Question about Car Audio & Video
How much does a Jensen Pro Speaker Box with 2 12inch speakers cost
4 Suggested Answers
SOURCE: kicker L5 solo baric
Wire the speaker in series and bridge the amp
Posted on Mar 16, 2008
  • 5603 Answers
SOURCE: have 2 blown square hifonics 12inch speakers
They probably will have to be reconed. Slight chance the flex leads have broken in which they MIGHT be repairable. If this occurred during playing very loud, you probably burned up the voice coils.
Have them reconed and then use an amplifier that maxes out at MUCH less power to drive them. Also fuse the speakers to protect them.
Posted on Dec 04, 2009
SOURCE: Repair of speakers inside Jensen BP212
i just got a bp212, and the reason for it is different, but i also had to remove the plexiglass front, i just used a hex bit, and unscrewed them.
Posted on Sep 02, 2010
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
Feb 15, 2015 | Sony STR-DE597 Receiver
How do I bridge my jensen 200watt bridgeable amp
To bridge an amp, connect the negative speaker lead of a speaker to the negative terminal of the first channel, and the positive speaker lead of the SAME speaker to the positive terminal of the second channel.
Mar 20, 2011 | Jensen Car Audio & Video
I have a jensen cd6112 radio vol control is not working also will not change bass/tre/ or speakers.Tried reset button but no change .Vol knob won't do anything.
I was installing a speaker and while drilling a spark flew. Didn't think anything of it and finished instalation. When finished the audio didn't work on any of my speakers. I have a jensen cd6112 and the unit seemed to be fine. Tuned in, the lights came on and everything. I hooked a radio straight to the speakers to see if they were blown and they worked fine. Is there a fuse in line with the speaker wires? I would hat to buy another jensen unit and the same problem exist. Any help? Is the jensen unit bad?
Jan 05, 2010 | Jensen Car Audio & Video
Is the Jensen car speaker model cv 650 a 4 OHM spreaker? I'm trying to match a 4 OHM subwoofer.
It should be a 4 ohm speaker as this is the standard impedence for car audio speakers. Jensen does not produce car audio speakers with any other impedences.
Jun 21, 2009 | Car Audio & Video
Nov 10, 2008 | Jensen BP212 Car Subwoofer
My indash jensen radio keeps shutting down when turned up?
Sounds like there's a power problem. First take out the radio and leave it connected. Turn on the radio normal volume, then disconnect the radio's antenna. If the radio shuts off then you need a better ground. If the radio doesn't shut off then you need to run power wires to the fuse box.
The only other thing is you have a bad speaker that only shorts out when you turn it up. Disconnect all but one speaker or one speaker at a time and see which one is the problem.
Jul 08, 2008 | Jensen Car Audio & Video
Jensen Bass Boost CR220x
white/black is speaker positive
white solid is speaker ground front and back ground
gray/black is speaker ground front and back
the solid black wire is battery ground
Apr 13, 2008 | Jensen SCR-60 Stereo Cassette Player with...
No low bass
Check the wiring of the woofers. If one speaker is wired improperly, it can cause the loss of bass and will make the woofers bottom out easily. Check inside the enclosure at the terminals and at the speaker.
Oct 28, 2007 | Jensen LXA300 Car Audio Amplifier
Jensen Subwoofer JPS-10
This sound is made by the automatic shutdown in the speaker. Jensen repaired my unit under warrantee.
Aug 27, 2007 | Jensen JPS10 Subwoofer
Need A Wiring Diagram
Hi Matt,
I assume you have probably got the answer but just in case you haven't. I just opened the box on a unit someone gave me and I have the harness. From left to right the first pair (top and bottom) are the left speaker + top and left speaker - bottom. The next two are the right speaker. The next two are left signal in and the last pair are right signal in.
I'm looking for an instruction manual if there even is one.
Brian
Mar 11, 2007 | Jensen XA92 Car Audio Amplifier
Car Audio & Video Logo
333 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
