Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I can get my Usb adapter wirelessG MIMO TO GET AN ip ADRESSE ?
  • KG John Justin
    KG John Justin May 11, 2010
    give full details and from where want to get ip
  • 105 Answers
You type on internet b rowser 192.168.1.1, and ask you to enter the user and password , both are admin and enter. if it did not work go through router manual for configuration you will ip address for configuration if necessary restart the system
Ask your ISP to give detail of network, sometime your IP (internet) may be dyanamic in that case you can not assign any value, stick with their configuration
Posted on Apr 27, 2008
  • 323 Answers
To get an ip address from your router you have to setup the router from http://192.168.1.1
You should already have an ip address setup though.
You need to contact your DSL/cable provider and get access to their website to setup your account information to access the internet. Then you have to setup your wireless connection if you are needing to do so, let me know.
Posted on Apr 20, 2008
Connected computer to wireless network but can't connect to internet
Shut down all computers connected to the network, and reset the router. WAIT for the lights on it to return to normal. Start up one of the computer to make sure it has internet access. This will eliminate any issues the router may have.
Make sure you have the passphrase (password) for the network handy (If that matters.) You need to check to see that the computer using the adapter has the correct IP address, and that the adapter settings are getting the IP address automatically.
IF you still cannot connect, uninstall the adapter, reboot the computer using it, then reinstall it and try again. You may also have to go into the network and sharing center, advanced adapter settings, and remove the network, so it can be re-detected by windows.
Sep 27, 2013 | Sabrent USB-802N Wireless 802.11n USB 2.0...
Wont connect to internet
The password for your USB adapter is different from router password.
Mar 12, 2013 | Zonet ZEW2508 54Mbps WirelessG Usb Adapter
Bonjour pouvez vous me dire comment installer la tec sx4 en reseau sous windows xp
Pour installer en r?seau deux solutions.
1 Installer la carte r?seaux et param?trer l'adresse ip, l'adresse passerelle et le masque de sous r?seau.
Soit sur le paneau ou en utilisant les commandes ci-dessous en modifiant les valeurs:
{IP;2,192,168,001,201'} adresse ip
{IP;3,000,000,000,000'} passerelle
{IP;4,255,255,255,000'} masque de sous r?seau
{IS;1,09100'} activation du port telnet en 9100
ou
brancher un boitier axis ou netgear sur le port parallele
Feb 15, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
My G Mimo Plus adapter won't pull and IP address. Any suggestions?
Is there a RESET button on the back of the router, if so power it up and press the RESET button until all the LEDs flash and reconfigure the router.
Try a different LAN cable, the other could be faulty
Install the latest LAN and wireless card drivers (this problem sometimes occurs when you install a new router).
Check the LAN and wireless cards are functioning correctly in Device Manager.
Open the DOS cmd window.
Test the NIC - loopback test address - ping 192.0.0.1
Ping the router's IP configuration address
Type ipconfig to see what IP address you get (if any)
Type inconfig /renew all - this will (should) get a new IP address from the router's DHCP
Let me know how things work out.
Dec 24, 2009 | Belkin Wireless-G Plus MIMO Router with...
Usb network adapter adapter. I want to configure
If you ar eusing vista go to the small wireless indicator on your toolbar..dble click it then click connect to network...click on your connecion and it wil as you if you want to save it...probably similiar to XP
Jun 07, 2009 | Belkin F5D9050 Wireless G Plus MIMO USB...
I am having problems with my belkin wireless usb adapter, while at first i thought it was a problem with the router, i now realize that my problem lies with the usb adapter receiving the wrong ip address,...
There's a big possibility that your computer is set with a static IP, computer should be set to Obtain n ip automatically, follow this Go to control panel and network connection then look for Wireless connection>right click on it and click on properties>look for Internet proptocol TCP/IP from the list>click propeties>a new window will open just set it to both Obtain and then click on OK and close all the window, then after that check if the computer is already getting a new IP if still no restart the computer....
Dec 09, 2008 | Belkin Wireless-G Plus MIMO Router with...
Connecting to secure network
when enabling wireless security the router and adapter must be both be configured and configured in a fashion that both support. If you need help provide confirmation of your wireless router's manufacturer and model and the same information for any wireless adapters or computers with built-in wireless adapters to be wirelessly connected.
This will allow us to determine the common security options for all wireless devices you have.
Dec 16, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
50 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
