Question about Health & Beauty
I have a 1980 honda express 2 moped that i am slowly trying to restore there are some things missing a battery and has broken ignition switch.i turn ignition on by useing a screwdriver,.my problem is i had it running sometime ago with a battery charger hooked up ,but now i try to start without charger, it seems that while turning to find right ignition position ,at the same time holding the sparkplug wire i dont have spark, but when i have my body on the frame i seem to have spark my question is do i need a battery to start moped to complete circuit or should it start without battery.i am thinking my problem is either battery,broken ignition or points or a wire short while i had it running my headlight never worked .can u help me with this ugly duckling waiting to be a swan .tom l .laporte ,ind
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
It doesnt need a battery to start and the headlight will only work when the engine runs and the ignition switch is in a second position.
You will probably need to find another ignition for it to all work.
If you try dissconnecting the ignition completely at the plug, it may spark, as the ignition switch has a kill circuit in it, which is to stop the engine. the on position really only completes the circuit for the indicators and horn and brake lights.
They are only 6v, a 12v charger can damage electrics
Posted on Jul 24, 2010
1980 Yamaha qt50 has good spark but will not start, leave alone for 20 min and starts right up, and then same thing happens all over again, any ideas?
Hi, Bill and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to the carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://scooterbbs.net/international-moped-bbs/1212.html
Scooter Troubleshooting Scooter won start All about Scooters Yamaha QT 50F Service Manual
OEM parts for Yamaha
Yamaha QT50G2 Owner Manual
Feb 20, 2017 | Yamaha Motorcycles
1982 honda nc50 has no brake, turn signils, horn ect
Hi, William for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Honda, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Wiring Diagrams Myrons Mopeds
http://vfrworld.com/forums/showthread.php/29448-No-Turn-Signals-No-Brake-Lights-amp-No-Horn-then-try-this-gt-gt-gt-gt-gt
No Horn No blinking turn signals in The Repair Shed Electrical Help Forum
http://www.jax184.com/projects/Express/Honda%20Shop%20Manual%20for%20NC50-NA50.pdf
http://www.vintagemopedsforsale.com/pdfs/honda-express-nc50-1978-owners-manual.pdf
Jun 23, 2016 | Honda Motorcycles
1980 CX 500. Why doesn't left cylinder fire until high rpm?
could be a spark plug failing under the higher compression of the increased rpms
start by changing the plug and or HT lead or coil if independent of the other cylinder
Apr 02, 2016 | Honda Motorcycles
Hooked brake lights up and it stopped starting and all lights stopped working when u turn key on i got new battery and rectafifer on it
Hi, Steve and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
Bike Will Not Start GL1100 Information Questions goldwingdocs com
1983 GL1100 won start
1983 GL1100 Aspencade won start
Honda Goldwing GL1100 1980 1983 Workshop Repair Manual
Mar 20, 2016 | 1983 Honda GL 1100 Aspencade Gold Wing
I have a 84 Honda NightHawk 700s and I turn on my bike and the headlight does not turn on unless I hit the hi beam switch, what could be wrong in the wiring?
Hi, Anonymous if your headlight is not working the first thing to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply to headlight bulb socket.
2. Faulty hi/lo beam switch.
3. Faulty ignition switch.
4. Fuse is good but no continuity on both sides.
5. Faulty wiring between battery positive and headlight bulb socket.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
Motorcycle Headlight Help
Headlight wiring Testing Pt 1
Honda Motorcycle Manuals 1980 to Now
https://www.tradebit.com/filesharing.php/search/0/1984+honda+nighthawk+700s
Dec 07, 2015 | Honda Motorcycles
I have a 1985 Honda Aero 50 moped/scooter. My friend who is a retired car mechanic told me after listening to my moped, that its skipping. what does this mean? And how can i fix it?
He means that it is not firing all the time. It is also called missing. The issue could be bad wires, plugs, ignition parts etc.
Apr 07, 2015 | Honda Motorcycles
No electrical power when I turn on the key for a 1998 Honda XL650
Hi, Anonymous before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.starbikeforums.com/forums/14-royal-star/23673-no-electrical-power-when-key-turned.html
Dead Bike No Dash No Fuel Pump No Lights
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/227
Mar 02, 2014 | 2000 Honda XL 650 V Transalp
Bike does not start
Hi Anonymous, and the usual suspects are:
1. Fuel tank empty.
4. Engine flooded as a result of over use of enrichner.
5. Vacuum hose to fuel supply valve/petcock disconnected, broken, cracked, or pinched.
7. Discharged battery, loose, corroded or broken battery terminal connections especially the "NEGATIVE" cable inside the harness at both ends.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module or sensors (MAP, CMP CKP and/or BAS).
11. Sticky or damaged valve or pushrod wrong length.
12. Primary cam sprocket spline sheared or missing spacer.
13. Security alarm needs a reset.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
50cc Mopeds 125cc Scooters Motorcycles Motorbikes for Sale at AJS
Mar 02, 2014 | AJS Motorcycles
Motor turn over as soon as I put the battery cable on .
For the motor to engage even with ignition off would indicate that the starting relay/solenoid is faulty and the contacts are fused together. Another possibility and that could also be responsible for the missing lights would be a mis-connected connector.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 19, 2008 | 1980 Honda GL 1100 Gold Wing
Health & Beauty Logo
360 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
