Question about Samsung Omnia Cell Phone
Omnia 2 charging problem
My omnia 2 is not charging from its original working charger. It can only be charged when I connect it to my laptop via usb.
  • 4 Answers
I have the same problem with mine, It charges fine when its turned off and plugged into the wall charger but dussnt recognize the charger when its on. kinda retarded. Could be a manufacturing fault thats coming up now =(.
Planning on sending it in coz its still covered under its warrenty. I suggest you do the same if yours is, otherwise u might just have to charge it from the usb port from now on... kinda dissapointing from samsung, thought they wouldve defntly got everything together after the original omnia failed so much
Posted on Sep 26, 2010
I have a problem in Samsung omnia B 7610.When I plug in the charger to power source it displayed the battery is full.When I plug out the battery is low and uncharged.Pl help
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 05, 2011 | Samsung Omnia Cell Phone
My Samsung Omnia 2 is not charging.....pls help me...
try with a different charger... if it is not charging still then the charger IC might have gone, replacing the charger IC will fix the problem
Apr 20, 2011 | Samsung Omnia Cell Phone
Can i use Samsung omnia i900 windows phone as a modem to connect to intenet?
1. install the Samsung Omnia modem driver on your Windows PC - can be found @http://www.samsungmobile.com/promotion/omnia/fr/sub02_xp.jsp
2. if you have installed Active Sync on your Windows PC then make sure that before you connect your mobile device to PC you disable "Allow USB connections" from the Active SyncOption menu
3. after you connect Samsung Omnia to PC, on your mobile device go to START->PROGRAMS->INTERNET SHARING and select the connection type (bluetooth or USB - most commonly used would be USB); tap "Connect". Your Samsung Omnia will connect to the mobile network if you have set up a profile for GPRS/HSDPA according to your billing plan provided by the network operator.
Feb 27, 2011 | Computers & Internet
The socket from which chargers are connected has broken , so it does not charge
CHANGE YOUR CHARGING SOCKET
AND CHARGE YOUR PHONE ON ORIGINAL CHARGER..............
Oct 22, 2010 | Samsung Omnia Pro B7320 Smartphone
I have problems changing my samsung omnia i900's housing.any body knows how to do it?
Try to check if the phone's charger is good and working or not. If it is, it might be that your charging port is damaged. You will need to change it.
May 10, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
Omnia malfunction plz plz plz help
Have you done a reset ? small pin hole at top of phone next to on/off button
Aug 24, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Jul 16, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
Jul 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
I900 Omnia dead after removing battery
Do you have any update with your omnia yet ?
Considering charging battery for a while would be a option but in case did not work out ?
www.omnia-repair.com
Jun 09, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
How to change i900 language from Greek to English.
1 : Download & install latest version ActivSync 4.5 for XP ActiveSync 4.5
2 : Download samsung omnia os ZHHH2Z < full update Hong Kong English tested by me
3: Press the 'dial' key to the left of the optical pad to bring up the dialer
With the onscreen keypad input *#1546792*#
Select 'Preconfiguration'
Enter code *#81230*# and select OK
Select 'Hong Kong', with the default Operator
Accept this, DEVICE WILL HARD RESET<(credit goes to modaco forum Paul for this tips)
4 : open i908ZHHH2_ENG from download folder
5 : Turn off the omnia
6 : connect the omnia to a pc using the usb cable
7 : turn on the omnia
8 : click start button if the device found
9 : wait for job done massage
Originally posted by Ramjan from Bangledesh
Feb 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Samsung Omnia  Cell Phone Logo
682 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
