My Number 9 key fell off i can still use it but want the peice back on i have the cap and the 2 white peices please help!
  • 3940 Answers
SOURCE: B key on my Dell Latitude popped off
Generally, once a key pops off a portable keyboard the keyboard needs to be replaced. It is pretty simple to replace and not too expensive.
Here is an example of a replacement on Ebay:
http://cgi.ebay.com/NEW-KEYBOARD-DELL-8500-500M-Latitude-D505-D600-D800_W0QQitemZ250338315590QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item250338315590&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
To replace the keyboard, just remove the hinge cover, take out the screws for the keyboard and lift the keyboard to release the cable connector.
Posted on Jan 04, 2009
jtbjtb
  • 135 Answers
SOURCE: Water leaking from white plastic peice under washer
If this piece had 2 hoses attached and slides onto the motor, then it is the pump. you will need to replace it. Part # 3363394 available both new (27.99) and used (9.99) from timerking.com Hope this helps!
Posted on Jan 07, 2009
nalin_elliot
  • 224 Answers
SOURCE: Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Posted on Jun 23, 2009
al_kupchella
  • 843 Answers
SOURCE: pulled of doorknob, all the peices fell out and
If this is an inside door from an old house, just take another one apart very slowly to see how the pieces fit. If this is an an outside door from a newer house, you might want to just buy a new lockset and follow the directions carefully. I assume you took it apart because it wasn't working anyway.
Posted on Jan 19, 2010
SOURCE: colors;flag is blue,white & green
Yes thats right. There are a correct sequence. Must be (from left to right). The piece whit out color, the pink piece, the green piece and the yellow piece. If the color wheel have more than four pieces, reapet the sequence.
Posted on Jun 18, 2010
Rusted metal peice fell off undercarriage of my car
it was an exhaust hanger bracket, thro it in the trunk and one day when the flex pipe rotts thru get the nice guy who is fixing the exhaust to weld it back on!!!!
Feb 03, 2012 | 1997 Chevrolet Lumina
The white small peice that spins falls out and dishes are still dirty
Sounds like you have a fridgedaire dishwasher. The plastic peice that the propellor snaps into. Need complete model number for part.
http://www.searspartsdirect.com/partsdirect/index.action
Put in the complete model number.
If you need further assistance please contact.
Jul 27, 2011 | Dishwashers
The backspace has come off on my desktop toshiba 3000-242 and the white peice has been detacted from the buton they are 2 white peices a long white peice and small peice with a thin part at the bottom the...
It is hardly worth worrying about at new keyboards are for sale at extremely cheap prices.
There are replacement keys available on ebay as a kit. Have a look.
Jan 23, 2011 | Computers & Internet
I took screws out of cpu fan to clean fan , retainer peices fell out that you mount fan too. I do not know how to put retainer peices back in place so i can mount fan back on.
All you need to do is to turn locking screws anticlockwise.
This should solve your problem.Best of Luck.Please rank me appropriately. If you want any clarification, Please get back to me
Sep 20, 2009 | Compaq Presario 5000 PC Desktop
Broken brake line
Fixing a brake line is not hard, but first the question is where is the line broke... If the line is broke in the rear of the car or truck sometimes it is best to just replace that short peice of line with the screw in fittings on both ends.. On the rear of most cars and trucks the line runs to a tee and out of both sides of the tee a shorter line runs to each rear brake...You can find them at a ford dealer and the line will be bent to the shape of the line you are replacing with the two fitting on both ends.. sometimes its much cheaper to buy from auto zone or advanced auto parts..They also sell lines with fittings in bulk, so if you know how long and the size of the fitting they will give you a peice of straight line with the fittings on the ends and you have to put the bends in the line where needed... NUMBER 2 If the the line is broke on the long straight run from the front of the car or truck that runs back to the tee theses can be fixed with a compresion fitting.. This works great if you only have a pin hole in your line and cost only a few dollars... You will have to cut the line on both sides of the pin hole about a 1/8 inch and slide nut cap on first and next slide on the line ball on the brake line this has to be done on both sides of the broken line.. next is the center peice of the compresion fitting, gently pull the line apart enough to slide the center peice overthe cut line, now the same has to be done to the other side ... Once the the center peice is in place on the cut line slide line balls and nut caps to the center peice start to thread your nut caps on to the center peice tighten..
Sep 16, 2009 | 1994 Honda Accord
      3. Close the ADF.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Jan 07, 2009 | Roper RAS6233KQ Top Load Washer
Fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Jun 21, 2008 | Conair GMT182CS
Kenmore super capacity 3.5 front loading washer
it may be locked. hold the "options" and "select" buttons down together for 3 seconds.
Dec 16, 2007 | Washing Machines
Suddenly lost the function of displaying menus icons in my digital camera model nikon coolpix s3
a peice fell off of the back cover connector. it is a pain to put this peice back on if you can find it.
Oct 19, 2007 | Nikon Coolpix S3 Digital Camera
Computers & Internet Logo
Alun Cox
David Payne
David Payne
