Question about Sharp AR 163 Copier
H200 in copier sharp ar163
I read your solution and i need to know what is simulaion 14 is?
where can i find details for this problem ?
  • 1,498 Answers
Hi there Hava,
I'm in the same boat as you. With potentially thousands of problems for each product, and thousands of products, we need a little more from you.
If you are serious about getting an answer, include Make, Model and in this case the expert and date of the solution.
(Re)Describe your problem clearly, concisely and with as much detail as possible.
Often, a problem can be the result of a seemingly unrelated event. It is always a good idea to include a recent history.
Additional information such as what steps have already been taken, has the product ever worked, is it new, etc. can have a bearing on providing the best solution for your particular circumstances.
Remember, you are a key participant in this process. We are not there, you are. We depend on you to be our eyes and ears. We can only respond to what you provide us.
What you get out of the experience depends on what you put in to it. So help us help you.
It would be also be advantageous in your case to repost your problem so that it starts over at the top of the queue.
Best regards
Mike
Posted on Jul 12, 2010
Sharp AR163 copier RESET CODE ERROR FOR F2 — 04 solution
check the toner cartridge if third party replace with OEM
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 02, 2015 | Sharp Office Equipment & Supplies
Sharp AR163 copier CODE ERROR F2 — 04 solution
check the toner cartridge if 3rd party replace with OEM
Sharp AR163 CODE ERROR F2 04 solution
replace toner cartridge if third party with oem
Error u2 ar163
EEFROM read write error.Clean motherboard
Apr 17, 2014 | Sharp AR 163 Copier
What is the meaning of f 5 error code in sharp AR163 PHOTOCOPIER
F5 is exposure lamp problem, to fix this problem try these solutions:
Solution1: switch off and on the machine.
But if this is not working try solution2
Solution2: Step1: Press continuously Clear key then Interrupt key then Zero key then Interrupt key
Step2: You are inside the simulation if the display turns off but if not do again step1.
Step3: Press 14 then press print button
Step4: If not canceled try step1 to step2 again then press 16 then press print button
But if this is not working try solution3
Solution3: try to open the platen glass and clean the mirrors and also the bottom side of the platen glass especially the white correction plate then apply solution2.
Mar 03, 2009 | Sharp AR 163 Copier
SHARP AR163 Displaying H2 error code
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Dec 11, 2008 | Sharp AR-163 All-In-One Laser Printer
Communication error
I assume this is a sharp??????????
U2 Backup memory problem
Aug 25, 2008 | Office Equipment & Supplies
Error h200
H2 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR 5320 error h200
H4 indicates there is a fuser error.
enter 14,
Hope that helps...
Lbcoaster
60 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
