because of viruses, to re- format your os you can click one time restore..just turn on or reboot your laptop and quickly press f11 button on your keyboard, but no data will save when you do this, so you need to back up your data first, so you don't lose your work..
if one click restore couldn't be done, you need to prepare a bootable windows cd. to install windows from cd you need to change your boot set up, press f1 when you turn on your laptop, go to boot menu change your first boot to cd room and the second boot to hard drive, enter the windows cd, press save and exit, when appear a message "boot from cd or dvd" quickly press any key, then you can follow the instruction that appears on your screen..
May 19, 2011 | HP Compaq Presario A945US 17" Notebook PC
Laptop locks up constantly, even during boot from HDD or CD.
Don't upgrade the OS. Try upgrading your RAM. This should the computer to process more and therefore stop it freezing as much. Also don;t run too many programs at once. If you are looking to keep a laptop for the furture invest in a new one. go to http://www.crucial.com/ fo RAM.
May 03, 2009 | Computers & Internet
Boot up menu restart; will not power
Boot up to the safe mode screen & select last known good configuration.
Jan 15, 2009 | Gateway 4026GZ Notebook
Laptop boots then shuts automatically off
If you haven't tried it yet, pull the battery out and try booting from the adaptor only. If it boots normally, then your battery pack may be bad (shorted cell) or the regulator that has the job of charging and monitoring the battery pack while keeping your system running may not be healthy.
If you own any multimeter (at the cost of Chinese DMMs, everyone should own one), check the battery pack for charge. Under normal conditions, they should measure a couple of percent higher than their rating. You will have either Lithium Ion or Nickle metal hydride batteries in the pack so should measure some multiple of the nominal cell voltage of one of those types that are respectively 3.6 & 1.2 volts.
Nov 28, 2008 | HP Pavilion dv9000z Notebook
Constantly reboots itself
The Gateway GT5220 has an AMD Athlon 64 processor. It has been documented that Windows XP SP3 doesn't play well with some AMD CPUs. I'm pretty sure this is one of them. I would suggest attempting a system recovery using a restore point on a date BEFORE you installed SP3. If that doesn't work, you might consider recovery using the original Gateway Restore CD. It will likely wipe the system, but that might be the only choice.
I would NOT start with the total reload option. We have a couple others before you get there, so try the restore point and then let me know the results. We'll go from there...
Regards,
Char1ieJ
Nov 04, 2008 | Gateway GT5220 PC Desktop
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
Can't boot up laptop
If your Usb port works, then the mobo is working, so possible graphics problem. Try booting up in safe mode(normally pressing F8) on boot up then highlight 'start windows in safe mode', to see if Windows will load with only minimal drivers, if so restart again, pressing F8 again, but this time highlight 'start windows with last known good configuration' Doing any of these 2 things can be done in any order, either last known good config first or safe mode.
Oct 21, 2006 | Compaq Presario 2140US Notebook
Asrock K7S41GX Motherboard Logo
117 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
