Question about HP Designjet Z6100 InkJet Printer
Can the print head be reset and used again after it gives out of warranty message?
  • 38 Answers
Printheads can not be reset after it expires, but it should still works fine. Unless you have a problem with print quality.
Posted on Jul 12, 2010
Gives message Printhead loose missing or not installed. changed several times same message
If you already replaced Print head then same error occur their might be a problem with the carriage unit. kindly check also if there is a leak inks on a carriage contact then clean it.installed again print head.
May 08, 2015 | Kodak 6150 AllInOne InkJet Printer
Error message saying that the type of print head is incorrect.?? Been using this printer for years and haven't changed the print head.
The printer is not giving the message.
The program you are printing from is giving the message.
either the paper is wrong, the type of printing you are trying to do ie photo, is wrong
Mar 11, 2015 | Canon Office Equipment & Supplies
0xc19a0035
The ink system failure is a pain to troubleshoot. It could mean that the ink cartridges are not communicating with the print head, the print head is bad or the entire printer needs service.
Try resetting the printer to clear the error from memory:
First with the printer on, unplug the USB cable (if using one) from the printer (and the computer).. Then remove all of the ink cartridges from the printer (lift the scanner unit as if to change the ink). Wait for the printer to indicate "Insert ink cartridge). Then unplug the power cord from the back of the printer. (Note: do not turn off the printer just disconnect the power cord.) I also disconnect the power cord from the outlet and the power adapter (this resets the adapter). Wait 60 seconds or longer. Then reconnect the power cord to the printer, the adapter and then the outlet. Turn on the printer if it doesn't turn on on its own. Reinsert the ink cartridges and close the printer. Print a calibration page if prompted to do so. Finally reconnect the USB cable. Try printing again.
If the message repeats, the unit needs service. This printer doesn't allow the user to service the print head so the cost for servicing is variable. If the printer is under warranty, contact HP for service. Otherwise decide if it is worth the cost of service (expect a minimum charge of $50 just to determine the problem.)
I hope this helps.
May 16, 2012 | HP Photosmart C8180 All-in-one -...
Hello again can i not clean the printer head nozzles myself? in my brother mfc 490cw out of warranty but was working previously until black ink ran out copying but they are blank pages all inks are full
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, thenprint head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head. A Warranty does not cover blocked print heads.
Jul 20, 2011 | Brother MFC 490cw Color Inkjet...
HP Photosmart C5380 All-in-One. Ink system Failure. Oxc19a0023 My computer has Windows XP and IS is Internet Explorer.
The first step is to try resetting the printer. Turn the unit off, unplug the power cord and wait 30 seconds before reconnecting the power. Turn on the printer. If you still have the error message, you may need to clean the print head. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=au&lang=en&product=3560275&docname=c01458034 has the details.
Remove all of the cartridges, lift the handle on the carriage until it stops. Lift the print head straight up. Once the print head is out, you need several lint-free cloths and distilled or bottled water. With a damp cloth, wipe the electrical contacts from bottom to top (do not go past the edge). Then wipe the edge between the ink nozzles and the electrical contacts - wipe away from the nozzles. Wipe the ramps on either side. Dry all three areas.
With a new damp cloth, wipe the contacts inside the printer from top to bottom until no ink remains on the contacts. Dry this area.
Reinstall the print head and lower the latch carefully. Reinstall the ink cartridges making sure that they snap into place.
Check if the error message repeats. If it does, try resetting the printer (power cord unplugging cycle). If you still get the error, the print head may need to be replaced. If a new print head is in and the error occurs, talk to HP support if the printer is under warranty. You'll have to decide if these last two steps are worthwhile if the printer is out of warranty.
I hope this helps.
Apr 24, 2010 | Office Equipment & Supplies
F340 will not print
try resetting printer by power flee and clean the print heads with soft material
it works for sure
Sep 01, 2009 | HP Deskjet F340 All-In-One Printer
Canon printer not printing and gives error code U052
you have a purge unit problem, cost more than the printer is worth unless it is under warranty,
Canon small printer technician
Mar 31, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Get paper jam error on Brother MFC 5840CN
are you using brother oem ink? generic ink gives lots of problems
Dec 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
NO PRINT HEAD
First remove cartridges and remove print head and make sure the contacts on back of head look clean. I use fibreglass pen and give clean if in doubt.But be very carefull cleaning. But maybe not seated correctly.? If you pull the print head out and do another test does it come up with same message.?
Try again and see what you get. Still worth replacing head if faulty as where else can you get a 8 ink printer. Unsure what head costs.
Nov 12, 2007 | Canon PIXMA iP8500 InkJet Photo Printer
Hp Officejet 7110 Not Printing From Computer
HP 7110 Printer
The problem with the printer is it does not work, there are flashing lights and the message it gives you is to turn the power on and turn it back on. Needless to say when I reboot the system and unplug the printer and plug it back up, I get the same message, does anyone have any solutions to this problem????
Sep 07, 2007 | HP OfficeJet 7110 All-In-One Thermal...
HP Designjet Z6100 InkJet Printer Logo
386 people viewed this question
Seeker5211
Seeker5211
