Question about Philips 105S51 15" CRT Monitor
Screen not appear,no Oscillation & no F.B.T on
My Philips 105e Monitor gives smell & Suddenly Screen Disappear ,When i removed back Cover 2 Resistance(22k & 14.5k) burn near F.B.T i changed her but no results come, IRF9620 & TIP122 are ok . I can't understand whats the problem, Pls help me , may be F.B.T not work Properly .Horizental out put also ok.
Thanks
Check the boost voltage.may be there is a short in -160v.
-prabakaran-
Posted on Jul 12, 2010
I have this Philips monitor that seems to share the problem of the "vertical' line going across the screen, followed all advice but problem keeps coming back
If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 25, 2018 | Televison & Video
Horzontal picture shrinking
The monitor is "dying". Since it's only 15 inches, and since it's a CRT, it's time to responsibly recycle the monitor, and buy a new, 17" (or larger) LCD screen.
Nov 17, 2009 | Philips SoHo 105E 15" CRT Monitor
Screen become red
verify if monitor cable is plugged correctly in computer
Jul 24, 2009 | Philips 202P40 22" CRT Monitor
Philips 105E
I have philips monitor 107E there is a supply problem i want to repair it. I need circiut diagram for repair.
May 28, 2009 | Philips 107E61 17" CRT Monitor
How to open the back cover of the LCD monitor
Hi..there,
It's seems you got a backling inverter busted. Need to replaced a new one or repaired it. To repaired you need to replaced a bad capacitors with a bulged on top of each caps. Not sure...just replaced all the caps...:) Ok! to open the back cover, there are 2 types to open it. First unscrew the 4 corner screws. If there are some... First type it from the back. After you had removed all the screws. Get a good grip on the bottom R/H side with both hands pulling as hard as you can on the 2 joints. 2nd type from the front bezel. Laid your monitor screen upward and placed a piece of clothes to proctect the screen from smudged. Used 2 hands to lifted up the edged of a bezel...do the same on the other side... After that just removed the screws...and that's how to open the front and back cover... Have a nice day!
Oct 13, 2008 | AOC LM729 17" LCD Monitor
Problem with data cord
Change the data cord if not repaired then change the monitor ,give another companies monitor
Aug 26, 2008 | Philips 105S51 15" CRT Monitor
Volume control appears on screen uncommanded and cannot be sent away
I had exactly the same problem. The volume up button was constantly on, causing the on screen display to be permanently displayed. Here is the solution to fix it. This will also work for any other front panel buttons that are misbehaving.
Note: If you monitor is still under warrantee, don't try and fix it yourself - just send it back.
If you open your monitor you will find a small circuit board with a row of microswitches mounted on it. This is the circuit that's causing the problem.
To open your monitor you will need to remove the stand (one plastic cover that unclips by hand and 4 screws that can be removed with a philips screwdriver). This will then reveal two additional countersunk screws that need to be removed.
You can now remove the front cover. There are 4 clips at the base of the cover that can be removed by hand. You then need to pry the cover off, starting at the corner next to the power button. This is really quite stiff and you need to use a reasonable amount of force. Don't worry about the loud cracking sound as each clip along the side releases.
Once the cover is removed you will see the circuit board with the microswitches staring you in the face.
This board needs to be replaced but if you want to fix the problem immediately here is what I did.
Disclaimer - Proceed at your own risk from here on in.
Plug your monitor back into the power and reconnect to your PC. Make sure it's on and still showing the same problem.
The curcuit board unclips and there is a 7 pin connector that also can be unclipped. Remove the board and undo the connector. You don't need to switch off the power.
After the board has been removed for a few seconds, the on screen display that was permanently visible should disappear.
Now I temporarily disabled the malfunctioning button by bending the associated pin on the connector 90 degrees and then reattaching the connector.
How do you know which pin is associated with which button. Trial and error. Simply bend down a pin, and reattach the connector. If the problem persists, unplug and try the next pin.
When you've found the correct pin, straighten the others and reattach the connector.
Clip the curcuit board back in, making sure the connecting cable is clear and doesn't get pinched.
Reassemble your monitor and you're good to go.
The next step is to order a new circuit board from Philips. These should be really cheap (I hope) and you now know how to fit it yourself.
I'm going to try ordering one tomorrow.
Mark Gladding
Aug 03, 2008 | Philips 190B6CB/27 19" LCD
Monitor display problem
there is a problem in the vertical , change the ic please
Dec 17, 2007 | Philips SoHo 105E 15" CRT Monitor
The OSD Main Menu button keeps popping up every 5 seconds and whenever I exit it always takes me back. I've searched everywhere and found no solution just more people with the same problem so if I actually...
f1703 monitor >> too simple!!! Unclip the front cover that sits around the front screen. >Becareful not to break the clips.>Remove the adjustment 715L1009-1-B (MANNEQUIN KEY BOARD) it has 2 screws and unclips from opposite side of the board. >> Clip back the surrounding cover.
Job done, no more OSD MAIN MENU ON YOUR SCREEN.
And you do not need to replace the board, your monitor will work just fine.
Nov 29, 2007 | HP Pavilion F1703 17" LCD Monitor
No display
as your power supply is ok check hor. section if it becomes ok you will get voltage on g1 &g2.
Aug 16, 2006 | Philips SoHo 105E 15" CRT Monitor
Philips 105S51 15" CRT Monitor Logo
145 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
