Question about Sony Playstation 3 (PS3) Console
Ps3 slim says hard drive corrupted but wont re boot or fix itself.
  • 206 Answers
You are going to have to replace your hardrive if it is corupted then it will not be ableto fix or reboot itself
hope i could help a little bit!
Posted on Jul 22, 2010
How do i fix my ps3 from saying corrupted hard drive
Try posting this in the section on this site that deals with PS3 etc--no answer is likely to be found in the portable TV area.
May 25, 2012 | Sony playstation 3 slim 160gb 160 gb...
Tip
How to remove the hard drive on a Playstation 3 Slim Removing the hard drive on...
Removing the hard drive on the PS3 Slim is simular to removing the hard drive on an original PS3, however the drive is in a different location.
Note if you are upgrading PS3 hard drive you will need to back up your data first so that you are able to put your files back onto the new hard drive.
1. Make sure you have all your cables unplugged from the PS3.
2. Turn the PS3 upside and locate the hard drive access door (it will be at the front of the system next to the small info sticker).
3. Ether with your finger nail or a small screw driver lift up the cover.
4. Next carefully unscrew the blue screw. Note you will want to make sure you get the right size phillips head to make sure you do not strip out the screw head. On the few systems I have seen a PH1 head you be the right size you need.
5. After you have the screw removed you will want to slide the hard drive cover to the right to expose the hard drive.
6. Next pull down on the lever and pull strait back in the drive caddy to remove it from the PS3.
If you have remove the drive to upgrade the drive you will want to unscrew the drive from the caddy and install your new drive.
If you have removed to corrupted data on the hard drive the link below will walk you through formatting the hard drive on your computer just skip to step 4 as the first steps are for removing the hard drive from the original PS3.
How to fix PlayStation 3 corrupted hard drive
on Oct 08, 2010 | Sony Playstation 3 Slim Console
My ps3 says that the hard disk's file system is corrupted
Reformat the hard drive - the processed can be started in the setup.
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
Ps3 slim says hard drive corrupted but wont work?
You will need to update the hard drive. You have to go to playstations website and find the update for your ps3 dashboard you can put it on a memory stick make sure to save it just how sony suggests. Then you put the memory stick in the ps3 and it will update your hard drive and it should work. Fixxed several with the same problems that way. Hope this helps. If you need help finding the update just let me know.
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
When I start up my PS3 slim it goes to a screen saying my drive is corrupt it lads to 100% then turns the system off automatically then when it turns on it brings me to the same screen about the drive...
Guest
If you are getting the corrupted drive message this means that you have corrupted data on your hard drive. The link below will help you address this. If you still have trouble you may need to replace the hard drive.
Note the link below I made is based off the original PS3 but everything still applies. If you need the actual physical steps I just got access to a Slim and will be updating the steps this weekend. Also with your Slim it should be in warranty so if the hard drive is bad I would contact Sony's techsupport about getting it replaced.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or quesitons
Issken
http://www.fixya.com/users/issken
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Having trouble hard drive in ps3slim
Wiredextreme.com can fix your YLoD for 86 dollars and you can buy up to a 4 year warranty that covers everything on the PS3.
I suggest returning the slim and sending in the 60GB
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
Help brand new ps3 hard drive corrupted. Im not taking the hardrive out, HELL NO!
I would return for replacement if it is new. Or send to sony would be under warranty if under 1 year. If not warrantied try to format the hard drive.Replace hard drie if it is older style PS3 and not the new slim PS3. I think the hard drive is built in and cannot be removed. If is a slim, your best bet is the warranty. Good Luck.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Hard disk corrupted
pettyjohnsco
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
Let me know if you have any more problems or questions
Issken
Mar 06, 2009 | Sony Playstation 3 (PS3) Console
My ps3 tells me the hard disk is corrupted
Sounds like you might need a new hard drive. You could try to disconnect it and reconnecting it, but usually it does not fix the problem. just remember you need a 2.5 sata hard drive (might be a good thing, if you ever wanted more hard drive space).
Dec 13, 2008 | Sony Playstation 3 (PS3) Console
Corrupted hard drive
All you need is a friend with a ps3!! Swap the hdd's and boot up your friends ps3, format the hdd, put it back in your ps3 and you may need to format it again.
Aug 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
221 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
