Question about Samsung SyncMaster 920NW Monitor
Hi I Got a Samsung SyncMaster 920NW the display
Hi I Got a Samsung SyncMaster 920NW the display switch on and then after a few second switches off again.what normally causes this
  • a_c_s Jul 12, 2010
    i know it a power supply problem i need the daigram to fix it. Can anybody help me with one
It seems like Samsung LCDs (TVs and monitors) manufactured between 2005-2008 have this problem. It is a bad capacitor on the power board.
Please see this link (last post) for more info: http://www.videohelp.com/forum/archive/samsung-lcd-tv-32-quot-fullhd-won-t-turn-on-t374268.html
Posted on Jul 16, 2010
  • 32 Answers
If you are saying that it powers off in a few seconds you most probably have a bad (internal) power supply.
Posted on Jul 12, 2010
Green and red screen on Samsung SyncMaster 920nw
Replace the video cable or hdmi,depending on which you may be using. Some of the small wires in that cable may have snapped. Another suggestion is to take it into a repair shop that gives free examinations or diagnosis, because one of the small leads going from the screen to circuit boards lining the display, may have broke, unfortunatelly this may lead to you having to buy a new display. Most of the time it can not be reconnected due to many wires in the same ribbon are to close. You may also have to purchase a new screen from the factory.
Feb 07, 2013 | Samsung SyncMaster 920NW Monitor
What causes my Samsung 920NW LCD monitor to go dark after a few seconds? I am running windows vista home premium. Thanks
If the power indicator remains on, the problem lies in the inverter board that powers the back lights. The cause is usually bad capacitors that sometimes bulge showing they are open. the board needs to be replaced or an attempt made to repair the old one.
Feb 16, 2011 | Samsung SyncMaster 920NW Monitor
Samsung 920nw when it warms display disappears & a few
Most common cause of the failed monitors are bad caps in the power supply, if it is about two years old, I would open it up and look for bad caps first, then look for any burnt parts, post back so we can guide you further, see failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 28, 2010 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
The repair guide has pictures and videos to guide you through the repair.
I hope this helps, if so please rate my solution.
BuddyMc
Nov 14, 2009 | Samsung SyncMaster 920NW Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Samsung 920nw display stay only one min and off but power on
This is due to backlite problem of LCD panel.
You may approach authorised service center for this issue they will solve your problem. Do not try to do yourself unless you have sufficient experience on LCDS.
Aug 05, 2009 | Samsung SyncMaster 920NW Monitor
No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 22, 2009 | Samsung SyncMaster 920NW Monitor
Good morning! kindly review the operations manual included when you bought the unit, takeing note on the best set-up settings of the display properties. Otherwise, you may opt to set it to other resolutions that will support the best display. best regards.
Aug 12, 2008 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920NW Monitor Logo
975 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
