Question about Cars & Co Cars and Co 196070s Prefo Dresden Rare Skoda Truck Slot Car Pair
What is the name of the oil filler cap houseing which has a pipe that links to the throttle valve as the base of mine has broken of, i have retrieved the bottom section from the cam houseing, i have a skoda octavia 1.6 2001 Y reg
  • 31 Answers
Nun
Posted on Jul 13, 2010
2003 Honda Civic LX code 1457 HELP
Error Code: P1457 Description - Evaporative Emissions Control System Leakage.
Causes:
- Fuel is filled with the engine start.
- Missing Fuel cap
- Wrong fuel filler cap is used
- Fuel filler cap seal is leaky.
- VSV Valve connector near air filter box is detached or wire broken.
- VSV Valve vacuum pipe near air filter box is detached.
Jun 01, 2015 | 2003 Honda Civic
Where is the filler cap located in my bmw 325i 2002 model
Your question did not specify what "filler cap".
The above response from FTjoe is for the power steering filler cap.
The following RealOEM link is for the engine oil filler cap (Item 4) which is square and black and is on top of the engine. It goes through the plastic cover into the cylinder cover
http://www.realoem.com/bmw/showparts.do?model=ET37&mospid=47720&btnr=11_2172&hg=11&fg=15
The engine oil filter housing cap (Item 3) is shown below:
http://www.realoem.com/bmw/partgrp.do?model=ET37&mospid=47720&hg=11&fg=30
Oct 10, 2014 | 2005 BMW 325i Automatic
When i take off oil filler cap on my bmw it makes engine go lower on revs and then sometimes it cuts the engine when i puit it back on
This is typical of the BMW, the name for the part to be replaced is under many names from BMW it either called Oil drain back valve.Crankcase oil seperator or better yet they should stick to the name PVC vavle,When this valve rupture internally either two things happen you burn and smoke oil like crazy,or you get strong vacuum in the crankcase as you are experiencing. The valve is located under the intake toward the front of the engine to remove you will need to remove the throttle body,8_12_2012_4_17_26_am.jpg
Aug 11, 2012 | Cars & Trucks
I have a 54 plate golf tdi it wont start but when you take the oil filler cap off it starts but you have exhaust smoke comeing out the filler cap hole ive already stripped the egr valve and cleaned it any...
Hi there?
It sounds like the EGR valve is stuck open letting the exhaust fumes enter the engine. Since the exhaust smoke has no oxygen then the engine won't start whout oxygen (fresh air). Disconnect the pipe going to the inlet manifold and see if the engine starts. If it starts then you need a new EGR valve.
May 21, 2011 | 2004 Volkswagen Golf
1990 regal starts, runs for 2 to 3 min then dies, changed fuel filter, crank sensor, coil packs, it has 45 pounds of prs. to rail. im stumped
hi, please check you oil level, ( on level ground). when the car is running place an old rag in front of you and take off the oil filler cap (be careful not to get near the fan, fan belt) if no oil comes out of the filler hole possible fault: oil pick-up pipe (in sump partial block), / oil filter in sump ( blocked), oil pump worn, oil relief valve (returning oil back into the sump), spring weak / broken. the (E C U) ENGINE CONTROL UNIT has many sensors that can stop the engine: but try cleaning the (EGR) ENGINE GAS RECIRCLING VALVE, this valve recycles gas back in to the engine, ( must be CLEANED with BRAKE FLUID) this is a VERY DIRTY job, as this gets block with carbon (EXHAUST PARTICULES). the E C U will detect all of these sensors: the (ECT), TOP OF ENGINE engine coolant temperature sensor rough tick over, (HO2), EXHAUST DOWN PIPE, heated oxygen sensor checks mixture of fuel, can adjust air / fuel, it tries to keep car going / may flood engine. (M A F) mass air flow, adjusts fuel / air retio this sensor can so much fuel to the engine it may flood it. flooded engine mean WET spark plugs. i would put it on dianostic machine to check these out before paying for extra sensors. gerry
Sep 08, 2010 | Buick Regal Cars & Trucks
WHILE DOING AN ENGINE OIL CHANGE I DRAINED THE AUTO TRANS FLUID BY MISTAKE. HOW DO I RE'FILL THE TRANS ?
Fluid Level Checking & Filling To Check:
  1. Connect a scan tool to the vehicle to read ATF temperature. ATF checking temperature should be 95° - 113°F (35° - 45°C).
  2. Start the engine.
  3. Raise and safely support the vehicle.
  4. Place a drain pan under the transmission.
  5. Allow the ATF temperature to reach 95° - 113°F (35° - 45°C). Automatic transmission fluid inspection plug vw-07-00-7273.gif
  6. Remove the inspection plug from the transmission housing. Fluid is pipe will run out. If fluid continues to drip out, no additional fluid is needed. If only the fluid in the overflow pipe runs out, additional fluid is needed.
To Fill:
  1. Pry the cap from the filler pipe. The cap locking device will be destroyed during removal.
  2. Pull the plug from the filler pipe.
  3. Add fluid slowly with VAG 1924 or equivalent until fluid runs out of the inspection hole. Install the inspection hole plug.
  4. Install the plug in the filler pipe and secure with a new cap.
Aug 17, 2010 | 2003 Volkswagen Jetta TDI
Water not circulating through engine
Does your engine overheat? Could be a thermostat that is stuck, let me know with some clarification and i can help ou better. Thanks
Dec 17, 2009 | 1998 Buick Century
Oil coming out of engine oil filler cap even though i have changed oil filler cap
The engine breather pipe seems to be blocked.
It may also damage the oil seals.
Oct 27, 2009 | 1992 Volvo 940
Replacing fuel filler neck on 2000 Crown Vic
Good news, no the tank doesn't have to come down. However, there needs to be less than 3/4 tank. Jack it up and set on a jack stand, remove the wheel, four screws housing to pipe, filler pipe sensing hose from filler pipe, screw retaining the cap, four retaining screws from filler pipe, screw from filler pipe retainer, slide into the tank until it can be rotated and pulled out through the fender. lube the tank grommet with clean oil and reverse the removal for install.
Aug 21, 2009 | 1996 Ford Crown Victoria
2004 and 2001, are parts interchangeable?
Yes they are as long as the Motors are Similar.
Jan 22, 2009 | 2004 Ford Crown Victoria
Cars & Co Cars and Co 196070s Prefo Dresden Rare Skoda Truck Slot Car Pair Logo
51 people viewed this question
Top Cars & Co Toys Experts
Tom Chichester
Jim Snideman
Jim Snideman
Level 1 Expert
Are you a Cars & Co Toy Expert? Answer questions, earn points and help others
