Question about Sony Cyber-Shot DSC-S40 Digital Camera
On & off problem
My camera all of a sudden started telling me to turn power off and on. I cannot do anything and the lens cannot retract
Acer
I have a Sony Cyber-Shot ASC-S40 Digital Camera.  When I turn it on a message comes up which says "turn the power off and on again."  I've done this plus followed the advice on this website which said to hold down the power button for 30 seconds then turn it on again.  I've done this several times and nothing has worked.  This camera was only a little over a year old when I started having this problem.
    Genius:
  • 3,422 Answers
try this out it worked for most of them who had a similar problem like urs:
Gently tap it twice at the end of the camera to ur plam and it will work again.
just tap it very lightly against the bottom of the camera holding it upright.
If you still face the problem then the only solution is to get it repaired or replaced if it is still under warranty..
Goodluck,
Please don't forget to rate the solution
Posted on Apr 20, 2008
  • 3,037 Answers
From the sound of it, you most likely have some sand or other foreign material stuck in the lens area causing it to not retract. If you feel comfortable doing so, you can open the camera up and see if you can find what may be causing this problem. Maybe a gear is out of line otherwise. If anything is trying to move, see why it can't. The pieces are so small that a experience person working on it would be best. Good luck on fixing this and please let me know if you need any further help with this
Thank you for using Fixya and Have a Great Day!
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
  • Sony Master
  • 19,396 Answers
Check the batteries first, eventually pull them off ond put back in
  • Ginko
    Ginko Apr 20, 2008
    If you keep getting the problem it means that the lens may be stuck. Something is caught in the mechanism that releases the lens and it is
    interpreting that blockage to think that there is a cover or something
    else keeping it from operating properly.You can try pushing gently the lens to retract as you turn the camera on.
    If it does not unlock then you need service
Lumix tz30 lens will not retract
the oven will not igniter it get power so it not the breakerso can anyboby tell me whats going on?
Jan 18, 2014 | Panasonic Lumix DMC-TZ30 Digital Camera -...
Lens error
There is a possibility that a bit of grit or debris has got stuck in the retraction mechanism or the lens has been knocked out of alignment.
The camera will have switches inside to tell it when the lens is retracted or extended and if it doesn't make contact within the expected time then it will give this error.
If the there is no warrantee or you dont mind voiding it then I would suggest carefully disassembling the camera and turning the retraction motor by hand to see where the problem is.
Please comment again if you discover anything.
Good luck
Oct 19, 2007 | Nikon Coolpix 5200 Digital Camera
Camera won't turn on anymore
If changing battery doesn't help, then you better go through this blog's article about camera lens solution, http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html Please don't try to do anything if it's under warranty. Good luck
May 23, 2010 | Kodak EasyShare C913 Digital Camera
The lens won't retract and when you turn the camera on, it buzzes and then tells you there is a lens error.
You are gonna hate this... but when it happened to me... I placed the camera on the table - lens down.
I then powered it off and applied pressure to the camera (to get the lens to grab its drive gear inside).
It retracted and has worked fine ever since.....
Oct 12, 2009 | Canon Powershot A1000IS 10MP Digital...
Turn camera on, lens goes in and out then camera shuts off
You may try resetting the Camera to the original factory settings.
If the issue persists then service will be required.
Aug 27, 2009 | Panasonic Lumix® DMC-FS3 Digital Camera
L2 Lens Error
I just gave it a very hard tap against my dinning table and it became alright!
Jul 07, 2008 | Nikon COOLPIX L2 Digital Camera
On & off problem
this was happening to me, finally got it fixed by holding the power button down for 30seconds. must be 30 seconds, then it powered up and the screen popped up but i still held it down and then finally i had to turn it off and then back on and it WORKED!
Nov 20, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Canon Power Shot Pro1 will not turn on
A new camera will fix problem perfectly. LOL Did you drop it? Seem like there might be a short or something similar. Had U ever play the game "Operation"? This camera need it, of cause done by the pro. LOL
Sep 09, 2006 | Canon PowerShot Pro1 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
22 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
