Question about Peg Perego John Deere Gator HPX Ride on Toy
Just bought a jd Gator used and the shifter wont stay in reverse can you make a suggestion as to what might be wrong without starting disassembly...when it's pushed to reverse gear it slowly slides back into first gear
    Genius:
  • Peg Perego Master
  • 1,508 Answers
That is how its supposed to work, you have to hold the shhifter down to go into reverse
Posted on Jun 14, 2012
5 Suggested Answers
SOURCE: kids john deere gator shifter won't go into reverse
I took the shift assembly apart. The switches weren't set in right. Once I put them in the shifter lined up and it works fine
Posted on Mar 20, 2009
  • 156 Answers
SOURCE: gator will only drive in reverse
I would replace the reverse switch as seen in here http://www.shopjandl.com/mepu0003.html and also the high low switch for this peg perego gator.
Sometimes the high/low switch will cause it to not go in reverse, so I would replace both switches in the shifter just to make sure.
They are really easy to replace. You can call these guys http://www.shopjandl.com/.
They know what they are talking about because they sell and repair them.
Posted on Apr 08, 2009
  • 8 Answers
SOURCE: Won't go forward, only in reverse
You need a forward/reverse switch, most likely.
http://www.rungreen.com/john_deere_peg_perego.html
You can replace the whole shifter for $28, but the switch may work fine.
Posted on Aug 04, 2009
  • 156 Answers
SOURCE: Gator doesn't go
I had a green gator model and replaced the switches in the shifter and that fixed the problem. I found them at
http://www.mypegperegoparts.com/switches.html
I also have called them before at 1.801.655.0800 for other help on these toys and they were very helpful
Posted on Jul 08, 2010
Have a new battery, only goes forward very slow, but in reverse goes fast then slow. does anybody ave an idea what may be wrong?
sounds like switches reversed, remove the shifter and swap the two switches. the for/rev is a spring loaded switch, the hi/low will stay on either position on its own.
good luck!
Dec 20, 2010 | Peg Perego John Deere Gator HPX Ride on...
We just picked one up used> it wont "stay in reverse" are you supposed to hold down the gear shift while reversing? Also, how long should it charge for?
yes you have to hold down the shifter to go in reverse, 1 hour for every ah that the battery is, so if its a 12ah battery then charge it for 12 hours
Sep 13, 2010 | Peg Perego John Deere Gator HPX Ride on...
Cannot put in reverse
you have to manually hold it down to go in reverse, probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath you can order a new one here www.powerwheelsoutlet.com
Jun 10, 2010 | Peg Perego John Deere Gator HPX Ride on...
Jul 11, 2009 | Peg Perego John Deere Gator HPX
John deer power pull only works in 2nd
The shifter should come with the switches. I know you can also purchase the switches sepearalty to save a little money at this link.
http://www.shopjandl.com/mepu0002.html
If there are other issues with it, I bet they will be able to help.
Hope this helps
Apr 10, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
201 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
