Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
  • ambientplumb Jul 12, 2010
    i am a plumber and i install breamar units i belive the $230 plus parts that brivis have quoted me to just attend and look at it is a rip off
    Guru:
  • 528 Answers
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Posted on Jul 12, 2010
  • Archie Cruz
    Archie Cruz Jul 12, 2010
    If that will resolved the issue and why not. There are things that we cannot be fixed due to certain limitations and needs to be done by manufacturers technician.
    All the best.
  • 677 Answers
Hi, If the error continues to appear, contact Brivis Service. ..... If the unit has not started blowing warm air after 30 minutes ,. Please contact our Brivis Service (13 26 65) for an authorized ... installations may require two service personnel to attend, in accordance with EH & S requirements. ....
Take care.
  • 821 Answers
Hello,i will advice you contact brivis on this number to provide you with a comprehensive solution,because the codes you talked about are not common errors on brivis heater.
CALL:1800 335 094
fax:1800 655 465
wish you good luck,
take care.
Brivis heater spanner showing with ho1 code 65
It is a flame loss error. Open the unit up Clean both of the flame sensors with either a file or steel wool (with the power off) then turn power back on and reset the screen to do this hold down all 3 buttons for 10 sec. there should be 2 buttons on one side and 1 on the other. hope this helped :)
May 10, 2014 | Heating & Cooling
Hi I have error code 30 H1 on my Brivis heater, The problem is the fan sometime speed up itself
my power went out last night and today the heat was not working just the cooler , l turned off the main to the heater and the main power and reset the unit but is still the same
Mar 23, 2012 | Heating & Cooling
Error code 62 on Brivis Me20 ducted heater
Hi
Error 62 is related to hot surface ignitor (HSI)or/nglo module
you can check the resistance of the ignitor should be less than 10 oms @ 20 degrees
failing that, if you incomming suppy exceeds 270 volt will also result in error 62
May 04, 2010 | Heating & Cooling
Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Apr 12, 2010 | Heating & Cooling
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Brivis Ducted Heating system. No display on Programmable controller inside hoiuse. Electronic Control (Model 14100) located on Heater (outside house)displays "Searching". Have turned off...
I have an identical issue with my Brivis.
Did you get a solution?
Mine can be running, then goes blank and says searching. it will eventually come back.
Just wondering if you had to replace the 14100?
Cheers
James
Jun 10, 2008 | Heating & Cooling
Brivis Heater help
These Brivis guys and girls are a rip-off. They are only out to take your money. Then can easily ask you to do just as mentioned above. And pronto all works in 3 minutes to be precise.
It is just the power supply reset required due to a fult being detected, either caused by a very low setting on the controller less than 16 degs. or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
So, put the power supply to heater off first, reset the heater panel, press the button again to shaow EMS on and then set the heater to the required temp. after turning on to the heating mode. That simple! That is if it is the error 71 HI.
Jun 01, 2008 | Heating & Cooling
Heating & Cooling Logo
3,231 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
