LOST MY MODEM CANT FIND IT 192.168.0.1 AND MY STATUS METER IS MISSING. I NEED BOTH OF THEM.
  • 6,487 Answers
If you cannot access your modem setup page there reason for that is you modem is not giving IP address to your computer , try to PIN first the ip address of the modem from command prompt type PING 192.168.0.1 and if its not replying do a power cycle shut down all the devices and then try to Ping again.
Posted on Jul 18, 2010
  • 146 Answers
Sir, to get into your modem config page, type in the address bar any internet explorer : 192.168.1.1
It will promt for username and password, by default both the value are : "admin". Status meter in the sense, you didn't specify which status meter. Once you login to the modem config page, you can see the status meter in that page.
If 192.168.1.1 not worked, try to get your ip address by going to www.whatismyip.com
and type that ip in the address bar and enter the username and password and login to your modem. Thank You.
Posted on Jul 12, 2010
  • Govind Jul 18, 2010
    If
    and
Windows vista crashed. changed bios to load xp. worked. old files on hidden drive. problem is cant connect to internet. driver files on hidden drive. Now what? Try to find driver and load it?
your explanation is very confusing. your internet connection must come from a modem either directly or remotely thru router. your mentioning of hidden drive does not make sense. drivers are not part of internet connection. you need to reset the modem and router if you are connecting through it. turn everything off. unplug router and modem. after 15 seconds unplugged, plug only modem in, wait until lights stablize; now plug router power back in, wait for lights to come on;,next turn PC on. Wait until completely booted up. go to control panel click on Network Internet, when opens try to find the local connect to network. if none, then your modem is not receiving signal or IP Address from your internet provider(comcast,centurylink, whoever). check status, if active fine. if active but icon says no internet access then your router is not set correctly. you may have lost its set up and you will have to reset up your router. you should have the step or instructions for doing that. after resetting and network active, restart computer so that is receives fresh settings from router.
if no network is found after restart you may have to reconfigure your internet connect by using the internet connection wizard(control panel).
Sep 27, 2012 | Dell Dimension B110 PC Desktop
Modem problem
You need to find out the modem card make and model in system info. Then find the driver from DELL windows7 operating system?
Mar 04, 2012 | Dell LATITUDE Computers & Internet
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
My laptop can't connect via wireless to my att/dsl 2wire wireless router/modem. it see's it but cant connect
Hi toasoulinh,
First off you need to go to your network connections, and right click on the wireless connection and view status. Then click on the support tab, and then the details tab. This will show you what the IP configuration is. You need to have a gateway (which is your wireless router IP) and a assigned IP address for the laptop, and also a dns IP to resolve who you are. I'm going to guess that one of them are missing, perhaps the DNS? If there is any missing click on the repair button, and see if it corrects the problem. If not, then you have a bigger problem then you bargined for. You will need to go to your network connection and click on wireless connection. Inside you will find a add wireless connection button. Click this button and windows will walk you through creating a new connection. If that doen't to the trick.
You can reconfigure your HomePortal without using the setup CD.
  • Open your Web browser.
  • Type http://homeportal/setup in the address or location line of your browser.
  • Follow the on-screen instructions to complete the setup process.
    • If you need a key code, you can find it at HERE
    • If you need to replace drivers for your 2Wire network adapters, you can download them directly from the 2Wire support Web site.
Good Luck,
And don't leave a rating
Thanks
Mark
Sep 21, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Cant connect to internet using edge modem
If the modem came with a disc, run it, the drivers are probably missing. If you don't have a disk then you need to go to your control panel, go to add hardware, look for any icons that have yellow questions marks on it, fix it and your good to go. Or you may need to renew your IP address. Without an address you can't go online. Hope this helps.
Good Luck =)
May 21, 2009 | Smartlink (I56KSPF00) Modem
Cant get internet on both computers using router
When did the router stop working?
Have you tried a new cable between the router and the modem?
Since the status light is off on the router, that tells me that there is no communication between the router and modem. Is it possible that the router was reset by accident? Resetting it will put all settings to default. If it has been reset then you need to sign on to the router to setup the communication again to your modem. Typically this is done via the IP address.
I can walk you through those steps if that is the case. Try supplying a different cable though between the router and modem. Power off both of them, power on the modem and then power on the router....then try to connect to the Internet.
Mar 26, 2009 | D-Link DI-624 / DWL-G520 Kit...
ADSL Router DSL-G604T
all ADSL routers are very fussy when it comes to power fluctuations, even the tiniest can set them into error, first thing to try, is pull the power cord out of the back of the modem, wait a couple of minuteds, then plug it back it, give it a few moments to re-connect and see how it is, if no luck with that, check the DSL, or ADSL light is on and solid.. if so look on the bottom of the modem for an ip address, open internet explorer browser, type that ip address into the address bar and hit enter, it should prompt you for a username and password.. usually ADMIN for both user and pass.. then go to "status" or "diagnostics" depending on the modem, and it will give you a run down on any potential problem..
PPP error: username and password are wrong (Authentication Failure)
Jun 01, 2008 | D-Link DSL-G604T Wireless Router
HL-DT-ST DVD-RW GWA-4082N
my HL-DT-ST DVD-RW GWA-4082N has a problem i cant up date the drivers in my computer it is missing so if in incert a cd it cant be found my HL-DT-ST DVD-RW GWA-4082N has a yellow exclamation an status Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Feb 29, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
Lost installation cd
What is the model of the modem?
and what OS do you have?
Nov 02, 2007 | Computers & Internet
Kt600 8237
-Check your cables and power status first. -verify your internet connection via router or modem -Scan for viruses -Fix wndows Errors -check your network properties and status
Sep 28, 2007 | Soyo KT600 Dragon Plus Motherboard
Computers & Internet Logo
David Payne
David Payne
