Question about Ricoh Aficio 2027 All-In-One Laser Printer
Scanner Error code 36851: noresponse from scanner
I receive an error when trying to scan a document. Error code 36851: noresponse from scanner
5 Suggested Answers
  • 5 Answers
SOURCE: problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Posted on Jul 22, 2008
SOURCE: scan gear error code:22500
Check Cannon support site, it has all solutions. Good Luck
Posted on Feb 19, 2009
SOURCE: Canon PIXMA mp240 All-in-one InkJet Printer. Error code: 2,140,2
I had exactly the same problem (error Code:2,140,2) in Canon PIXMA MP250, and it was solved when I replaced both ink cartridges which were almost empty (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
Posted on Jul 27, 2010
  • 1751 Answers
SOURCE: I have error 36851: No
Hi
You need to replace your cartridges with new ones
Posted on Nov 25, 2010
Error 36851: No response from scanner" ricoh
Dear kishorkamble,
We fixed this error, which happened in another model (Aficio MP-5500), by configuring two options:
1. Activating SNMP protocol. Menu Configuration -> Network -> IPv4
2. Activating RSH/RCP protocol. Menu Configuration -> Network -> SNMP
I hope it may be useful.
Yours sincerely,
Bruno Coutinho
Feb 07, 2011 | Ricoh Aficio 2018D All-In-One Laser...
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Error message code 2,140,0
I had a similar problem (error Code:2,140,2) in Canon PIXMA MP250 all-in-one, and it was solved when I replaced both ink cartridges which were in low ink (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
Mar 16, 2009 | Canon PIXMA MP240 All-In-One InkJet...
I can not use the scanner, Ricoh Aficio 1515. I alredy instal the twain driver ver.3 from the original cd, when I open the function palete, looks like its conected with the machine, but when I try to...
Visit the Ricoh download site and download the latest driver. This will ask you if you wish to overwrite, say yes. Hopefully this will replace the corrupt file.
Aug 01, 2008 | Ricoh Office Equipment & Supplies
Scan gear error code:22500
Jul 26, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error code 2806:0000
your scanner soft has problem try to another driver install it try to scan
Jul 10, 2008 | Acer ScanPrisa 640P Flatbed Scanner
Problem in scanner when scan
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2027 All-In-One Laser Printer Logo
874 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
