Question about Tamron 18-200mm f/3.5-6.3 for Nikon
Lens gets stuck when retracting using the zoom ring
Lens of my camera developed a problem since last few months.
Th lens wont retract totally when using the zoom ring. It gets stuck at around 30mm.
I have to manually puch it in by pushing the top of the lens inside.
This leads to great inconvenience.
Also the zoom ring is not smooth to use as before. It does need some force to use it.
Gryfox
  • 216 Answers
SOURCE: AF 70-300 causes error 99 in my Canon 300D
This is usually a torn flexible circuit or binding aperture in the lens. It'll have to go to a repair shop for replacement. About a $80 job.
Posted on Dec 06, 2006
SOURCE: Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Posted on Jul 05, 2008
SOURCE: ERROR 99
try cleaning the lens contacts of your lens and camera.
Posted on Aug 13, 2008
  • 134 Answers
SOURCE: Lens jams when extending or retracting
This is either due to a cracked internal roller or a cracked/broken internal cam. The lens will have to be sent to Tamron for repair.
Posted on Apr 21, 2009
  • 37 Answers
SOURCE: My nikon 55-200 zoom lens is stuck at full zoom
Don't force it.
Did you get dust or dirt in it?
The only solution is to bring it in for service or send it to Nikon if it is a USA model.
Nikon USA will NOT repair any gray market items.
Posted on Jul 13, 2009
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
My dsc hsx-1 zoom lens wont retract from max.
my cam z sony DSC HX1..the problem z when i zoom in(max) the objct i m zoomin doesnt get focusd....when i shoot it the pic z totally blurrd....no matter how mch i try 2 focus with the manual focus option the outcum z da same....
Nov 27, 2009 | Sony Cyber-shot DSC-HX1 Digital Camera
Lens won't retract
You could try to gently pull the lens straight. If it's leaning to the right then pull the lens to the left. Don't use brute force but it's possible to realign the lens this way. If it works you'll hear a click and the lens will look straight. Switch on and see if it retracts. I'd only use this as a last resort because you can cause additional damage if it's overdone. It has sood success rate also
Sep 06, 2009 | Pentax Optio M20 7MP Digital Camera with...
Hi, my zoom is stuck out and won't retract.
Your lens motor is most likely burnt out. The only way to continue taking pictures is push the lens in manually, You may have problems with the focus after doing this, so just turn the lens manually until you are zoomed in properly. If you have a warranty now is the time to use it.
Jun 26, 2009 | Fuji FinePix A600 Digital Camera
Zoom wont adjust
Hi there. I can help you with that.
The number one problem with cameras with lenses that won't retract or or move out into position is dirt, grit or sand in the lens mechanism. The best way to fix this is to get an air compressor and put the tip up the lens and blow air into the space around the lens. Run the tip of the compressor nozzle around the lens and turn the camera back on. See if that helps. If it doesn't do it one more time.
If it helps, great. Stop there. If it doesn't help, let me know in a comment and I will tell you a couple more things to do. I want to wait, because they are things that you should only try if you are ready to trash the camera, but they usually work. Hope the air compressor works.
Rob
Feb 21, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Lens Error - Restart Camera : Lens remains in extended position.
Hey,
I had the same problem as everyone else regarding the error that would pop up stating that there was a lens error. I had the camera in my pocket when I went to a hockey game, pulled it out to take a picture, and it didn't work. Needless to say I was pissed because I expected far more from Canon. I was just about to go and buy a new camera, and figured that I would try to troubleshoot the problem and stumbled upon this site. Someone suggested turning the camera on and off while twisting the lens, so I figured it couldn't hurt to try it.
Before trying this, my lens would not retract all the way, the cover would not shut, the image was blurry, and I could not zoom in at all or the camera would show the error.
So, I tried the "twisting" solution, and it wasn't working, but I think I was being too delicate with it. I put a little more pressure on it and gave it a good twist. There was a clicking noise as others have said, but in the end, it worked after about 2 or 3 minutes of messing with it. No my lens goes down, the cover shuts and its clear as a bell. Not sure if this is a recurring problem as it appears to be a common problem, I fully suggest trying this before you send it off to get it fixed for a ridiculous amount of money.
Best of luck
May 03, 2008 | Canon PowerShot SD870 IS Digital Camera
Lens wont retract
I did the same thing to my camera (twice) and I just took it back to the place where I got it. Since it was within the 6 month return period- they let me exchange it for no charge.
They told me that when the camera hits something while the lens is out, it knocks the lens out of its groove, which is why you can't get it to retract.
Dec 16, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens cover stays open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 30, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Tamron 18-200mm f/3.5-6.3 for Nikon Logo
156 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
