Question about Canon T70 35mm SLR Camera
I have to press the shutter button twice on my t70 to take a picture. The first time the shutter closes and then the second time it opens and then the film winds. It is on manual and program mode. Will my pictures turn out blurry and if so how can i fix this?
    Habit-Forming:
    New Friend:
  • 25 Answers
    Top Expert:
  • Canon Master
  • 14,162 Answers
Posted on Jul 18, 2016
Gryfox
  • 216 Answers
SOURCE: Camera turns off
Open the file door and check to see if the shutter blades look uneven, like they might have been pushed out of track. Sometimes it's simple to re-track them - other times it'll have to go to a repair shop. Another cause is the film motor wears out and has to be replaced - a job for the repair shop.
Posted on Nov 19, 2006
SOURCE: AE-1Problems... Advance lever, Shutter, and more.
This happened to me to both the Canon's I had. I found out it was a dead battery. Once I replaced those it worked fine. The battery is hidden under the hand grip which can be taken off using a coin in the screw slot.
Sincerely,
Karin
Posted on Nov 24, 2007
SOURCE: shutter stuck
not sure about the 'BC', but the shutter problem is most likely due to shutter oil leakage. do you see some shiny black oil on the edges of the shutter blinds? i've had this happen to me once and the repair shop managed to clean it. seems like a problem that bugs Canon EOS cams. Replacing the shutter would most definitely cost more than the value of the camera, so you might want to try this
http://photonotes.org/articles/oily-shutter/
Posted on Apr 28, 2008
CameraRepair
  • 60 Answers
SOURCE: Is our Canon T70 dead?
It sounds like the motor is locked up. The gears under the bottom of the camera may have gotten sluggish from dried out lubrication. You can take the bottom off to see if the gears are able to turn freely or check with a local camera repair shop.
CameraRepairs
Posted on Aug 11, 2008
grant185
  • 117 Answers
SOURCE: The shutter on my canon a-1 seems to be stuck.
If you opened the bottom you saw the magnet that holds the shutter /mirror mechanism closed- sometimes it and the lever it holds get dirt or corrosion on them and won't hold the lever when you **** the shutter? it can also be the battery is not dead, but not enough voltage to supply enough power to hold lever.
Posted on Aug 25, 2009
So, I finally figured out (with your help) how to find BULB in M. But, is it normal to press the ml-l3 button three times to get a picture. I did turn long exp nr to the on position. and the release in...
You should only have to press the button twice to take a picture. In the BULB setting, the first press opens the shutter and the second press closes the shutter. With the long exposure NR turned on, it doubles the picture taking time. If you take a one-minute exposure, for example, the remote will be ignored for a minute after the second press.
Try turning off the long exposure NR just to see whether two presses do the job. If it doesn't, please feel free to reply to this post and provide any additional information you can.
Jul 08, 2011 | Nikon D7000 Digital Camera
Cannon EOS500D, taking a picture in creative modes I have to press the shutter button twice to take a picture.(not counting the half pressing of the shutter button. the second pressing of the shutter...
Hi kevinmullen8 - was this ever resolved? My mum was mucking around with my camera (eos1000d) and I have the exact same problem (press shutter twice in creative mode). Factory reset was of no assistance.
Please help!!!
Dec 05, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
How do I get to the self timer?
Press Home key and see Clock icon in list, its self timer, select it and press shutter button to take picture, camera will take picture after 10 seconds.
Below image shows Timer Icon in your DSC-T70 camera.
Dec 20, 2009 | Sony DSC-T70 Digital Camera
Shutter needs to be pressed twice in creative zone?
Your camera could be enabled for Mirror Lock-Up, thus needing two presses of the shutter to shoot - first press to lock mirror up till vibration dissipates, second press to activate shutter.
In the menu, go to C.Fn III: Auto Focus/Drive, #7 - turn that off/disable.
May 25, 2009 | Canon EOS 40D Digital Camera
Help with "B" setting
You press the shutter once and that opens the shutter (you do your light painting) then you press the shutter a second time to close the shutter.
When you press the shutter the first time and look in the view finder it will be dark . this is because the mirror has locked its self up while doing the exposure (this is normal) Once you click the shutter a second time the mirror will flop down and you will be able to see threw the viewfinder again.
Jan 24, 2009 | Canon EOS-AE-1 35mm SLR Camera
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Smile shutter feature
Select the smile shutter option from the program settings. You will see an icon of a smiley face on the bottom left hand of the screen. To activate the automatic shot of when a person smiles, simply hold down the shutter button for a second or two. Now, when the camera face detection senses a smile, it will automatically take the picture. To deactivate it, press the shutter button again, the camera will then tell you how many shots it took. Hope this helps.
Dec 29, 2008 | Sony DSC-T70 Digital Camera
Canon t70
Honestly, I just got a T70 on ebay for $15. Sounds like it's time to move on. I had an AE-1 for over 10 years but it just wasn't working and one has to weigh the cost of repair, the cost to replace it or upgrade to a modest digital camera.
Oct 01, 2008 | Canon T70 35mm SLR Camera
Taking a photo of the family, delaying the camera until I can get into the shot.
Sure, follow these steps...
  • Set everyone in an even composition, close together, maybe some standing, some sitting, whatever strikes you as a good picture.
  • Put the camera on a tripod or other tall article
  • Press the Mountain/Macro/Timer button until the (clock/timer) icon is displayed on the viewer. The button to press is just above the MF (Manual Focus letters)
  • Press the shutter button all the way down to activate the timer.
    • Press once for ten-second delay
    • Press twice for three-second delay
    • Press a third time to stop the timer
  • Jump into the shot! =)
The lamp next to the lens will start to blink and continue until one second before the picture is taken. The lamp will then stay solid during the last second to warn about the picture being taken.
Please rate FixYa!, ThankYa!
Dec 15, 2007 | Nikon Coolpix 4500 Digital Camera
Canon T70 35mm SLR Camera Logo
457 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
